First post, by uscleo
Does anyone have any ideas on if it's possible? I have been trying but no luck - I can get EGA to work, but CGA is what I'm trying to get at.
Specifically, I am trying to get Windows 95 to play nice with my Compaq Portable 386 - it has special drivers "plasma.drv" and "Plasma.3gr" that work with Windows 3 - 3.11, but I can't get them to work with Windows 95. I believe the plasma drivers run Windows 3 / 3.11 in monochrome mode which the Compaq Portable 386 supports, but the compaq has jumpers also for CGA emulation mode.
https://www.betaarchive.com/forum/viewtopic.php?t=12325 - seems like others have reached the same conclusion in that CGA (and by extension the plasma drivers) won't work with Windows 95... does anyone know why? Would anyone know where to start if one were to try modify the drivers to work for Win 95? I have the expansion chassis for my Compaq, and windows 95 is pretty zippy with a Mach 64 ISA card and external monitor - but I want to see how it performs with it's internal plasma display.
Any ideas welcome!
Reply 2 of 5, by Disruptor
Yes, it is possible.
640x200 in monochrome.
You have to make a driver disk using the Windows 3.0 drivers.
Reply 3 of 5, by radiounix
I remember reading a blog post where someone messed around a good bit with this and came to the conclusion that it could not be done. They did get the 3.0 drivers to work in a Chicago beta, but parts of basic system dialog boxes were cut off because the 640x200 viewport was too small. Windows 95s UI was designed around VGA, and in 640x480 some basic system Windows already fill the screen and so likely wouldn't even be usable under EGA. I guess you could track down a virtual desktop expander program, but the whole affair sounds painful. If you can get the 640x400 video mode to work, it might be usable, but "okay" and "cancel" boxes will probably be barely visible and you may have to set the task bar to auto-disappear.
I've also heard that the correct way to use the older drivers is to install 3.1x with the older driver, then upgrade in place to 95.
Reply 4 of 5, by Jo22
The Compaq perhaps supports that Olivetti M24/AT&T mono mode of 640x400..
You can check by running these simple test programs : Olivetti/Logabax/AT&T/Toshiba 640x400 hi-res graphics mode
If you're eager for experimentation, do a test installation of Windows 3.1 with a compatible driver.
And if it runs, let Windows 95 do an upgrade. Maybe it will keep that special driver in place.
Reply 5 of 5, by Grzyb
The last Windows version shipped with CGA driver was 3.0, but such a driver was also provided for 3.1 - as part of the "Windows 3.1 Driver Library".
Maybe the driver for 3.1 was somehow updated, and has greater chances to run in 95 ?
Kiełbasa smakuje najlepiej, gdy przysmażysz ją laserem!
