First post, by Falcon_H
Hello,
I have an IBM PC-XT that I installed a CF card adapter into. The floppy drive on the machine is broken, so I'm unable to install DOS conventionally. A few months ago, I was able to finally get the boot disk installed with the help of this form, but I'm stuck when it comes to installing the other two disks. I tried extracting the files from disk2, making a directory on the CF card, pasting the files in and then using the "SUBST" command to attempt to use the directory as a disk, but I got an error message. Does anyone have any ideas for getting the setup disks installed?
I'm pretty sure this is a stupid question, but is it possible to just paste the extracted files in?
Thank you for the help!
