First post, by appiah4
Does anyone know how to set the FSB to 66Mhz on HP Vectra Vei8 PCs with Sherwood-B motherboards?
A “CPU Frequency Jumper” block is located on J14 and the manual states a CPU will come with a matching shunt if needed but that is all I could find on it.
Being a 440ZX board it should be possible to set this to 66MHz FSB but I can not figure out thia undocumented setting.
Reply 1 of 3, by PC Hoarder Patrol
appiah4 wrote on 2020-09-30, 18:45:
Assuming Slot 1, on mine its silkscreened above the memory slots
163.56 KiB
Reply 3 of 3, by dionb
PC Hoarder Patrol wrote on 2020-09-30, 23:55:
Aren't those just the multiplier jumpers, not FSB?
I would expect OEM boards like this to 'autodetect' FSB via BSEL0 and BSEL1 pins on the CPU. Both should be pulled low for 66MHz.
