First post, by cyclone3d
Is there any reason at all for me to keep PCI S3 Trio32 or Trio64 video cards when I also have PCI S3 Virge video cards?
Do the older cards have better compatibility or anything like that?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 1 of 9, by Joseph_Joestar
The 2D core should be the same, but Trio cards may have a slightly sharper 2D image, at least in my experience.
This could be due to the manufacturer though.
Reply 3 of 9, by chinny22
I can't really think of a reason to use a Trio over a Virge if you have both.
Maybe useful to harvest the memory to upgrade other cards (Yeh I don't like doing this either but options are limited these days)
I'd let them go if your trying to clear out excess stock.
Reply 4 of 9, by The Serpent Rider
Better performance maybe. Some original S3 Trio64 cards are very fast and can beat any typical "noname" Virge card. For example, I've recenty acquired ExpertColor DSP-3364P which is clocked at 70Mhz and it shows.
Reply 5 of 9, by dionb
Yep. Consider that the added value of the Virge was 3D acceleration and that S3D was not well supported and performed awfully...
Certainly in DOS both should perform identically at same core & RAM clocks, so whoever has higher clock should win.
Reply 6 of 9, by The Serpent Rider
Higher clocked Trio64 will perform better in Windows too. Although I know one interesting exception, which is probably tied to difference between memory bank limit of Trio64 and Virge.
Reply 7 of 9, by MKT_Gundam
I would keep the good brand ones.
I have a good collection of S3 Diamonds cards:Vision, Trio 64/+, DX, GX2 AGP, SV4 pro LT AGP, SV4 pro pci, SV2000.
I really wanted the ISA and VLB cards.
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 8 of 9, by _ar
I know it's an old thread, but I'd like to add that I have Virge cards which would refuse to boot with a Voodoo plugged in. Which is kind of a bummer provided that'd be one of the main use cases of a Virge. So yeah, keep the Trios.
Reply 9 of 9, by Postman5
Some S3 Trio cards show a true black background on LCD monitors in DOS. I would keep those cards. Most S3 and all Virge cards show a hideous gray background instead of black on LCD monitors in DOS. It seems to be a faulty black level detection in the Video BIOS, but that can be corrected, I guess?
