Reply 20 of 45, by Gamecollector
Gex 2 is glide or d3d+glide.
IIRC the EU version (Ubi-Soft) is glide only.
The US version (Eidos) is d3d only. And there is the glide patch for this version.
Reply 21 of 45, by derpmochump
Garrett W wrote on 2020-07-25, 00:14:
Fairly certain Dreams to Reality only runs on the original Voodoo (and perhaps Voodoo Rush). Even Voodoo2 can't run it apparently.
okay thanks.
MSI MS-6734 KM3M mobo / Athlon XP 3000+ /512mb ddr1 ram
Voodoo 3 3000 PCI @185mhz / Aureal vortex 2 (dell oem)
3dfx ref. drivers win98se and dual boot with winXP-32 bit running amigasport 3.0 3dfx drivers oc'd with koolsmokey's V.Control in XP
Reply 22 of 45, by robertmo
finished 😀
thread may be locked now 😀
Reply 23 of 45, by robertmo
ok, it looks games using direct3d from directx 2 or 3 cannot be really counted as using direct3d.
we have to wipe out all d3d 2 and 3 only games from the list
unlocking the thread
Reply 24 of 45, by robertmo
all dos games are considered glide only (and not on the list for easiness) unless someone proves otherwise
Reply 25 of 45, by robertmo
if a game runs in higher resolutions with dgvoodoo2 then it is using d3d 5 or more
Reply 27 of 45, by robertmo
it's basically same as software
Reply 28 of 45, by willow
robertmo wrote on 2020-08-15, 17:10:
It's not true.
Lands of lore 2 win95 version use only directx3.0a (only dos version use glide) and you can run in higher version with dgvoodoo2.
Reply 29 of 45, by robertmo
if you want you can post a screenshot when looking at the pool
but when you look at the pool you notice the uneven blocky line of the edge of the pool
Reply 30 of 45, by willow
robertmo wrote on 2020-08-16, 14:37:
I have just tried this afternoon and force higer resolution works with lands of lore 2 win 95 dx3.0a version.
640x480
2560x1440
640x480 stretched
If the pool is in 2D, it's normal.
Force resolution doesn't change 2d elements like sprite. It's change only 3d elements.
LoL 2 have lot's of 2d elements.
Reply 31 of 45, by ZellSF
Lands of Lore II's Direct3D render has a lot of issues btw, the DOS Glide render is a lot better if you want to play the game. It isn't fun to get that working on modern systems though, especially not if you want resolution forcing.
Resolution forcing definitely works for the Direct3D version, but it causes glitches with some graphical effects.
Reply 32 of 45, by robertmo
ok, it looks very high resolution is indeed working
i guess i was confused, cause for some reason i cannot see a razor sharp picture with d3d
dos glide is razor sharp in lol2g btw
Reply 33 of 45, by robertmo
ok, so everything marked on the list as d3d in first column should work in very high resolutions in dgvoodoo2
Reply 34 of 45, by BEEN_Nath_58
Civilization 2
Knight's Chase
Reply 35 of 45, by BEEN_Nath_58
robertmo wrote on 2020-08-15, 13:12:
Some games get to a higher resooution, like Moto Racer and Daytona USA, using dgVoodoo. They are dx2 and dx3 games. Do they qualify for this?
Reply 37 of 45, by BEEN_Nath_58
This list is in the top, how to do that. I also want to keep my list of dx8.1 and older games running on win10 list on top like this
Reply 38 of 45, by robertmo
i guess you can start a new thread in dgvoodoo2 subforum named
"Direct3D games list that get to a higher resolution with dgvoodoo2"
Reply 39 of 45, by filipetolhuizen
Ignition
Simcopter (despite being so buggy)
