Reply 620 of 1140, by red-ray
mastergamma12 wrote on 2020-08-30, 18:14:
Everything looks good apart from fan names, fan names should be CPUFan1,SYSFan1 and AUXFan1.
Thank you for the report, but what about the DRAM timing information?
Please try the attached SIV32X 5.52 DRAM-05 test SIV and check the DRAM timings are the same as other utilities report.
The W83627HF reports several other SIO voltages which SIV may need to report and I wonder, what does the BIOS report?
Reply 621 of 1140, by mastergamma12
red-ray wrote on 2020-08-30, 21:01:
Thank you for the report, but what about the DRAM timing information? […]
Didn't even notice the spd info was missing. Looks good now though
file.php?mode=view&id=91118
file.php?mode=view&id=91117
Reply 622 of 1140, by red-ray
mastergamma12 wrote on 2020-08-30, 21:31:
Thank you, all looks OK, but the missing information is from the chipset, SIV read the SPD OK.
As I suspected more voltages should be reported, please try the attached SIV32X 5.52 Volt-05 test SIV
Reply 623 of 1140, by mastergamma12
red-ray wrote on 2020-08-30, 23:22:
Won't be able to do any more testing on that board for a while, I put it back in storage and it'll be a PITA to get it back out anytime soon.
I did try SIV64x on the XP/Vista rig in my sig. There's a few things wrong, SMART detection issues, something at 86c, 12v not right.
file.php?mode=view&id=91183
Reply 624 of 1140, by red-ray
mastergamma12 wrote on 2020-09-01, 07:15:
OK and there is no real rush as I am 99% sure the voltages will be correct, I am adjusting the EVGA 132-YW-E179-FTW SIO reporting, as usual it would be helpful to have a screen shot of the BIOS sensor reporting.
The NVidia disk driver does not allow the standard SMART commands, have you tried enabling -SCSI mode? See Menu->Tools->Configure->SIV Configuration. If there is still no SMART see SIV support for 386/486/586 class + Alpha + PowerPC CPUs and 3dfx + XGI + old ATI + NVidia GPUs - Testing Help which says "4. If there is an issue with Disk SMART Monitoring on NT do SIV32L -DBGSDM > SIV_DBGOUT.log | more".
Update: I just spotted the memory is only running at 1.33 GHz when looking at the SPD it should be good for 1.60 GHz.
Reply 625 of 1140, by mastergamma12
red-ray wrote on 2020-09-01, 08:25:
OK and there is no real rush as I am 99% sure the voltages will be correct, I am adjusting the EVGA 132-YW-E179-FTW SIO reportin […]
Here's a bios screenshot
file.php?mode=view&id=91217
-SCSI did the trick.
As for why the ram is at 1333, I read up that having ram faster than FSB (in this case 1333) can cause data corruption on Nforce 790i.
Reply 626 of 1140, by red-ray
mastergamma12 wrote on 2020-09-01, 16:27:
Thank you, I felt I should check if there was a nForce Fan. Please try the attached SIV64X 5.52 nFRC-05 test SIV and post new save files generated after SIV has been running for >= 5 minutes so I can see how the sensor reporting does.
Reply 627 of 1140, by mastergamma12
red-ray wrote on 2020-09-01, 17:25:
Looks good now
file.php?mode=view&id=91235
Reply 628 of 1140, by red-ray
mastergamma12 wrote on 2020-09-01, 18:23:
Looks good now
Thank you and yes, looks good to me too, I wonder what will be the next system assuming there will be one.
I meant to ask, do any other utilities manage to report the Disk SMART data? I added -SCSI support back in around 2007 and recall BSOD issues with some versions of the NVidia drivers which is why you need to opt into using -SCSI mode.
Reply 629 of 1140, by mastergamma12
red-ray wrote on 2020-09-01, 18:36:
Looks good now
There might be one in a few days.
As for your second question, Aida64 reports it fine and I think Hwinfo did as well.
Reply 630 of 1140, by red-ray
mastergamma12 wrote on 2020-09-01, 18:52:
OK, I have just uploaded the SIV 5.52 Beta-05 which contains all the fixes so please update from the test SIVs.
Reply 631 of 1140, by mastergamma12
I tried SIV on a MSI B450i Gaming Plus AC. Everything looks fine other than a VCCSA voltage being shown which AMD doesn't have and no SOC voltage and the board only has 2 fan headers which are both being used atm.
file.php?mode=view&id=91448
Reply 632 of 1140, by red-ray
mastergamma12 wrote on 2020-09-04, 01:21:
Thank you for the report, I suspect VINC SIO + PW2 are the SOC, please will you post a BIOS screen shot so I can confirm this?
Reply 633 of 1140, by mastergamma12
red-ray wrote on 2020-09-04, 07:02:
Here
file.php?mode=view&id=91469
Reply 634 of 1140, by red-ray
mastergamma12 wrote on 2020-09-04, 07:07:
Here
Thank you, the attached SIV46X 5.52 7A40-06 test SIV should tidy thing up, how does it look to you please?
Reply 636 of 1140, by mastergamma12
Tried SIV on an MSI MEG X570 Ace. Looks like the same as the B450i Gaming Plus AC.
file.php?mode=view&id=91947
Here's a Bios screenshot.
file.php?mode=view&id=91948
Reply 637 of 1140, by red-ray
mastergamma12 wrote on 2020-09-10, 16:03:
Thank you. I have just uploaded SIV 5.52 Beta-07 which should do better, how does it look to you please?
Reply 639 of 1140, by Camtheman
Tested this on my IBM PS/2 Server 95/A with the following specs:
Pentium 1 @ 66mhz
16 MB RAM
IBM XGA/2 1MB Graphics
IBM SCSI-2 "Corvette"
Adlib Clone card
3Com EtherLink III MCA
Needless to say there's quite a bit missing. Can't read the bios date among many other things.
Early 90s: IBM PS/2 Server 95/A, Pentium 66, 16MB RAM, XGA-2, IBM SCSI Corvette, SCSI2SD, 3 Com EtherLink III MCA, Resound 2 AdLib MCA
Late 90s: Micron Millenia MXE, ABIT VH6-II, Coppermine 1ghz, 1024MB, Voodoo 5 5500 PCI, GUS Max 2.1, 128GB SATA PNY SSD
