First post, by Metal
- Newbie
So my luck building this retro PC project of mine has not been so good so far. Right now the problem I'm having is that I can't for the life of me get NT-based Windows OS's to install. I've tried Windows XP off an HP OEM CD and Windows Codename Neptune (beta OS based on Win2000). What happens is I make it through the initial text-based install phase with the blue background, and when it reboots after copying all the files, I get an error and the computer won't boot into the setup. If I formatted the hard disk with NTFS in the setup, I get:
Error loading operating system
after the Verifying DMI Pool Data..... message.
If I formatted the hard disk with FAT32 in the setup, I get:
Missing operating system
My specs are:
- Gigabyte GA-6BXC Slot 1 440BX motherboard v2.0 (manual with specs: https://www.gigabyte.com/Motherboard/GA-6BXC/ … #support-manual)
- Pentium III 550MHz with 100MHz multiplier
- NVidia GeForce FX 5200 (AGP, unbranded Dell OEM part)
- 1 Stick 256MB PC100 SDRAM
- 40GB Seagate HDD (Using SATA -> IDE Adapter)
The DVD drive and HDD are on the same IDE cable.
Additionally, I tried to install Mandrake Linux 7.0 on a freshly-wiped hard disk and had similar results. That used the LILO bootloader and got the error code "LI", and according to https://www.tldp.org/HOWTO/Bootdisk-HOWTO/a1483.html, that means the first stage boot loader was able to load the second stage boot loader, but has failed to execute it. This can either be caused by a geometry mismatch or by moving /boot/boot.b without running the map installer.
I've tried using SeaTools For DOS to limit my drive to 32GB but that didn't fix the issue. My money was bet on the hard drive being too big for the BIOS (despite the fact that the BIOS and all software recognize it PERFECTLY). I imagine it could also be the SATA->IDE adapter causing the issue. Unfortunately, I don't have any IDE drives on-hand to swap in, and it'll be a day or 2 before I can get ahold of my spare SATA drives.
Any thoughts?
So far my only successes have been Windows ME and Windows 98SE, although when I installed 98SE it failed to install whatever driver it needed to use my CD drive or my USB flash drive. WinME installed perfectly, though 😒. WinME has been pretty crash-happy so it's not exactly what I want to be using regularly on this thing.
