Flashback Drag N Drop
First post, by TomJeffersonJones
- Community -
I just installed dosbox .65 and am using it to run the floppy version of Flashback -
Naturally, - I've run into something i don't understand. When I run the game by starting dosbox, mounting the drive, and typing FB - The games' performance is awful - though modifying the .conf file helps and has an effect.
Ok - but if I open two explorer windows and do the drag and drop - the FB.exe onto the DosBox.exe, the game's performance is incredibly fast and smooth, in both window and fullscreen.
So while i'm not exactly having a problem -- I'd like to know why this is happening for future reference -- I know the drag n drop start method seems to bypass the .conf -- and i'd like to experiment with the scaling settings so i can try and eliminate an ugly teal border around my flashback fullscreen game window --
so...what gives?
Why is performance so much better through drag and drop?
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
try the following:
rename dosbox.conf to nothing.conf
start DOSBox from the startmenu and start FB this way.
This is what happends if you drag and drop the game. Does this make the game run smooth as well ?
Water flows down the stream
