First post, by Queen K Juul
So when I first set up my rig, I didn't really know entirely what I was doing, so I installed the retail drivers for the SBLive, and in so doing I installed the DOS drivers and the WDM drivers.
I would like to try the VXD drivers, or even the Audigy drivers as outlined here: Guide: Installing Windows 9x and DOS drivers on Sound Blaster Live! cards (version 3.1)
However, I have a strange problem. If I remove the DOS drivers, I get a BSOD on boot. I first tried using the Creative uninstaller and selecting the DOS drivers, which caused the BSOD. I restored a backup, then I tried manually commenting out the lines in autoexec.bat that load the drivers, and this also causes the BSOD. The error it gives is a VFAT initialization error, which I've seen before as something where the kernel runs out of memory before it can load the VFAT driver (which is one of the last to be loaded, apparently). If I uncomment those lines, then the system boots. But commenting out the CTSYN, BLASTER, and SBEINIT lines causes the BSOD.
What gives? What do I need to do? I want to uninstall the device completely to install new drivers but any way I try to remove the DOS drivers causes the BSOD. I know now that installing them to begin with was a mistake 🤣 but at the time I had no idea. I don't have a recent backup without them installed...in fact, I think I ran my first backup after I had the drivers installed, because I didn't think I would need to uninstall them.
Reply 2 of 8, by Jorpho
Queen K Juul wrote on 2020-09-18, 17:13:
CTSYN and BLASTER are just environment variables, aren't they? Do you still get a BSOD if you leave in those lines but comment out the SBEINIT line?
What if you leave in the SBEINIT line, but remove the card from your computer entirely?
Reply 3 of 8, by Queen K Juul
Definitely not RAM, I've tested both sticks and the machine has run rock-solid for several hours of continuous gaming
It's the SBEINIT line that's doing it. Commenting that out on its own causes the BSOD
Reply 4 of 8, by cyclone3d
That doesn't make any sense.
Maybe try remaking your autoexec.bat file from scratch. I've seen weird things happen when config.sys or autoexec.bat have either gotten corrupted or have an invisible character somewhere in the file.
Don't copy / paste any of the lines.... manually type everything in.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 5 of 8, by Queen K Juul
I did that, no dice. The only things in AUTOEXEC are the sound card lines, and then adding ATI control panel to PATH. Config.sys is even more barebones, entirely unmodified with just HIMEM and EMM386.
I rebooted with BOOTLOG.TXT, included below, but I don't see anything helpful
[0010AD5A] Loading Device = C:\WINDOWS\HIMEM.SYS [0010AD64] LoadSuccess = C:\WINDOWS\HIMEM.SYS [0010AD65] Loading Device = C: […]
[0010AD65] Loading Device = C:\WINDOWS\EMM386.EXE
[0010AD68] LoadSuccess = C:\WINDOWS\EMM386.EXE
[0010AD68] Loading Device = C:\WINDOWS\DBLBUFF.SYS
[0010AD69] LoadSuccess = C:\WINDOWS\DBLBUFF.SYS
[0010AD69] Loading Device = C:\WINDOWS\IFSHLP.SYS
[0010AD69] LoadSuccess = C:\WINDOWS\IFSHLP.SYS
[0010AE23] Loading Vxd = C:\WINDOWS\system\VMM32\VMM.VXD
[0010AE24] LoadSuccess = C:\WINDOWS\system\VMM32\VMM.VXD
[0010AE24] Loading Vxd = C:\WINDOWS\SMARTDRV.EXE
[0010AE25] LoadSuccess = C:\WINDOWS\SMARTDRV.EXE
[0010AE25] Loading Vxd = vnetsup.vxd
[0010AE25] LoadSuccess = vnetsup.vxd
[0010AE26] Loading Vxd = ndis.vxd
[0010AE26] LoadSuccess = ndis.vxd
[0010AE27] Loading Vxd = ndis2sup.vxd
[0010AE27] LoadFailed = ndis2sup.vxd
[0010AE27] Loading Vxd = JAVASUP.VXD
[0010AE27] LoadSuccess = JAVASUP.VXD
[0010AE28] Loading Vxd = C:\WINDOWS\system\VMM32\CONFIGMG.VXD
[0010AE28] LoadSuccess = C:\WINDOWS\system\VMM32\CONFIGMG.VXD
[0010AE28] Loading Vxd = C:\WINDOWS\system\VMM32\NTKERN.VXD
[0010AE29] LoadSuccess = C:\WINDOWS\system\VMM32\NTKERN.VXD
[0010AE29] Loading Vxd = VWIN32
[0010AE2A] LoadSuccess = VWIN32
[0010AE2A] Loading Vxd = VFBACKUP
[0010AE2A] LoadSuccess = VFBACKUP
[0010AE2A] Loading Vxd = C:\WINDOWS\system\VMM32\VCOMM.VXD
[0010AE2B] LoadSuccess = C:\WINDOWS\system\VMM32\VCOMM.VXD
[0010AE2B] Loading Vxd = COMBUFF
[0010AE2B] LoadSuccess = COMBUFF
[0010AE2B] Loading Vxd = C:\WINDOWS\system\VMM32\IFSMGR.VXD
[0010AE2C] LoadSuccess = C:\WINDOWS\system\VMM32\IFSMGR.VXD
[0010AE2C] Loading Vxd = C:\WINDOWS\system\VMM32\IOS.VXD
[0010AE2D] LoadSuccess = C:\WINDOWS\system\VMM32\IOS.VXD
[0010AE2D] Loading Vxd = mtrr
[0010AE2D] LoadSuccess = mtrr
[0010AE2E] Loading Vxd = SPOOLER
[0010AE2E] LoadSuccess = SPOOLER
[0010AE2E] Loading Vxd = C:\WINDOWS\system\VMM32\UDF.VXD
[0010AE2F] LoadSuccess = C:\WINDOWS\system\VMM32\UDF.VXD
[0010AE2F] Loading Vxd = C:\WINDOWS\system\VMM32\VFAT.VXD
[0010AE30] LoadSuccess = C:\WINDOWS\system\VMM32\VFAT.VXD
[0010AE30] Loading Vxd = C:\WINDOWS\system\VMM32\VCACHE.VXD
[0010AE30] LoadSuccess = C:\WINDOWS\system\VMM32\VCACHE.VXD
[0010AE30] Loading Vxd = VCOND
[0010AE30] LoadSuccess = VCOND
[0010AE31] Loading Vxd = VCDFSD
[0010AE31] LoadSuccess = VCDFSD
[0010AE31] Loading Vxd = VXDLDR
[0010AE31] LoadSuccess = VXDLDR
[0010AE31] Loading Vxd = VDEF
[0010AE32] LoadSuccess = VDEF
[0010AE32] Loading Vxd = C:\WINDOWS\system\VMM32\VPICD.VXD
[0010AE32] LoadSuccess = C:\WINDOWS\system\VMM32\VPICD.VXD
[0010AE32] Loading Vxd = VTD
[0010AE32] LoadSuccess = VTD
[0010AE33] Loading Vxd = REBOOT
[0010AE33] LoadSuccess = REBOOT
[0010AE33] Loading Vxd = VDMAD
[0010AE33] LoadSuccess = VDMAD
[0010AE33] Loading Vxd = VSD
[0010AE34] LoadSuccess = VSD
[0010AE34] Loading Vxd = V86MMGR
[0010AE34] LoadSuccess = V86MMGR
[0010AE34] Loading Vxd = PAGESWAP
[0010AE34] LoadSuccess = PAGESWAP
[0010AE35] Loading Vxd = DOSMGR
[0010AE35] LoadSuccess = DOSMGR
[0010AE35] Loading Vxd = VMPOLL
[0010AE35] LoadSuccess = VMPOLL
[0010AE35] Loading Vxd = SHELL
[0010AE36] LoadSuccess = SHELL
[0010AE36] Loading Vxd = PARITY
[0010AE36] LoadSuccess = PARITY
[0010AE36] Loading Vxd = BIOSXLAT
[0010AE36] LoadSuccess = BIOSXLAT
[0010AE37] Loading Vxd = C:\WINDOWS\system\VMM32\VMCPD.VXD
[0010AE37] LoadSuccess = C:\WINDOWS\system\VMM32\VMCPD.VXD
[0010AE37] Loading Vxd = VTDAPI
[0010AE37] LoadSuccess = VTDAPI
[0010AE38] Loading Vxd = PERF
[0010AE38] LoadSuccess = PERF
[0010AE38] Loading Vxd = C:\WINDOWS\SYSTEM\vrtwd.386
[0010AE39] LoadSuccess = C:\WINDOWS\SYSTEM\vrtwd.386
[0010AE39] Loading Vxd = C:\WINDOWS\SYSTEM\vfixd.vxd
[0010AE39] LoadSuccess = C:\WINDOWS\SYSTEM\vfixd.vxd
[0010AE3A] Loading Vxd = vnetbios.vxd
[0010AE3A] LoadSuccess = vnetbios.vxd
[0010AE3B] Loading Vxd = ndiswan.vxd
[0010AE3B] LoadSuccess = ndiswan.vxd
[0010AE3B] Loading Vxd = vredir.vxd
[0010AE3C] LoadSuccess = vredir.vxd
[0010AE3C] Loading Vxd = dfs.vxd
[0010AE3C] LoadSuccess = dfs.vxd
[0010AE3D] Loading Vxd = PNPHLP.VXD
[0010AE3D] LoadSuccess = PNPHLP.VXD
[0010AE3E] Loading Vxd = vserver.vxd
[0010AE3E] Skipped (not needed) = vserver.vxd
[0010AE3F] Loading Vxd = KEYREMAP.VXD
[0010AE3F] LoadSuccess = KEYREMAP.VXD
[0010AE3F] Loading Vxd = ebios
[0010AE3F] LoadSuccess = ebios
[0010AE3F] Loading Vxd = C:\WINDOWS\system\VMM32\vmouse.VXD
[0010AE40] LoadSuccess = C:\WINDOWS\system\VMM32\vmouse.VXD
[0010AE40] Loading Vxd = msmouse.vxd
[0010AE40] LoadSuccess = msmouse.vxd
[0010AE40] Loading Vxd = dynapage
[0010AE41] LoadSuccess = dynapage
[0010AE41] Loading Vxd = vcd
[0010AE41] LoadSuccess = vcd
[0010AE41] Loading Vxd = vpd
[0010AE41] LoadSuccess = vpd
[0010AE42] Loading Vxd = int13
[0010AE42] LoadSuccess = int13
[0010AE42] Loading Vxd = enable
[0010AE42] LoadSuccess = enable
[0010AE42] Loading Vxd = vkd
[0010AE43] LoadSuccess = vkd
[0010AE43] Loading Vxd = vdd
[0010AE43] LoadSuccess = vdd
[0010AE43] Loading Vxd = vflatd
[0010AE44] LoadSuccess = vflatd
[0010AE44] Loading Vxd = convmem.vxd
[0010AE44] LoadSuccess = convmem.vxd
[0010AE46] SYSCRITINIT = VMM
[0010AE46] SYSCRITINITSUCCESS = VMM
[0010AE46] SYSCRITINIT = MTRR
[0010AE46] SYSCRITINITSUCCESS = MTRR
[0010AE46] SYSCRITINIT = VCACHE
[0010AE47] SYSCRITINITSUCCESS = VCACHE
[0010AE47] SYSCRITINIT = DFS
[0010AE47] SYSCRITINITSUCCESS = DFS
[0010AE47] SYSCRITINIT = PERF
[0010AE47] SYSCRITINITSUCCESS = PERF
[0010AE47] SYSCRITINIT = VFIXD
[0010AE48] SYSCRITINITSUCCESS = VFIXD
[0010AE48] SYSCRITINIT = CONVMEM
[0010AE48] SYSCRITINITSUCCESS = CONVMEM
[0010AE48] SYSCRITINIT = VPICD
[0010AE48] SYSCRITINITSUCCESS = VPICD
[0010AE49] SYSCRITINIT = VrtwD
[0010AE49] SYSCRITINITSUCCESS = VrtwD
[0010AE49] SYSCRITINIT = VTD
[0010AE49] SYSCRITINITSUCCESS = VTD
[0010AE49] SYSCRITINIT = VWIN32
[0010AE4A] SYSCRITINITSUCCESS = VWIN32
[0010AE4A] SYSCRITINIT = VXDLDR
[0010AE4A] SYSCRITINITSUCCESS = VXDLDR
[0010AE4A] SYSCRITINIT = NTKERN
[0010AE4A] SYSCRITINITSUCCESS = NTKERN
[0010AE4B] SYSCRITINIT = PNPHLP
[0010AE4B] SYSCRITINITSUCCESS = PNPHLP
[0010AE4B] SYSCRITINIT = CONFIGMG
[0010AE4B] SYSCRITINITSUCCESS = CONFIGMG
[0010AE4B] SYSCRITINIT = VCDFSD
[0010AE4B] SYSCRITINITSUCCESS = VCDFSD
[0010AE4C] SYSCRITINIT = IOS
[0010AE4C] SYSCRITINITSUCCESS = IOS
[0010AE4C] SYSCRITINIT = PAGEFILE
[0010AE4C] SYSCRITINITSUCCESS = PAGEFILE
[0010AE4D] SYSCRITINIT = PAGESWAP
[0010AE4D] SYSCRITINITSUCCESS = PAGESWAP
[0010AE4D] SYSCRITINIT = PARITY
[0010AE4D] SYSCRITINITSUCCESS = PARITY
[0010AE4D] SYSCRITINIT = REBOOT
[0010AE4D] SYSCRITINITSUCCESS = REBOOT
[0010AE4E] SYSCRITINIT = EBIOS
[0010AE4E] SYSCRITINITSUCCESS = EBIOS
[0010AE4E] SYSCRITINIT = VDD
[0010AE4E] SYSCRITINITSUCCESS = VDD
[0010AE4E] SYSCRITINIT = VSD
[0010AE4F] SYSCRITINITSUCCESS = VSD
[0010AE4F] SYSCRITINIT = COMBUFF
[0010AE4F] SYSCRITINITSUCCESS = COMBUFF
[0010AE4F] SYSCRITINIT = VCD
[0010AE50] SYSCRITINITSUCCESS = VCD
[0010AE50] SYSCRITINIT = VMOUSE
[0010AE50] SYSCRITINITSUCCESS = VMOUSE
[0010AE50] SYSCRITINIT = MSMINI
[0010AE50] SYSCRITINITSUCCESS = MSMINI
[0010AE50] SYSCRITINIT = ENABLE
[0010AE50] SYSCRITINITSUCCESS = ENABLE
[0010AE51] SYSCRITINIT = VKD
[0010AE51] SYSCRITINITSUCCESS = VKD
[0010AE51] SYSCRITINIT = VPD
[0010AE51] SYSCRITINITSUCCESS = VPD
[0010AE52] SYSCRITINIT = INT13
[0010AE52] SYSCRITINITSUCCESS = INT13
[0010AE52] SYSCRITINIT = VMCPD
[0010AE52] SYSCRITINITSUCCESS = VMCPD
[0010AE52] SYSCRITINIT = BIOSXLAT
[0010AE53] SYSCRITINITSUCCESS = BIOSXLAT
[0010AE53] SYSCRITINIT = SDVXD
[0010AE53] SYSCRITINITSUCCESS = SDVXD
[0010AE54] SYSCRITINIT = VNETBIOS
[0010AE54] SYSCRITINITSUCCESS = VNETBIOS
[0010AE54] SYSCRITINIT = NDIS
[0010AE54] SYSCRITINITSUCCESS = NDIS
[0010AE54] SYSCRITINIT = NDISWAN
[0010AE54] SYSCRITINITSUCCESS = NDISWAN
[0010AE55] SYSCRITINIT = DOSMGR
[0010AE55] SYSCRITINITSUCCESS = DOSMGR
[0010AE55] SYSCRITINIT = VMPOLL
[0010AE56] SYSCRITINITSUCCESS = VMPOLL
[0010AE56] SYSCRITINIT = JAVASUP
[0010AE56] SYSCRITINITSUCCESS = JAVASUP
[0010AE56] SYSCRITINIT = VCOMM
[0010AE57] SYSCRITINITSUCCESS = VCOMM
[0010AE57] SYSCRITINIT = VCOND
[0010AE57] SYSCRITINITSUCCESS = VCOND
[0010AE57] SYSCRITINIT = VTDAPI
[0010AE57] SYSCRITINITSUCCESS = VTDAPI
[0010AE57] SYSCRITINIT = KEYREMAP
[0010AE57] SYSCRITINITSUCCESS = KEYREMAP
[0010AE58] SYSCRITINIT = VFLATD
[0010AE58] SYSCRITINITSUCCESS = VFLATD
[0010AE58] SYSCRITINIT = VDMAD
[0010AE58] SYSCRITINITSUCCESS = VDMAD
[0010AE59] SYSCRITINIT = V86MMGR
[0010AE59] SYSCRITINITSUCCESS = V86MMGR
[0010AE59] SYSCRITINIT = SPOOLER
[0010AE59] SYSCRITINITSUCCESS = SPOOLER
[0010AE59] SYSCRITINIT = UDF
[0010AE59] SYSCRITINITSUCCESS = UDF
[0010AE5A] SYSCRITINIT = VFAT
[0010AE5A] SYSCRITINITSUCCESS = VFAT
[0010AE5A] SYSCRITINIT = VDEF
[0010AE5A] SYSCRITINITSUCCESS = VDEF
[0010AE5A] SYSCRITINIT = IFSMGR
[0010AE5B] SYSCRITINITSUCCESS = IFSMGR
[0010AE5B] SYSCRITINIT = VNETSUP
[0010AE5B] SYSCRITINITSUCCESS = VNETSUP
[0010AE5B] SYSCRITINIT = VREDIR
[0010AE5B] SYSCRITINITSUCCESS = VREDIR
[0010AE5B] SYSCRITINIT = VFBACKUP
[0010AE5C] SYSCRITINITSUCCESS = VFBACKUP
[0010AE5C] SYSCRITINIT = SHELL
[0010AE5C] SYSCRITINITSUCCESS = SHELL
[0010AE5C] DEVICEINIT = VMM
[0010AE5D] DEVICEINITSUCCESS = VMM
[0010AE5D] DEVICEINIT = MTRR
[0010AE5D] DEVICEINITSUCCESS = MTRR
[0010AE5D] DEVICEINIT = VCACHE
[0010AE5D] DEVICEINITSUCCESS = VCACHE
[0010AE5E] DEVICEINIT = DFS
[0010AE5F] DEVICEINITSUCCESS = DFS
[0010AE5F] DEVICEINIT = PERF
[0010AE5F] DEVICEINITSUCCESS = PERF
[0010AE5F] DEVICEINIT = VFIXD
[0010AE60] DEVICEINITSUCCESS = VFIXD
[0010AE60] DEVICEINIT = CONVMEM
[0010AE60] DEVICEINITSUCCESS = CONVMEM
[0010AE60] DEVICEINIT = VPICD
[0010AE60] DEVICEINITSUCCESS = VPICD
[0010AE61] DEVICEINIT = VrtwD
[0010AE61] DEVICEINITSUCCESS = VrtwD
[0010AE61] DEVICEINIT = VTD
[0010AE61] DEVICEINITSUCCESS = VTD
[0010AE61] DEVICEINIT = VWIN32
[0010AE62] DEVICEINITSUCCESS = VWIN32
[0010AE62] DEVICEINIT = VXDLDR
[0010AE62] DEVICEINITSUCCESS = VXDLDR
[0010AE62] DEVICEINIT = NTKERN
[0010AE63] DEVICEINITSUCCESS = NTKERN
[0010AE63] DEVICEINIT = PNPHLP
[0010AE64] DEVICEINITSUCCESS = PNPHLP
[0010AE64] DEVICEINIT = CONFIGMG
[0010AE64] Starting Unknown (HTREE\ROOT\0)
[0010AE64] Started Unknown (HTREE\ROOT\0)
[0010AE64] Enumerating Unknown (HTREE\ROOT\0)
[0010AE65] Enumerated Unknown (HTREE\ROOT\0)
[0010AE65] Starting Unknown (HTREE\RESERVED\0)
[0010AE65] Started Unknown (HTREE\RESERVED\0)
[0010AE65] Enumerating Unknown (HTREE\RESERVED\0)
[0010AE65] Enumerated Unknown (HTREE\RESERVED\0)
[0010AE66] Loading PNP drivers of Dial-Up Adapter (ROOT\NET\0001)
[0010AE66] Loading PNP drivers of Dial-Up Adapter #2 (VPN Support) (ROOT\NET\0002)
[0010AE66] Loading PNP drivers of Microsoft Virtual Private Networking Adapter (ROOT\NET\0003)
[0010AE66] Loading PNP drivers of Processor support (ROOT\PROCESSOR_UPDATE\0000)
[0010AE67] Loaded PNP drivers of Processor support (ROOT\PROCESSOR_UPDATE\0000)
[0010AE67] Starting Processor support (ROOT\PROCESSOR_UPDATE\0000)
[0010AE67] Started Processor support (ROOT\PROCESSOR_UPDATE\0000)
[0010AE67] Loading PNP drivers of Plug and Play Software Device Enumerator (ROOT\SWENUM\0000)
[0010AE68] Loaded PNP drivers of Plug and Play Software Device Enumerator (ROOT\SWENUM\0000)
[0010AE69] Starting Plug and Play Software Device Enumerator (ROOT\SWENUM\0000)
[0010AE69] Started Plug and Play Software Device Enumerator (ROOT\SWENUM\0000)
[0010AE69] Loading PNP drivers of Advanced Configuration and Power Interface (ACPI) BIOS (ROOT\*PNP0C08\0000)
[0010AE6A] Dynamic load device PCI.VXD
[0010AE6A] Dynamic init device PCI
[0010AE6A] Dynamic init success PCI
[0010AE6B] Dynamic load success PCI.VXD
[0010AE6B] Starting Advanced Configuration and Power Interface (ACPI) BIOS (ROOT\*PNP0C08\0000)
[0010AE6B] Started Advanced Configuration and Power Interface (ACPI) BIOS (ROOT\*PNP0C08\0000)
[0010AE6C] Loaded PNP drivers of Advanced Configuration and Power Interface (ACPI) BIOS (ROOT\*PNP0C08\0000)
[0010AE6C] Loading PNP drivers of System board (ROOT\*PNP0C01\0000)
[0010AE6C] Loaded PNP drivers of System board (ROOT\*PNP0C01\0000)
[0010AE6C] Starting System board (ROOT\*PNP0C01\0000)
[0010AE6C] Started System board (ROOT\*PNP0C01\0000)
[0010AE6D] Enumerating System board (ROOT\*PNP0C01\0000)
[0010AE6D] Enumerated System board (ROOT\*PNP0C01\0000)
[0010AE6D] Loading PNP drivers of PnP BIOS Extension (ROOT\D347BUS\0000)
[0010AE6E] Loaded PNP drivers of PnP BIOS Extension (ROOT\D347BUS\0000)
[0010AE70] Starting PnP BIOS Extension (ROOT\D347BUS\0000)
[0010AE70] Started PnP BIOS Extension (ROOT\D347BUS\0000)
[0010AE70] Enumerating Processor support (ROOT\PROCESSOR_UPDATE\0000)
[0010AE71] Enumerated Processor support (ROOT\PROCESSOR_UPDATE\0000)
[0010AE71] Enumerating Plug and Play Software Device Enumerator (ROOT\SWENUM\0000)
[0010AE71] Enumerated Plug and Play Software Device Enumerator (ROOT\SWENUM\0000)
[0010AE71] Enumerating Advanced Configuration and Power Interface (ACPI) BIOS (ROOT\*PNP0C08\0000)
[0010AE72] Starting SCI IRQ used by ACPI bus (ACPI\ACPI_INTERRUPT\0)
[0010AE72] Started SCI IRQ used by ACPI bus (ACPI\ACPI_INTERRUPT\0)
[0010AE72] Enumerating SCI IRQ used by ACPI bus (ACPI\ACPI_INTERRUPT\0)
[0010AE72] Enumerated SCI IRQ used by ACPI bus (ACPI\ACPI_INTERRUPT\0)
[0010AE73] Dynamic load device VPOWERD.VXD
[0010AE73] Dynamic init device VPOWERD
[0010AE73] Dynamic init success VPOWERD
[0010AE74] Dynamic load success VPOWERD.VXD
[0010AE74] Enumerated Advanced Configuration and Power Interface (ACPI) BIOS (ROOT\*PNP0C08\0000)
[0010AE74] Enumerating SCI IRQ used by ACPI bus (ACPI\ACPI_INTERRUPT\0)
[0010AE75] Enumerated SCI IRQ used by ACPI bus (ACPI\ACPI_INTERRUPT\0)
[0010AE75] Loading PNP drivers of Composite Power Source (ACPI\COMPBATT\ROOT&*PNP0C08&0000)
[0010AE75] Loaded PNP drivers of Composite Power Source (ACPI\COMPBATT\ROOT&*PNP0C08&0000)
[0010AE76] Starting Composite Power Source (ACPI\COMPBATT\ROOT&*PNP0C08&0000)
[0010AE76] Started Composite Power Source (ACPI\COMPBATT\ROOT&*PNP0C08&0000)
[0010AE76] Loading PNP drivers of ACPI System Button (ACPI\BUTTON\ROOT&*PNP0C08&0000)
[0010AE76] Loaded PNP drivers of ACPI System Button (ACPI\BUTTON\ROOT&*PNP0C08&0000)
[0010AE77] Starting ACPI System Button (ACPI\BUTTON\ROOT&*PNP0C08&0000)
[0010AE77] Started ACPI System Button (ACPI\BUTTON\ROOT&*PNP0C08&0000)
[0010AE78] Starting ACPI Power Button (ACPI\*PNP0C0C\0)
[0010AE78] Started ACPI Power Button (ACPI\*PNP0C0C\0)
[0010AE78] Enumerating ACPI Power Button (ACPI\*PNP0C0C\0)
[0010AE78] Enumerated ACPI Power Button (ACPI\*PNP0C0C\0)
[0010AE79] Loading PNP drivers of PCI bus (ACPI\*PNP0A03\0)
[0010AE79] Dynamic load device pci.vxd
[0010AE79] Dynamic init device PCI
[0010AE79] Dynamic init success PCI
[0010AE7A] Dynamic load success pci.vxd
[0010AE7A] Starting PCI bus (ACPI\*PNP0A03\0)
[0010AE7A] Started PCI bus (ACPI\*PNP0A03\0)
[0010AE7A] Enumerating PCI bus (ACPI\*PNP0A03\0)
[0010AE7B] Starting Intel(R) 82815 Processor to AGP Controller - 1131 (PCI\VEN_8086&DEV_1131&SUBSYS_00000000&REV_02\BUS_00&DEV_01&FUNC_00)
[0010AE7B] Started Intel(R) 82815 Processor to AGP Controller - 1131 (PCI\VEN_8086&DEV_1131&SUBSYS_00000000&REV_02\BUS_00&DEV_01&FUNC_00)
[0010AE7B] Enumerating Intel(R) 82815 Processor to AGP Controller - 1131 (PCI\VEN_8086&DEV_1131&SUBSYS_00000000&REV_02\BUS_00&DEV_01&FUNC_00)
[0010AE7C] Enumerated Intel(R) 82815 Processor to AGP Controller - 1131 (PCI\VEN_8086&DEV_1131&SUBSYS_00000000&REV_02\BUS_00&DEV_01&FUNC_00)
[0010AE7C] Starting Intel(R) 82801BA PCI Bridge - 244E (PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_01\BUS_00&DEV_1E&FUNC_00)
[0010AE7C] Started Intel(R) 82801BA PCI Bridge - 244E (PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_01\BUS_00&DEV_1E&FUNC_00)
[0010AE7D] Enumerating Intel(R) 82801BA PCI Bridge - 244E (PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_01\BUS_00&DEV_1E&FUNC_00)
[0010AE7D] Enumerated Intel(R) 82801BA PCI Bridge - 244E (PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_01\BUS_00&DEV_1E&FUNC_00)
[0010AE7D] Enumerated PCI bus (ACPI\*PNP0A03\0)
[0010AE7D] Loading PNP drivers of Intel(R) 82801BA LPC Interface Controller - 2440 (PCI\VEN_8086&DEV_2440&SUBSYS_00000000&REV_01\BUS_00&DEV_1F&FUNC_00)
[0010AE7E] Dynamic load device isapnp.vxd
[0010AE7E] Dynamic init device ISAPNP
[0010AE7E] Dynamic init success ISAPNP
[0010AE7E] Dynamic load success isapnp.vxd
[0010AE7F] Starting Intel(R) 82801BA LPC Interface Controller - 2440 (PCI\VEN_8086&DEV_2440&SUBSYS_00000000&REV_01\BUS_00&DEV_1F&FUNC_00)
[0010AE7F] Started Intel(R) 82801BA LPC Interface Controller - 2440 (PCI\VEN_8086&DEV_2440&SUBSYS_00000000&REV_01\BUS_00&DEV_1F&FUNC_00)
[0010AE7F] Enumerating Intel(R) 82801BA LPC Interface Controller - 2440 (PCI\VEN_8086&DEV_2440&SUBSYS_00000000&REV_01\BUS_00&DEV_1F&FUNC_00)
[0010AE7F] Starting IO read data port for ISA Plug and Play enumerator (ISAPNP\READDATAPORT\0)
[0010AE80] Started IO read data port for ISA Plug and Play enumerator (ISAPNP\READDATAPORT\0)
[0010AE80] Enumerating IO read data port for ISA Plug and Play enumerator (ISAPNP\READDATAPORT\0)
[0010AE80] Enumerated IO read data port for ISA Plug and Play enumerator (ISAPNP\READDATAPORT\0)
[0010AE80] Enumerated Intel(R) 82801BA LPC Interface Controller - 2440 (PCI\VEN_8086&DEV_2440&SUBSYS_00000000&REV_01\BUS_00&DEV_1F&FUNC_00)
[0010AE82] Loaded PNP drivers of Intel(R) 82801BA LPC Interface Controller - 2440 (PCI\VEN_8086&DEV_2440&SUBSYS_00000000&REV_01\BUS_00&DEV_1F&FUNC_00)
[0010AE82] Loaded PNP drivers of PCI bus (ACPI\*PNP0A03\0)
[0010AE83] Starting Motherboard resources (ACPI\*PNP0C02\0)
[0010AE83] Started Motherboard resources (ACPI\*PNP0C02\0)
[0010AE83] Enumerating Motherboard resources (ACPI\*PNP0C02\0)
[0010AE83] Enumerated Motherboard resources (ACPI\*PNP0C02\0)
[0010AE84] Starting Programmable interrupt controller (ACPI\*PNP0000\0)
[0010AE84] Started Programmable interrupt controller (ACPI\*PNP0000\0)
[0010AE84] Enumerating Programmable interrupt controller (ACPI\*PNP0000\0)
[0010AE84] Enumerated Programmable interrupt controller (ACPI\*PNP0000\0)
[0010AE85] Loading PNP drivers of Direct memory access controller (ACPI\*PNP0200\0)
[0010AE85] Loaded PNP drivers of Direct memory access controller (ACPI\*PNP0200\0)
[0010AE85] Starting Direct memory access controller (ACPI\*PNP0200\0)
[0010AE85] Started Direct memory access controller (ACPI\*PNP0200\0)
[0010AE86] Enumerating Direct memory access controller (ACPI\*PNP0200\0)
[0010AE86] Enumerated Direct memory access controller (ACPI\*PNP0200\0)
[0010AE86] Loading PNP drivers of System timer (ACPI\*PNP0100\0)
[0010AE86] Loaded PNP drivers of System timer (ACPI\*PNP0100\0)
[0010AE87] Starting System timer (ACPI\*PNP0100\0)
[0010AE87] Started System timer (ACPI\*PNP0100\0)
[0010AE87] Enumerating System timer (ACPI\*PNP0100\0)
[0010AE87] Enumerated System timer (ACPI\*PNP0100\0)
[0010AE88] Loading PNP drivers of System CMOS/real time clock (ACPI\*PNP0B00\0)
[0010AE88] Loaded PNP drivers of System CMOS/real time clock (ACPI\*PNP0B00\0)
[0010AE88] Starting System CMOS/real time clock (ACPI\*PNP0B00\0)
[0010AE88] Started System CMOS/real time clock (ACPI\*PNP0B00\0)
[0010AE88] Enumerating System CMOS/real time clock (ACPI\*PNP0B00\0)
[0010AE89] Enumerated System CMOS/real time clock (ACPI\*PNP0B00\0)
[0010AE89] Loading PNP drivers of System speaker (ACPI\*PNP0800\0)
[0010AE89] Loaded PNP drivers of System speaker (ACPI\*PNP0800\0)
[0010AE89] Starting System speaker (ACPI\*PNP0800\0)
[0010AE8A] Started System speaker (ACPI\*PNP0800\0)
[0010AE8A] Enumerating System speaker (ACPI\*PNP0800\0)
[0010AE8A] Enumerated System speaker (ACPI\*PNP0800\0)
[0010AE8A] Loading PNP drivers of Numeric data processor (ACPI\*PNP0C04\0)
[0010AE8A] Loaded PNP drivers of Numeric data processor (ACPI\*PNP0C04\0)
[0010AE8B] Starting Numeric data processor (ACPI\*PNP0C04\0)
[0010AE8B] Started Numeric data processor (ACPI\*PNP0C04\0)
[0010AE8C] Enumerating Numeric data processor (ACPI\*PNP0C04\0)
[0010AE8C] Enumerated Numeric data processor (ACPI\*PNP0C04\0)
[0010AE8C] Loading PNP drivers of Microsoft PS/2 Port Mouse (ACPI\*PNP0F03\0)
[0010AE8C] Loading PNP drivers of Standard 101/102-Key or Microsoft Natural Keyboard (ACPI\*PNP0303\0)
[0010AE8D] Loaded PNP drivers of Standard 101/102-Key or Microsoft Natural Keyboard (ACPI\*PNP0303\0)
[0010AE8D] Starting Standard 101/102-Key or Microsoft Natural Keyboard (ACPI\*PNP0303\0)
[0010AE8D] Started Standard 101/102-Key or Microsoft Natural Keyboard (ACPI\*PNP0303\0)
[0010AE8D] Starting Intel(r) 82802 Firmware Hub Device (ACPI\*INT0800\0)
[0010AE8E] Started Intel(r) 82802 Firmware Hub Device (ACPI\*INT0800\0)
[0010AE8E] Enumerating Intel(r) 82802 Firmware Hub Device (ACPI\*INT0800\0)
[0010AE8E] Enumerated Intel(r) 82802 Firmware Hub Device (ACPI\*INT0800\0)
[0010AE8E] Loading PNP drivers of System board extension for ACPI BIOS (ACPI\*PNP0C01\00000001)
[0010AE8F] Loaded PNP drivers of System board extension for ACPI BIOS (ACPI\*PNP0C01\00000001)
[0010AE8F] Starting System board extension for ACPI BIOS (ACPI\*PNP0C01\00000001)
[0010AE8F] Started System board extension for ACPI BIOS (ACPI\*PNP0C01\00000001)
[0010AE8F] Enumerating System board extension for ACPI BIOS (ACPI\*PNP0C01\00000001)
[0010AE90] Enumerated System board extension for ACPI BIOS (ACPI\*PNP0C01\00000001)
[0010AE90] Enumerating PnP BIOS Extension (ROOT\D347BUS\0000)
[0010AE90] Enumerated PnP BIOS Extension (ROOT\D347BUS\0000)
[0010AE90] Loading PNP drivers of D347PRT SCSI Controller (PCI\D347PRT&0&0&0\0000)
[0010AE90] Enumerating Composite Power Source (ACPI\COMPBATT\ROOT&*PNP0C08&0000)
[0010AE91] Enumerated Composite Power Source (ACPI\COMPBATT\ROOT&*PNP0C08&0000)
[0010AE91] Enumerating ACPI System Button (ACPI\BUTTON\ROOT&*PNP0C08&0000)
[0010AE91] Enumerated ACPI System Button (ACPI\BUTTON\ROOT&*PNP0C08&0000)
[0010AE91] Enumerating Standard 101/102-Key or Microsoft Natural Keyboard (ACPI\*PNP0303\0)
[0010AE92] Enumerated Standard 101/102-Key or Microsoft Natural Keyboard (ACPI\*PNP0303\0)
[0010AE92] DEVICEINITSUCCESS = CONFIGMG
[0010AE92] Loading PNP drivers of Standard Floppy Disk Controller (ACPI\*PNP0700\0)
[0010AE92] Loading PNP drivers of Communications Port (COM1) (ACPI\*PNP0501\00000001)
[0010AE92] Loaded PNP drivers of Communications Port (COM1) (ACPI\*PNP0501\00000001)
[0010AE93] Starting Communications Port (COM1) (ACPI\*PNP0501\00000001)
[0010AE93] Started Communications Port (COM1) (ACPI\*PNP0501\00000001)
[0010AE93] Loading PNP drivers of Printer Port (LPT1) (ACPI\*PNP0400\0)
[0010AE94] Loaded PNP drivers of Printer Port (LPT1) (ACPI\*PNP0400\0)
[0010AE94] Starting Printer Port (LPT1) (ACPI\*PNP0400\0)
[0010AE94] Started Printer Port (LPT1) (ACPI\*PNP0400\0)
[0010AE94] Loading PNP drivers of ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000001)
[0010AE94] Dynamic load device PCI.VxD
[0010AE95] Dynamic init device PCI
[0010AE95] Dynamic init success PCI
[0010AE95] Dynamic load success PCI.VxD
[0010AE95] Loaded PNP drivers of ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000001)
[0010AE96] Starting ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000001)
[0010AE96] Started ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000001)
[0010AE96] Enumerating ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000001)
[0010AE96] Enumerated ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000001)
[0010AE97] Loading PNP drivers of ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000002)
[0010AE97] Dynamic load device PCI.VxD
[0010AE97] Dynamic init device PCI
[0010AE97] Dynamic init success PCI
[0010AE98] Dynamic load success PCI.VxD
[0010AE98] Loaded PNP drivers of ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000002)
[0010AE98] Starting ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000002)
[0010AEA1] Started ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000002)
[0010AEA2] Enumerating ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000002)
[0010AEA2] Enumerated ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000002)
[0010AEA2] Loading PNP drivers of ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000003)
[0010AEA2] Dynamic load device PCI.VxD
[0010AEA2] Dynamic init device PCI
[0010AEA3] Dynamic init success PCI
[0010AEA3] Dynamic load success PCI.VxD
[0010AEA3] Loaded PNP drivers of ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000003)
[0010AEA3] Loading PNP drivers of ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000004)
[0010AEA3] Dynamic load device PCI.VxD
[0010AEA4] Dynamic init device PCI
[0010AEA4] Dynamic init success PCI
[0010AEA4] Dynamic load success PCI.VxD
[0010AEA4] Loaded PNP drivers of ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000004)
[0010AEA4] Starting ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000004)
[0010AEA5] Started ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000004)
[0010AEA5] Enumerating ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000004)
[0010AEA5] Enumerated ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000004)
[0010AEA5] Loading PNP drivers of ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000006)
[0010AEA5] Dynamic load device PCI.VxD
[0010AEA6] Dynamic init device PCI
[0010AEA6] Dynamic init success PCI
[0010AEA6] Dynamic load success PCI.VxD
[0010AEA6] Loaded PNP drivers of ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000006)
[0010AEA6] Starting ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000006)
[0010AEA7] Started ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000006)
[0010AEA7] Enumerating ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000006)
[0010AEA7] Enumerated ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000006)
[0010AEA7] Loading PNP drivers of ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000008)
[0010AEA7] Dynamic load device PCI.VxD
[0010AEA8] Dynamic init device PCI
[0010AEA8] Dynamic init success PCI
[0010AEA8] Dynamic load success PCI.VxD
[0010AEA8] Loaded PNP drivers of ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000008)
[0010AEA8] Starting ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000008)
[0010AEA9] Started ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000008)
[0010AEA9] Enumerating ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000008)
[0010AEA9] Enumerated ACPI IRQ Holder for PCI IRQ Steering (ACPI\*PNP0C0F\00000008)
[0010AEA9] Starting Intel(R) 82815 Processor to I/O Controller - 1130 (PCI\VEN_8086&DEV_1130&SUBSYS_00000000&REV_02\BUS_00&DEV_00&FUNC_00)
[0010AEA9] Started Intel(R) 82815 Processor to I/O Controller - 1130 (PCI\VEN_8086&DEV_1130&SUBSYS_00000000&REV_02\BUS_00&DEV_00&FUNC_00)
[0010AEAA] Enumerating Intel(R) 82815 Processor to I/O Controller - 1130 (PCI\VEN_8086&DEV_1130&SUBSYS_00000000&REV_02\BUS_00&DEV_00&FUNC_00)
[0010AEAA] Enumerated Intel(R) 82815 Processor to I/O Controller - 1130 (PCI\VEN_8086&DEV_1130&SUBSYS_00000000&REV_02\BUS_00&DEV_00&FUNC_00)
[0010AEAA] Loading PNP drivers of Intel(R) 82801BA Ultra ATA Storage Controller - 244B (PCI\VEN_8086&DEV_244B&SUBSYS_45418086&REV_01\BUS_00&DEV_1F&FUNC_01)
[0010AEAA] Loaded PNP drivers of Intel(R) 82801BA Ultra ATA Storage Controller - 244B (PCI\VEN_8086&DEV_244B&SUBSYS_45418086&REV_01\BUS_00&DEV_1F&FUNC_01)
[0010AEAA] Starting Intel(R) 82801BA Ultra ATA Storage Controller - 244B (PCI\VEN_8086&DEV_244B&SUBSYS_45418086&REV_01\BUS_00&DEV_1F&FUNC_01)
[0010AEAA] Started Intel(R) 82801BA Ultra ATA Storage Controller - 244B (PCI\VEN_8086&DEV_244B&SUBSYS_45418086&REV_01\BUS_00&DEV_1F&FUNC_01)
[0010AEAB] Enumerating Intel(R) 82801BA Ultra ATA Storage Controller - 244B (PCI\VEN_8086&DEV_244B&SUBSYS_45418086&REV_01\BUS_00&DEV_1F&FUNC_01)
[0010AEAB] Enumerated Intel(R) 82801BA Ultra ATA Storage Controller - 244B (PCI\VEN_8086&DEV_244B&SUBSYS_45418086&REV_01\BUS_00&DEV_1F&FUNC_01)
[0010AEAC] Loading PNP drivers of Intel(R) 82801BA/BAM USB Universal Host Controller - 2442 (PCI\VEN_8086&DEV_2442&SUBSYS_45418086&REV_01\BUS_00&DEV_1F&FUNC_02)
[0010AEAC] Loaded PNP drivers of Intel(R) 82801BA/BAM USB Universal Host Controller - 2442 (PCI\VEN_8086&DEV_2442&SUBSYS_45418086&REV_01\BUS_00&DEV_1F&FUNC_02)
[0010AEAD] Starting Intel(R) 82801BA/BAM USB Universal Host Controller - 2442 (PCI\VEN_8086&DEV_2442&SUBSYS_45418086&REV_01\BUS_00&DEV_1F&FUNC_02)
[0010AEAD] Started Intel(R) 82801BA/BAM USB Universal Host Controller - 2442 (PCI\VEN_8086&DEV_2442&SUBSYS_45418086&REV_01\BUS_00&DEV_1F&FUNC_02)
[0010AEAE] Starting Intel(R) 82801BA/BAM SMBus Controller - 2443 (PCI\VEN_8086&DEV_2443&SUBSYS_45418086&REV_01\BUS_00&DEV_1F&FUNC_03)
[0010AEAE] Started Intel(R) 82801BA/BAM SMBus Controller - 2443 (PCI\VEN_8086&DEV_2443&SUBSYS_45418086&REV_01\BUS_00&DEV_1F&FUNC_03)
[0010AEAE] Enumerating Intel(R) 82801BA/BAM SMBus Controller - 2443 (PCI\VEN_8086&DEV_2443&SUBSYS_45418086&REV_01\BUS_00&DEV_1F&FUNC_03)
[0010AEAE] Enumerated Intel(R) 82801BA/BAM SMBus Controller - 2443 (PCI\VEN_8086&DEV_2443&SUBSYS_45418086&REV_01\BUS_00&DEV_1F&FUNC_03)
[0010AEAE] Loading PNP drivers of RADEON 9600 SERIES (PCI\VEN_1002&DEV_4150&SUBSYS_7C20174B&REV_00\000800)
[0010AEAE] Loaded PNP drivers of RADEON 9600 SERIES (PCI\VEN_1002&DEV_4150&SUBSYS_7C20174B&REV_00\000800)
[0010AEAF] Starting RADEON 9600 SERIES (PCI\VEN_1002&DEV_4150&SUBSYS_7C20174B&REV_00\000800)
[0010AEAF] Dynamic load device ATI2VXAG.VXD
[0010AEB1] Dynamic init device ATI2VXAG
[0010AEB1] Dynamic init success ATI2VXAG
[0010AEB1] Dynamic load success ATI2VXAG.VXD
[0010AEB1] Started RADEON 9600 SERIES (PCI\VEN_1002&DEV_4150&SUBSYS_7C20174B&REV_00\000800)
[0010AEB2] Enumerating RADEON 9600 SERIES (PCI\VEN_1002&DEV_4150&SUBSYS_7C20174B&REV_00\000800)
[0010AEB6] Enumerated RADEON 9600 SERIES (PCI\VEN_1002&DEV_4150&SUBSYS_7C20174B&REV_00\000800)
[0010AEB6] Loading PNP drivers of SAPPHIRE RADEON 9600 ATLANTIS - Secondary (PCI\VEN_1002&DEV_4170&SUBSYS_7C21174B&REV_00\010800)
[0010AEB6] Loaded PNP drivers of SAPPHIRE RADEON 9600 ATLANTIS - Secondary (PCI\VEN_1002&DEV_4170&SUBSYS_7C21174B&REV_00\010800)
[0010AEB7] Starting SAPPHIRE RADEON 9600 ATLANTIS - Secondary (PCI\VEN_1002&DEV_4170&SUBSYS_7C21174B&REV_00\010800)
[0010AEB7] Dynamic load device ATI2VXAG.VXD
[0010AEB7] Dynamic init device ATI2VXAG
[0010AEB7] Dynamic init success ATI2VXAG
[0010AEB7] Dynamic load success ATI2VXAG.VXD
[0010AEB8] Started SAPPHIRE RADEON 9600 ATLANTIS - Secondary (PCI\VEN_1002&DEV_4170&SUBSYS_7C21174B&REV_00\010800)
[0010AEB8] Enumerating SAPPHIRE RADEON 9600 ATLANTIS - Secondary (PCI\VEN_1002&DEV_4170&SUBSYS_7C21174B&REV_00\010800)
[0010AEB8] Enumerated SAPPHIRE RADEON 9600 ATLANTIS - Secondary (PCI\VEN_1002&DEV_4170&SUBSYS_7C21174B&REV_00\010800)
[0010AEB8] Loading PNP drivers of Realtek RTL8169/8110 Family Gigabit Ethernet NIC (PCI\VEN_10EC&DEV_8169&SUBSYS_816910EC&REV_10\58F000)
[0010AEB8] Loading PNP drivers of Creative SB Live! series(WDM) (PCI\VEN_1102&DEV_0002&SUBSYS_80611102&REV_07\60F000)
[0010AEBC] Dynamic load device mmdevldr.vxd
[0010AEBC] Dynamic init device MMDEVLDR
[0010AEBC] Dynamic init success MMDEVLDR
[0010AEBD] Dynamic load success mmdevldr.vxd
[0010AEBD] Loading PNP drivers of Game Port for Creative SB Live! (PCI\VEN_1102&DEV_7002&SUBSYS_00201102&REV_07\61F000)
[0010AEBD] Dynamic load device mmdevldr.vxd
[0010AEBD] Dynamic init device MMDEVLDR
[0010AEBE] Dynamic init success MMDEVLDR
[0010AEBE] Dynamic load success mmdevldr.vxd
[0010AEBE] Starting Plug and Play Monitor (MONITOR\GSM5B54\PCI_VEN_1002&DEV_4150&SUBSYS_7C20174B&REV_00_000800)
[0010AEBE] Started Plug and Play Monitor (MONITOR\GSM5B54\PCI_VEN_1002&DEV_4150&SUBSYS_7C20174B&REV_00_000800)
[0010AEBF] Enumerating Plug and Play Monitor (MONITOR\GSM5B54\PCI_VEN_1002&DEV_4150&SUBSYS_7C20174B&REV_00_000800)
[0010AEBF] Enumerated Plug and Play Monitor (MONITOR\GSM5B54\PCI_VEN_1002&DEV_4150&SUBSYS_7C20174B&REV_00_000800)
[0010AEBF] Starting MACROSILICON (MONITOR\DEFAULT_MONITOR\PCI_VEN_1002&DEV_4170&SUBSYS_7C21174B&REV_00_010800)
[0010AEBF] Started MACROSILICON (MONITOR\DEFAULT_MONITOR\PCI_VEN_1002&DEV_4170&SUBSYS_7C21174B&REV_00_010800)
[0010AEC0] Enumerating MACROSILICON (MONITOR\DEFAULT_MONITOR\PCI_VEN_1002&DEV_4170&SUBSYS_7C21174B&REV_00_010800)
[0010AEC0] Enumerated MACROSILICON (MONITOR\DEFAULT_MONITOR\PCI_VEN_1002&DEV_4170&SUBSYS_7C21174B&REV_00_010800)
[0010AEC0] Loading PNP drivers of Primary IDE controller (dual fifo) (MF\CHILD0000\PCI&VEN_8086&DEV_244B&SUBSYS_45418086&REV_01&BUS_00&DEV_1F&FUNC_01)
[0010AEC0] Loading PNP drivers of Secondary IDE controller (dual fifo) (MF\CHILD0001\PCI&VEN_8086&DEV_244B&SUBSYS_45418086&REV_01&BUS_00&DEV_1F&FUNC_01)
[0010AEC0] Enumerating Intel(R) 82801BA/BAM USB Universal Host Controller - 2442 (PCI\VEN_8086&DEV_2442&SUBSYS_45418086&REV_01\BUS_00&DEV_1F&FUNC_02)
[0010AEC0] Enumerated Intel(R) 82801BA/BAM USB Universal Host Controller - 2442 (PCI\VEN_8086&DEV_2442&SUBSYS_45418086&REV_01\BUS_00&DEV_1F&FUNC_02)
[0010AEC1] Loading PNP drivers of USB Root Hub (USB\ROOT_HUB\PCI&VEN_8086&DEV_2442&SUBSYS_45418086&REV_01&BUS_00&DEV_1F&FUNC_02)
[0010AEC2] Loaded PNP drivers of USB Root Hub (USB\ROOT_HUB\PCI&VEN_8086&DEV_2442&SUBSYS_45418086&REV_01&BUS_00&DEV_1F&FUNC_02)
[0010AEC2] Starting USB Root Hub (USB\ROOT_HUB\PCI&VEN_8086&DEV_2442&SUBSYS_45418086&REV_01&BUS_00&DEV_1F&FUNC_02)
[0010AEC3] Started USB Root Hub (USB\ROOT_HUB\PCI&VEN_8086&DEV_2442&SUBSYS_45418086&REV_01&BUS_00&DEV_1F&FUNC_02)
[0010AEC3] Enumerating USB Root Hub (USB\ROOT_HUB\PCI&VEN_8086&DEV_2442&SUBSYS_45418086&REV_01&BUS_00&DEV_1F&FUNC_02)
[0010AECF] Enumerated USB Root Hub (USB\ROOT_HUB\PCI&VEN_8086&DEV_2442&SUBSYS_45418086&REV_01&BUS_00&DEV_1F&FUNC_02)
[0010AECF] Loading PNP drivers of Generic USB Hub (USB\VID_1A40&PID_0101\INST_0)
[0010AECF] Loaded PNP drivers of Generic USB Hub (USB\VID_1A40&PID_0101\INST_0)
[0010AED0] Starting Generic USB Hub (USB\VID_1A40&PID_0101\INST_0)
[0010AED9] Started Generic USB Hub (USB\VID_1A40&PID_0101\INST_0)
[0010AED9] Loading PNP drivers of USB Human Interface Device (USB\VID_046D&PID_C018\INST_0)
[0010AEDA] Loaded PNP drivers of USB Human Interface Device (USB\VID_046D&PID_C018\INST_0)
[0010AEDA] Starting USB Human Interface Device (USB\VID_046D&PID_C018\INST_0)
[0010AEDB] Started USB Human Interface Device (USB\VID_046D&PID_C018\INST_0)
[0010AEDB] Enumerating Generic USB Hub (USB\VID_1A40&PID_0101\INST_0)
[0010AEE8] Enumerated Generic USB Hub (USB\VID_1A40&PID_0101\INST_0)
[0010AEE8] Loading PNP drivers of USB Mass Storage Device (USB\VID_090C&PID_2000\CCYYMMDDHHMMSSR5S36J)
[0010AEE9] Loaded PNP drivers of USB Mass Storage Device (USB\VID_090C&PID_2000\CCYYMMDDHHMMSSR5S36J)
[0010AEE9] Starting USB Mass Storage Device (USB\VID_090C&PID_2000\CCYYMMDDHHMMSSR5S36J)
[0010AEF6] Started USB Mass Storage Device (USB\VID_090C&PID_2000\CCYYMMDDHHMMSSR5S36J)
[0010AEF7] Loading PNP drivers of Logitech Extreme 3D Pro (USB) (USB\VID_046D&PID_C215\INST_0)
[0010AEF7] Loaded PNP drivers of Logitech Extreme 3D Pro (USB) (USB\VID_046D&PID_C215\INST_0)
[0010AEF7] Starting Logitech Extreme 3D Pro (USB) (USB\VID_046D&PID_C215\INST_0)
[0010AEF8] Started Logitech Extreme 3D Pro (USB) (USB\VID_046D&PID_C215\INST_0)
[0010AEF9] Enumerating USB Human Interface Device (USB\VID_046D&PID_C018\INST_0)
[0010AEF9] Enumerated USB Human Interface Device (USB\VID_046D&PID_C018\INST_0)
[0010AEF9] Loading PNP drivers of HID-compliant mouse (HID\VID_046D&PID_C018\0000USB&VID_046D&PID_C018&INST_0)
[0010AEF9] Dynamic load device mouhid.vxd
[0010AEFA] Dynamic init device MOUHID
[0010AEFA] Dynamic init success MOUHID
[0010AEFA] Dynamic load success mouhid.vxd
[0010AEFA] Loaded PNP drivers of HID-compliant mouse (HID\VID_046D&PID_C018\0000USB&VID_046D&PID_C018&INST_0)
[0010AEFB] Starting HID-compliant mouse (HID\VID_046D&PID_C018\0000USB&VID_046D&PID_C018&INST_0)
[0010AEFB] Started HID-compliant mouse (HID\VID_046D&PID_C018\0000USB&VID_046D&PID_C018&INST_0)
[0010AEFB] Enumerating USB Mass Storage Device (USB\VID_090C&PID_2000\CCYYMMDDHHMMSSR5S36J)
[0010AEFB] Enumerated USB Mass Storage Device (USB\VID_090C&PID_2000\CCYYMMDDHHMMSSR5S36J)
[0010AEFC] Loading PNP drivers of USB Disk (USBSTOR\DISK&VEN_USB&PROD_FLASH_DISK&REV_1100\CCYYMMDDHHMMSSR5S36J&0)
[0010AEFC] Enumerating Logitech Extreme 3D Pro (USB) (USB\VID_046D&PID_C215\INST_0)
[0010AEFC] Enumerated Logitech Extreme 3D Pro (USB) (USB\VID_046D&PID_C215\INST_0)
[0010AEFC] Loading PNP drivers of Logitech Extreme 3D Pro (HID) (HID\VID_046D&PID_C215\0000USB&VID_046D&PID_C215&INST_0)
[0010AEFD] Dynamic load device LXLCore.VXD
[0010AEFD] Dynamic init device LXLCORE
[0010AEFD] Dynamic init success LXLCORE
[0010AEFE] Dynamic load success LXLCore.VXD
[0010AEFE] Dynamic load device joyhid.vxd
[0010AEFE] Dynamic init device JOYHID
[0010AEFE] Dynamic init success JOYHID
[0010AEFE] Dynamic load success joyhid.vxd
[0010AEFF] Dynamic load device mmdevldr.vxd
[0010AEFF] Dynamic init device MMDEVLDR
[0010AEFF] Dynamic init success MMDEVLDR
[0010AEFF] Dynamic load success mmdevldr.vxd
[0010AF00] Enumerating HID-compliant mouse (HID\VID_046D&PID_C018\0000USB&VID_046D&PID_C018&INST_0)
[0010AF00] Enumerated HID-compliant mouse (HID\VID_046D&PID_C018\0000USB&VID_046D&PID_C018&INST_0)
[0010AF00] DEVICEINIT = ACPI
[0010AF00] DEVICEINITSUCCESS = ACPI
[0010AF00] DEVICEINIT = VCDFSD
[0010AF00] DEVICEINITSUCCESS = VCDFSD
[0010AF01] DEVICEINIT = IOS
[0010AF02] Dynamic load device C:\WINDOWS\system\IOSUBSYS\apix.vxd
[0010AF02] Dynamic load success C:\WINDOWS\system\IOSUBSYS\apix.vxd
[0010AF02] Dynamic load device C:\WINDOWS\system\IOSUBSYS\atapchng.vxd
[0010AF03] Dynamic load success C:\WINDOWS\system\IOSUBSYS\atapchng.vxd
[0010AF03] Dynamic load device C:\WINDOWS\system\IOSUBSYS\cdfs.vxd
[0010AF03] Dynamic load success C:\WINDOWS\system\IOSUBSYS\cdfs.vxd
[0010AF03] Dynamic load device C:\WINDOWS\system\IOSUBSYS\cdtsd.vxd
[0010AF04] Dynamic load success C:\WINDOWS\system\IOSUBSYS\cdtsd.vxd
[0010AF04] Dynamic load device C:\WINDOWS\system\IOSUBSYS\cdvsd.vxd
[0010AF04] Dynamic load success C:\WINDOWS\system\IOSUBSYS\cdvsd.vxd
[0010AF04] Dynamic load device C:\WINDOWS\system\IOSUBSYS\disktsd.vxd
[0010AF05] Dynamic load success C:\WINDOWS\system\IOSUBSYS\disktsd.vxd
[0010AF05] Dynamic load device C:\WINDOWS\system\IOSUBSYS\diskvsd.vxd
[0010AF05] Dynamic load success C:\WINDOWS\system\IOSUBSYS\diskvsd.vxd
[0010AF06] Dynamic load device C:\WINDOWS\system\IOSUBSYS\drvspacx.vxd
[0010AF06] Dynamic load success C:\WINDOWS\system\IOSUBSYS\drvspacx.vxd
[0010AF06] Dynamic load device C:\WINDOWS\system\IOSUBSYS\drvwcdb.vxd
[0010AF07] Dynamic load success C:\WINDOWS\system\IOSUBSYS\drvwcdb.vxd
[0010AF07] Dynamic load device C:\WINDOWS\system\IOSUBSYS\drvwppqt.vxd
[0010AF08] Dynamic load success C:\WINDOWS\system\IOSUBSYS\drvwppqt.vxd
[0010AF08] Dynamic load device C:\WINDOWS\system\IOSUBSYS\drvwq117.vxd
[0010AF09] Dynamic load success C:\WINDOWS\system\IOSUBSYS\drvwq117.vxd
[0010AF09] Dynamic load device C:\WINDOWS\system\IOSUBSYS\necatapi.vxd
[0010AF09] Dynamic load success C:\WINDOWS\system\IOSUBSYS\necatapi.vxd
[0010AF09] Dynamic load device C:\WINDOWS\system\IOSUBSYS\scsi1hlp.vxd
[0010AF0A] Dynamic load success C:\WINDOWS\system\IOSUBSYS\scsi1hlp.vxd
[0010AF0A] Dynamic load device C:\WINDOWS\system\IOSUBSYS\torisan3.vxd
[0010AF0A] Dynamic load success C:\WINDOWS\system\IOSUBSYS\torisan3.vxd
[0010AF0A] Dynamic load device C:\WINDOWS\system\IOSUBSYS\voltrack.vxd
[0010AF0B] Dynamic load success C:\WINDOWS\system\IOSUBSYS\voltrack.vxd
[0010AF0B] Dynamic load device C:\WINDOWS\system\IOSUBSYS\cdr4vsd.vxd
[0010AF0C] Dynamic load success C:\WINDOWS\system\IOSUBSYS\cdr4vsd.vxd
[0010AF0C] Dynamic load device C:\WINDOWS\system\IOSUBSYS\cdralvsd.vxd
[0010AF0D] Dynamic load success C:\WINDOWS\system\IOSUBSYS\cdralvsd.vxd
[0010AF0D] Dynamic load device C:\WINDOWS\system\IOSUBSYS\acbhlpr.vxd
[0010AF0D] Dynamic load success C:\WINDOWS\system\IOSUBSYS\acbhlpr.vxd
[0010AF0E] Dynamic load device C:\WINDOWS\system\IOSUBSYS\iomega.vxd
[0010AF0E] Dynamic load success C:\WINDOWS\system\IOSUBSYS\iomega.vxd
[0010AF0E] Dynamic load device C:\WINDOWS\system\IOSUBSYS\smartvsd.vxd
[0010AF0F] Dynamic load success C:\WINDOWS\system\IOSUBSYS\smartvsd.vxd
[0010AF0F] Dynamic load device C:\WINDOWS\system\IOSUBSYS\rmm.pdr
[0010AF0F] Dynamic load success C:\WINDOWS\system\IOSUBSYS\rmm.pdr
[0010AF0F] Dynamic load device C:\WINDOWS\system\IOSUBSYS\bigmem.drv
[0010AF10] Dynamic load success C:\WINDOWS\system\IOSUBSYS\bigmem.drv
[0010AF10] DEVICEINITSUCCESS = IOS
[0010AF10] DEVICEINIT = PAGEFILE
[0010AF10] DEVICEINITSUCCESS = PAGEFILE
[0010AF10] DEVICEINIT = PAGESWAP
[0010AF11] DEVICEINITSUCCESS = PAGESWAP
[0010AF11] DEVICEINIT = PARITY
[0010AF11] DEVICEINITSUCCESS = PARITY
[0010AF11] DEVICEINIT = REBOOT
[0010AF11] DEVICEINITSUCCESS = REBOOT
[0010AF12] DEVICEINIT = EBIOS
[0010AF12] DEVICEINITSUCCESS = EBIOS
[0010AF12] DEVICEINIT = VDD
[0010AF12] DEVICEINITSUCCESS = VDD
[0010AF12] DEVICEINIT = VSD
[0010AF13] DEVICEINITSUCCESS = VSD
[0010AF13] DEVICEINIT = COMBUFF
[0010AF13] DEVICEINITSUCCESS = COMBUFF
[0010AF13] DEVICEINIT = VCD
[0010AF13] DEVICEINITSUCCESS = VCD
[0010AF14] DEVICEINIT = VMOUSE
[0010AF14] DEVICEINITSUCCESS = VMOUSE
[0010AF14] Loading PNP drivers of Microsoft PS/2 Port Mouse (ACPI\*PNP0F03\0)
[0010AF14] Loaded PNP drivers of Microsoft PS/2 Port Mouse (ACPI\*PNP0F03\0)
[0010AF15] Starting Microsoft PS/2 Port Mouse (ACPI\*PNP0F03\0)
[0010AF15] Started Microsoft PS/2 Port Mouse (ACPI\*PNP0F03\0)
[0010AF15] Enumerating Microsoft PS/2 Port Mouse (ACPI\*PNP0F03\0)
[0010AF15] Enumerated Microsoft PS/2 Port Mouse (ACPI\*PNP0F03\0)
[0010AF15] DEVICEINIT = MSMINI
[0010AF16] DEVICEINITSUCCESS = MSMINI
[0010AF16] DEVICEINIT = ENABLE
[0010AF16] DEVICEINITSUCCESS = ENABLE
[0010AF16] DEVICEINIT = VKD
[0010AF16] DEVICEINITSUCCESS = VKD
[0010AF16] DEVICEINIT = VPD
[0010AF17] DEVICEINITSUCCESS = VPD
[0010AF17] DEVICEINIT = INT13
[0010AF17] DEVICEINITSUCCESS = INT13
[0010AF17] DEVICEINIT = VMCPD
[0010AF17] DEVICEINITSUCCESS = VMCPD
[0010AF18] DEVICEINIT = BIOSXLAT
[0010AF18] DEVICEINITSUCCESS = BIOSXLAT
[0010AF18] DEVICEINIT = SDVXD
[0010AF18] DEVICEINITSUCCESS = SDVXD
[0010AF19] DEVICEINIT = VNETBIOS
[0010AF19] DEVICEINITSUCCESS = VNETBIOS
[0010AF19] DEVICEINIT = NDIS
[0010AF23] DEVICEINITSUCCESS = NDIS
[0010AF25] Loading PNP drivers of Dial-Up Adapter (ROOT\NET\0001)
[0010AF26] Dynamic load device pppmac.vxd
[0010AF27] Dynamic init device PPPMAC
[0010AF27] Dynamic load device C:\WINDOWS\system\spap.vxd
[0010AF28] Dynamic init device SPAP
[0010AF28] Dynamic init success SPAP
[0010AF28] Dynamic load success C:\WINDOWS\system\spap.vxd
[0010AF28] Dynamic init success PPPMAC
[0010AF28] Dynamic load success pppmac.vxd
[0010AF28] Loaded PNP drivers of Dial-Up Adapter (ROOT\NET\0001)
[0010AF29] Starting Dial-Up Adapter (ROOT\NET\0001)
[0010AF29] Started Dial-Up Adapter (ROOT\NET\0001)
[0010AF29] Enumerating Dial-Up Adapter (ROOT\NET\0001)
[0010AF29] Enumerated Dial-Up Adapter (ROOT\NET\0001)
[0010AF2A] Loading PNP drivers of Dial-Up Adapter #2 (VPN Support) (ROOT\NET\0002)
[0010AF2A] Loaded PNP drivers of Dial-Up Adapter #2 (VPN Support) (ROOT\NET\0002)
[0010AF2A] Starting Dial-Up Adapter #2 (VPN Support) (ROOT\NET\0002)
[0010AF2A] Started Dial-Up Adapter #2 (VPN Support) (ROOT\NET\0002)
[0010AF2A] Enumerating Dial-Up Adapter #2 (VPN Support) (ROOT\NET\0002)
[0010AF2B] Enumerated Dial-Up Adapter #2 (VPN Support) (ROOT\NET\0002)
[0010AF2B] Loading PNP drivers of Microsoft Virtual Private Networking Adapter (ROOT\NET\0003)
[0010AF2B] Loaded PNP drivers of Microsoft Virtual Private Networking Adapter (ROOT\NET\0003)
[0010AF2B] Starting Microsoft Virtual Private Networking Adapter (ROOT\NET\0003)
[0010AF2C] Started Microsoft Virtual Private Networking Adapter (ROOT\NET\0003)
[0010AF2C] Loading PNP drivers of Realtek RTL8169/8110 Family Gigabit Ethernet NIC (PCI\VEN_10EC&DEV_8169&SUBSYS_816910EC&REV_10\58F000)
[0010AF2D] Loaded PNP drivers of Realtek RTL8169/8110 Family Gigabit Ethernet NIC (PCI\VEN_10EC&DEV_8169&SUBSYS_816910EC&REV_10\58F000)
[0010AF2D] Starting Realtek RTL8169/8110 Family Gigabit Ethernet NIC (PCI\VEN_10EC&DEV_8169&SUBSYS_816910EC&REV_10\58F000)
[0010AF2D] Started Realtek RTL8169/8110 Family Gigabit Ethernet NIC (PCI\VEN_10EC&DEV_8169&SUBSYS_816910EC&REV_10\58F000)
[0010AF33] Loading PNP drivers of TCP/IP (NETWORK\MSTCP\0001)
[0010AF33] Dynamic load device vtdi.386
[0010AF33] Dynamic init device VTDI
[0010AF33] Dynamic init success VTDI
[0010AF34] Dynamic load success vtdi.386
[0010AF34] Dynamic load device vip.386
[0010AF34] Dynamic init device VIP
[0010AF34] Dynamic init success VIP
[0010AF35] Dynamic load success vip.386
[0010AF35] Dynamic load device vtcp.386
[0010AF35] Dynamic init device MSTCP
[0010AF36] Dynamic init success MSTCP
[0010AF36] Dynamic load success vtcp.386
[0010AF36] Dynamic load device vdhcp.386
[0010AF36] Dynamic init device VDHCP
[0010AF37] Dynamic init success VDHCP
[0010AF37] Dynamic load success vdhcp.386
[0010AF37] Dynamic load device vnbt.386
[0010AF38] Dynamic init device VNBT
[0010AF38] Dynamic init success VNBT
[0010AF38] Dynamic load success vnbt.386
[0010AF38] Starting TCP/IP (NETWORK\MSTCP\0001)
[0010AF38] Started TCP/IP (NETWORK\MSTCP\0001)
[0010AF39] Enumerating TCP/IP (NETWORK\MSTCP\0001)
[0010AF39] Enumerated TCP/IP (NETWORK\MSTCP\0001)
[0010AF39] Loading PNP drivers of Client for Microsoft Networks (NETWORK\VREDIR\0001)
[0010AF39] Starting Client for Microsoft Networks (NETWORK\VREDIR\0001)
[0010AF39] Started Client for Microsoft Networks (NETWORK\VREDIR\0001)
[0010AF3A] Starting Client for Microsoft Networks (NETWORK\VREDIR\0001)
[0010AF3A] Started Client for Microsoft Networks (NETWORK\VREDIR\0001)
[0010AF3A] Loaded PNP drivers of Client for Microsoft Networks (NETWORK\VREDIR\0001)
[0010AF3A] Enumerating Client for Microsoft Networks (NETWORK\VREDIR\0001)
[0010AF3A] Enumerated Client for Microsoft Networks (NETWORK\VREDIR\0001)
[0010AF3B] Loading PNP drivers of File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0002)
[0010AF3B] Starting File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0002)
[0010AF3B] Started File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0002)
[0010AF3B] Dynamic load device vserver.vxd
[0010AF3C] Dynamic init device VSERVER
[0010AF3C] Dynamic init success VSERVER
[0010AF3C] Dynamic load success vserver.vxd
[0010AF3C] Starting File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0002)
[0010AF3D] Started File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0002)
[0010AF3D] Loaded PNP drivers of File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0002)
[0010AF3D] Enumerating File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0002)
[0010AF3D] Enumerated File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0002)
[0010AF3D] Loading PNP drivers of File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0003)
[0010AF3E] Starting File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0003)
[0010AF3E] Started File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0003)
[0010AF3E] Loaded PNP drivers of File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0003)
[0010AF3F] Enumerating File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0003)
[0010AF3F] Enumerated File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0003)
[0010AF3F] Loaded PNP drivers of TCP/IP (NETWORK\MSTCP\0001)
[0010AF3F] Loading PNP drivers of TCP/IP (NETWORK\MSTCP\0002)
[0010AF3F] Starting TCP/IP (NETWORK\MSTCP\0002)
[0010AF40] Started TCP/IP (NETWORK\MSTCP\0002)
[0010AF40] Enumerating TCP/IP (NETWORK\MSTCP\0002)
[0010AF40] Enumerated TCP/IP (NETWORK\MSTCP\0002)
[0010AF40] Loading PNP drivers of Client for Microsoft Networks (NETWORK\VREDIR\0002)
[0010AF41] Starting Client for Microsoft Networks (NETWORK\VREDIR\0002)
[0010AF41] Started Client for Microsoft Networks (NETWORK\VREDIR\0002)
[0010AF42] Loaded PNP drivers of Client for Microsoft Networks (NETWORK\VREDIR\0002)
[0010AF42] Enumerating Client for Microsoft Networks (NETWORK\VREDIR\0002)
[0010AF42] Enumerated Client for Microsoft Networks (NETWORK\VREDIR\0002)
[0010AF42] Loading PNP drivers of File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0004)
[0010AF42] Starting File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0004)
[0010AF42] Started File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0004)
[0010AF43] Starting File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0004)
[0010AF43] Started File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0004)
[0010AF43] Loaded PNP drivers of File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0004)
[0010AF43] Enumerating File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0004)
[0010AF43] Enumerated File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0004)
[0010AF44] Loading PNP drivers of File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0005)
[0010AF44] Starting File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0005)
[0010AF44] Started File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0005)
[0010AF45] Started File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0005)
[0010AF45] Loaded PNP drivers of File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0005)
[0010AF45] Enumerating File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0005)
[0010AF45] Enumerated File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0005)
[0010AF45] Loaded PNP drivers of TCP/IP (NETWORK\MSTCP\0002)
[0010AF46] Enumerating Microsoft Virtual Private Networking Adapter (ROOT\NET\0003)
[0010AF46] Enumerated Microsoft Virtual Private Networking Adapter (ROOT\NET\0003)
[0010AF46] Loading PNP drivers of NDISWAN (NETWORK\NDISWAN\0000)
[0010AF46] Enumerating Realtek RTL8169/8110 Family Gigabit Ethernet NIC (PCI\VEN_10EC&DEV_8169&SUBSYS_816910EC&REV_10\58F000)
[0010AF47] Enumerated Realtek RTL8169/8110 Family Gigabit Ethernet NIC (PCI\VEN_10EC&DEV_8169&SUBSYS_816910EC&REV_10\58F000)
[0010AF47] Loading PNP drivers of TCP/IP (NETWORK\MSTCP\0003)
[0010AF47] Starting TCP/IP (NETWORK\MSTCP\0003)
[0010B034] Started TCP/IP (NETWORK\MSTCP\0003)
[0010B034] Enumerating TCP/IP (NETWORK\MSTCP\0003)
[0010B034] Enumerated TCP/IP (NETWORK\MSTCP\0003)
[0010B034] Loading PNP drivers of Client for Microsoft Networks (NETWORK\VREDIR\0003)
[0010B035] Starting Client for Microsoft Networks (NETWORK\VREDIR\0003)
[0010B035] Started Client for Microsoft Networks (NETWORK\VREDIR\0003)
[0010B035] Loaded PNP drivers of Client for Microsoft Networks (NETWORK\VREDIR\0003)
[0010B036] Enumerating Client for Microsoft Networks (NETWORK\VREDIR\0003)
[0010B036] Enumerated Client for Microsoft Networks (NETWORK\VREDIR\0003)
[0010B036] Loading PNP drivers of File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0006)
[0010B036] Starting File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0006)
[0010B036] Started File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0006)
[0010B037] Started File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0006)
[0010B037] Loaded PNP drivers of File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0006)
[0010B037] Enumerating File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0006)
[0010B038] Enumerated File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0006)
[0010B038] Loading PNP drivers of File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0007)
[0010B038] Starting File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0007)
[0010B038] Started File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0007)
[0010B039] Started File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0007)
[0010B039] Loaded PNP drivers of File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0007)
[0010B039] Enumerating File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0007)
[0010B03A] Enumerated File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0007)
[0010B03A] Loaded PNP drivers of TCP/IP (NETWORK\MSTCP\0003)
[0010B03A] Enumerating TCP/IP (NETWORK\MSTCP\0003)
[0010B03A] Enumerated TCP/IP (NETWORK\MSTCP\0003)
[0010B03A] Loading PNP drivers of Client for Microsoft Networks (NETWORK\VREDIR\0003)
[0010B03B] Starting Client for Microsoft Networks (NETWORK\VREDIR\0003)
[0010B03B] Started Client for Microsoft Networks (NETWORK\VREDIR\0003)
[0010B03C] Started Client for Microsoft Networks (NETWORK\VREDIR\0003)
[0010B03C] Loaded PNP drivers of Client for Microsoft Networks (NETWORK\VREDIR\0003)
[0010B03C] Enumerating Client for Microsoft Networks (NETWORK\VREDIR\0003)
[0010B03C] Enumerated Client for Microsoft Networks (NETWORK\VREDIR\0003)
[0010B03C] Loading PNP drivers of File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0006)
[0010B03D] Starting File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0006)
[0010B03D] Started File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0006)
[0010B03E] Loaded PNP drivers of File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0006)
[0010B03E] Enumerating File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0006)
[0010B03E] Enumerated File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0006)
[0010B03E] Loading PNP drivers of File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0007)
[0010B03F] Starting File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0007)
[0010B03F] Started File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0007)
[0010B040] Loaded PNP drivers of File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0007)
[0010B040] Enumerating File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0007)
[0010B040] Enumerated File and printer sharing for Microsoft Networks (NETWORK\VSERVER\0007)
[0010B040] DEVICEINIT = NDISWAN
[0010B041] DEVICEINITSUCCESS = NDISWAN
[0010B041] Loading PNP drivers of NDISWAN (NETWORK\NDISWAN\0000)
[0010B041] Starting NDISWAN (NETWORK\NDISWAN\0000)
[0010B041] Started NDISWAN (NETWORK\NDISWAN\0000)
[0010B041] Enumerating NDISWAN (NETWORK\NDISWAN\0000)
[0010B042] Enumerated NDISWAN (NETWORK\NDISWAN\0000)
[0010B042] Loaded PNP drivers of NDISWAN (NETWORK\NDISWAN\0000)
[0010B042] DEVICEINIT = DOSMGR
[0010B042] DEVICEINITSUCCESS = DOSMGR
[0010B043] DEVICEINIT = VMPOLL
[0010B048] DEVICEINITSUCCESS = VMPOLL
[0010B049] DEVICEINIT = JAVASUP
[0010B049] DEVICEINITSUCCESS = JAVASUP
[0010B049] DEVICEINIT = VCOMM
[0010B04A] DEVICEINITSUCCESS = VCOMM
[0010B04A] DEVICEINIT = VCOND
[0010B04A] DEVICEINITSUCCESS = VCOND
[0010B04A] DEVICEINIT = VTDAPI
[0010B04A] DEVICEINITSUCCESS = VTDAPI
[0010B04B] DEVICEINIT = KEYREMAP
[0010B04B] DEVICEINITSUCCESS = KEYREMAP
[0010B04B] DEVICEINIT = VFLATD
[0010B04B] DEVICEINITSUCCESS = VFLATD
[0010B04C] DEVICEINIT = Display1
[0010B04C] DEVICEINITSUCCESS = Display1
[0010B04C] DEVICEINIT = Display2
[0010B04C] DEVICEINITSUCCESS = Display2
[0010B04D] DEVICEINIT = SBEMUL
[0010B04D] DEVICEINITSUCCESS = SBEMUL
[0010B04D] DEVICEINIT = USBNTMAP
[0010B04D] DEVICEINITSUCCESS = USBNTMAP
[0010B04E] DEVICEINIT = VDMAD
[0010B04E] DEVICEINITSUCCESS = VDMAD
[0010B04E] DEVICEINIT = V86MMGR
[0010B04E] DEVICEINITSUCCESS = V86MMGR
[0010B04E] DEVICEINIT = SPOOLER
[0010B04F] DEVICEINITSUCCESS = SPOOLER
[0010B04F] DEVICEINIT = UDF
[0010B04F] DEVICEINITSUCCESS = UDF
[0010B04F] DEVICEINIT = VFAT
Reply 7 of 8, by Queen K Juul
I've run Scandisk, I've run Memtest for 2+ hours, I've tried clearing the PnP config data in BIOS and both the on and off settings of "pnp os" in bios settings.
I've gotten this error before, never resolved it, and as far as I can tell it's not triggered by anything to do with the actual disk systems, it just so happens that the VFAT VXD is when the kernel runs out or memory/hits whatever other exception it's hitting
