Gateway roadside rust bucket.
First post, by TimWolf
Found a Gateway P5-200 in a trash heap a few weekends ago. Have been working to resurrect it. This post will be the chronicle of the endeavor. Posted some of this on FB but wanted a more permanent log.
Enjoy, if this tickles you like it does for me.
TW
Reply 1 of 37, by Miphee
Are you planning on painting it?
Reply 2 of 37, by Anonymous Coward
Nice Evergreen Spectra. Those upgrades are fetching some money these days. Is it a 333 or 400?
Reply 3 of 37, by TimWolf
Anonymous Coward wrote on 2020-09-01, 05:55:
333. How hard would it be to convert to 400 I wonder? I'm looking it over and I'm not sure if it prys up or is soldered on.
Reply 4 of 37, by TimWolf
Miphee wrote on 2020-09-01, 05:27:
Yes. I'm derusting and painting. Then creating a custom bezel.
Reply 5 of 37, by Anonymous Coward
The CPU should be in a LIF socket, and there should be a bunch of DIP switches to control the voltage and frequency. The 333 and 400 both used the same interposer.
It's a pretty nice upgrade that goes really far in the early socket5 systems. I recommend swapping in a K6+ with internal cache.
Reply 6 of 37, by Doornkaat
Lucky! That socket interposer is even one of the good ones with switching voltage converter.👌
Reply 7 of 37, by chrismeyer6
I have the 400mhz evergreen upgrade and its a great part. I've had mine since they where new I used it to upgrade my grandparents computer back in the day.
Reply 8 of 37, by Dragon Caesar
Very nice find! I also have a Spectra upgrade in my Gateway. I swapped out the K6-2 with a K6-3+ and it wasn't too difficult. Just take your time with removing the processor from the interposer and make sure the voltage jumpers are set right.
Reply 9 of 37, by TimWolf
Dragon Caesar wrote on 2020-09-01, 23:02:
Wow, didn't know it could take a 3+
I have two of the 450mhz K6-III+ units. May have to try this out.
Thanks!
Reply 10 of 37, by TimWolf
The unit was "farm fresh" upon opening. Lots and lots of dirt and rust.
Reply 11 of 37, by TimWolf
Power supply looked very rough.
Reply 12 of 37, by TimWolf
Inside the PSU.
Reply 13 of 37, by TimWolf
More pictures inside the PSU.
Reply 14 of 37, by TimWolf
Bath time for the PSU. Lots of scrubbing. Extensive pitting. Will probably paint this, and replace the decals.
Reply 15 of 37, by TimWolf
Removed the rusted transformer and rebuilt it. Required lots of rust removal, and then sealed the clean metals with clear nail enamel, and rebuilt. Replaced the fuse holders. Put new thermal paste between the heat shields. Replaced the regulator screws as needed.
Reply 16 of 37, by chrismeyer6
Nice job. I can't wait to see the finished system!!
Reply 17 of 37, by TimWolf
PSU is now tested and confirmed working. Now that it is confirmed working, I will probably replace the caps.
Reply 18 of 37, by TimWolf
The board needed a good cleaning, and all the rusty items removed.
Reply 19 of 37, by TimWolf
The motherboard cleaned up well. I need some new, less roached out i/o ports so I've used this donor board that a homeless guy gave me in exchange for giving him a ride to a convenience store. Yes, a homeless guy in a tarp tent. He had a bunch of electronics, and motherboards all over. Said he was using them to make a travel device so he could see his kids again. Most of what he gave me was in trash condition, but I did get a Banshee that was good, but that is another topic.
