Gateway roadside rust bucket.
Reply 20 of 37, by TimWolf
Put the VGA port on first just in preparation for the unit to be tested. Then followed by the regulator. A new regulator was obtained, and the heatsink was fully cleaned of rust, then sealed with clear nail enamel.
Reply 21 of 37, by TimWolf
Cleaned the ram and cache expansion. Then on to the first test. Paired the board with a known working Pentium 133mhz before trying the Spectra. That passed, so after a bit of cleanup on the Spectra K6, that unit was also tested. Both were a success.
Reply 22 of 37, by Miphee
It's good to see that it's not just the usual cleaning job but a very thorough one.
I'm always too lazy to remove brackets and connectors.
Reply 23 of 37, by darry
That is a beautiful labour of love for retro hardware . Extra points for refurbishing the PSU .
Reply 24 of 37, by TimWolf
Time to get rid of those leaky button caps. I know, I know, tantalums are evil... not anymore, they are quite good these days made with new methods.
Reply 25 of 37, by TimWolf
Did the recap, also put the keyboard/mouse block on, retested and went in to the bios. Had to pack it in for the evening so just a recapping pic for tonight.
Reply 26 of 37, by TimWolf
It does appear that the bios does not have the signature splash screen. This does however match known Gateway motherboards, the OEM version of Intel TE430VX. The bios says 1999, even though it is marked on just about every part that it was built in April 1997. Wondering if they flashed this bios, if there is any Gateway splash screen specific updated bios for it. 1.00.xx.CY1T means something, but if I don't stop researching this and go to sleep I'm going to fall out of my chair.
Also, https://www.vogonswiki.com/index.php/Intel_TE430VX says it doesn't have a gameport, but it actually does if the Vibra16c is on board. Mine had one, but was removed from corrosion and rust, and I'm waiting on the official Foxconn part to arrive in a few months with delivery powered by a slow boat crewed soley by seamen fueled by only their dreams and cold bat soup.
Thank the gods for http://www.vogonsdrivers.com/getfile.php?fileid=929 who ever maintains those archives is a saint.
G'night,
TW
Reply 27 of 37, by darry
TimWolf wrote on 2020-09-03, 03:09:
It does appear that the bios does not have the signature splash screen. This does however match known Gateway motherboards, the […]
G'night,
TW
Bat gazpacho sounds delicious . 😉 Seriously, great work !
Reply 28 of 37, by Repo Man11
Very impressive work.
Reply 29 of 37, by TheMobRules
Awesome! Very thorough job on both the power supply and the motherboard!
Looking forward to the restoration of the case. I love these types of threads.
Reply 30 of 37, by yawetaG
For what it's worth, my Gateway from much later only gained a full screen Gateway splash screen after I updated the BIOS to the latest version. The earlier BIOS merely showed a small logo on boot up in the middle of the usual boot sequence.
Reply 32 of 37, by chinny22
yawetaG wrote on 2020-09-03, 06:09:
My Slot 1 and S370 systems had both options controlled in BIOS
Full screen enabled hid post messages and showed a loading bar under the logo.
Full screen disabled had a little white box with Gateway branding along with standard post messages
After BIOS updates I think it defaulted back to full screen, but it has been 20 odd years!
And great work on the restore, I was expecting swapping out hardware from the initial pictures, but after all the work on the PSU alone this aint no typical restore!
Reply 33 of 37, by gerry
I'm enjoying this excellent resurrection, everything looks very clean in the after pics! electronics are more robust than we sometimes give them credit for
Reply 34 of 37, by Mephusto
Very awesome restoration job. I am looking forward to seeing the finished pc
Reply 35 of 37, by TimWolf
No bezel so I have to homebrew it. Thinking this nonworking dehumidifier. It was $2 (got $1 off!) at the same estate sale I got a Tandy RLX full set for $25 at.
Reply 36 of 37, by TimWolf
This is the inspiration for the case bezel design I'm working towards. It will not be identical by any means, just in mind as it is created.
