Reply 600 of 1037, by mastergamma12
red-ray wrote on 2020-08-23, 22:58:
mastergamma12 wrote on 2020-08-23, 21:34:
Ran SIV on the Z370 FTW, same thing as the Z370 Micro before you fixed it.
Thank you for the report and posting the files, how does the attached SIV64X 8472-03 test SIV do?
Looking at the sample counts then the SIO ones are lower than all the others, further in the save file it's reporting [Y]INUSE Wait 812 of 812 ms which usually indicates issues caused by other software.
Looks good now
file.php?mode=view&id=90646
Regarding INUSE Wait 812 of 812 ms, I think it's caused by MSI Afterburner because when I exited out of MSI Afterburner and looked at the SIO values, it was reporting as INUSE Wait 0 of 812 ms
    1.15 MiB
    SIV_BORG-CUBE.zip
    380.93 KiB
    59 downloads
The Tuala-Bus (My 9x/Dos Rig) (Pentium III-S 1.4ghz, AWE64G+Audigy 2 ZS, Voodoo5 5500, Chieftec Dragon Rambus)
The Final Lan Party (My Windows Xp/7 rig) (Core i7 980x, GTX 480,DFI Lanparty UT X58-T3eH8,)
Re: Post your 'current' PC
Reply 601 of 1037, by red-ray
mastergamma12 wrote on 2020-08-23, 23:08:
Thank you and it also looks good to be, but a screen shots once SIV has been active for >= 5 minutes are better.
Once you get INUSE Wait 812 of 812 ms then to get back to INUSE Wait 0 of 812 ms then you need to exit and restart SIV. It's possible the BIOS triggers this, what do you get if you reboot the system and only run SIV?
Reply 602 of 1037, by Idon'tfranklycare
I have tried your software on my soon to be 98 box
    166.68 KiB
    SIV_COPPER-MAN.txt
    245.19 KiB
    46 downloads
Reply 603 of 1037, by Idon'tfranklycare
Though I may make this my soon to be 98 computer
    172.6 KiB
    SIV_IRON-MAN.txt
    212.71 KiB
    47 downloads
Reply 604 of 1037, by red-ray
Idon'tfranklycare wrote on 2020-08-25, 05:37:
Welcome to the forum, thank you for checking out SIV and posting the reports. In general SIV did OK, but as usual SIV struggled with the CPU ratio on Windows 9x. Please will you try SIV32L 5.52 Beta-03 which should improve things, does it?
I can't see why SIV did not report the disk SMART information on IRON-MAN, did a panel pop up asking for a reboot and if so did you reboot? If not then doing SIV32L -DBGSDM -EXIT=30 > SIV_DBGOUT.log from an MS-DOS command window (CD to C:\SIV\) should provide some insight. This command should run SIV for 30 seconds and write all the SMART Disk Monitoring debug information to SIV_DBGOUT.log.
Reply 605 of 1037, by Idon'tfranklycare
I will test this later. I deleted the install on Copper-Man, so it will take time.
I think Iron-Man doesn't report the information as the Viper IDE controller driver I am using is preventing it.
Reply 606 of 1037, by red-ray
Idon'tfranklycare wrote on 2020-08-25, 07:44:
Chances are that if the multiplier fix works on IRON-MAN it will also work on COPPER-MAN so there is probably no need to test it on both systems. Were you to install WXP on COPPER-MAN I expect SIV wold do way better.
Could be, the SIV support for SMART on W9x is relatively new so I don't have a feel for what does and does not work. Did you get the popup about C:\Windows\system\SMARTVSD.vxd?
Reply 607 of 1037, by Idon'tfranklycare
red-ray wrote on 2020-08-25, 07:57:
Installing XP on Copper-Man caused Blue Screens during the install. I did not however try it on Iron-Man yet.
Reply 608 of 1037, by red-ray
Idon'tfranklycare wrote on 2020-08-25, 16:18:
Strange, I don't see why that would happen. Thank you for trying.
I don't recall crashes while installing XP, 2003 refused to install on my Rise mP6, but would when I changed the CPU to an AMD K6 then ran OK when I swapped back to the mP6! I wonder if 2003 would install OK on your system.
Reply 610 of 1037, by Idon'tfranklycare
I have reported back
    199.51 KiB
    SIV_IRON-MAN.rar
    135.77 KiB
    65 downloads
Reply 611 of 1037, by red-ray
Idon'tfranklycare wrote on 2020-08-27, 04:05:
Thank you, but I though you would do this on COPPER-MAN, that said I am pleased you installed 2003 on IRON-MAN as SIV did not do as well as I expected, this is mainly down to SIV not having support for the AMD-755/756 SMBus so I have added support.
Please will you re-do the save using SIV32X 5.52 Beta-04 or later. If the new code works then the [ SPD ] button should report the DIMM SPD data.
SIV was able to read the drive SMART data, so I guess it's the W98 driver that prevented this before, unfortunately the drive does not report it's temperature.
Looking in the manual I can see there is a optional hardware monitoring chip, does your board have this and if so can you see what the chip is. I don't think so as looking at https://retronn.de/imports/hwgal/hw_gigabyte_ga-7ixe4.html I think it's a W83782D and SIV did not detect one.
Reply 613 of 1037, by mastergamma12
Hey, I tried SIV64X on an MSI 880G-E45, everything seems alright except for the 5v and 12v rail and the fan names.
Fan names should be CPU Fan and SYS Fan 1 and SYS Fan 2.
file.php?mode=view&id=91086
    956.68 KiB
    SIV_MSI-880G.zip
    205.83 KiB
    52 downloads
Reply 614 of 1037, by mastergamma12
Idon'tfranklycare wrote on 2020-08-30, 01:13:
I have grave news. Both motherboards have bad caps. I must recap them.
That sucks. 🙁
Reply 615 of 1037, by red-ray
Good luck, maybe this was the root cause of the problems you had installing XP.
Reply 616 of 1037, by red-ray
mastergamma12 wrote on 2020-08-30, 04:22:
Thank you for the report and how does the attached SIV64X 7576-05 test SIV look please? If you post what the BIOS reports for the Fintek F71889F I may be able to further improve things.
BTW I noticed that the WD2500AAKS-00B3A0 is reporting a none zero Re-allocated Sector Count 🙁
Reply 617 of 1037, by mastergamma12
red-ray wrote on 2020-08-30, 06:04:
Looks good, low 12v is due to that crappy psu from earlier.
As for the hdd, it's a drive I got lying around here so not a big deal.
file.php?mode=view&id=91090
file.php?mode=view&id=91091
    SIV_MSI-880G.zip
    205.95 KiB
    50 downloads
    995.41 KiB
    640.96 KiB
Reply 618 of 1037, by red-ray
mastergamma12 wrote on 2020-08-30, 06:18:
Yep, all looks good, the changes will be in 5.52 Beta-05 which I will release in the next few days. Thank you for the BIOS screen, I was wondering if any other voltages would be reported.
Reply 619 of 1037, by mastergamma12
Tried SIV32X on an Abit KW7
Everything looks good apart from fan names, fan names should be CPUFan1,SYSFan1 and AUXFan1.
file.php?mode=view&id=91109
    886.58 KiB
    SIV_ABIT-KW7.zip
    167.31 KiB
    46 downloads
