First post, by Robhalfordfan
hello all
i am try make my own bat file for my dos games that has multiple episodes in dos 6.22
i have been trying to use the choice command but no matter what option i press, it always loads up ep 1 instead of another and even when i choose to exit the "menu" or a syntax error
if there is a easier way to do this or a example somewhere that i can use to understand what i am doing wrong
any help would great
Reply 1 of 2, by keropi
Here I made one such .bat for you
notice how the IF ERRORLEVEL statements are going backwards
just adapt it to your needs adding/removing choices
echo  Choose an episode to launch
echo.
echo 1. Episode 1
echo 2. Episode 2
echo 3. Episode 3
echo 4. Exit
echo.
CHOICE /C:1234
IF ERRORLEVEL 4 GOTO END
IF ERRORLEVEL 3 GOTO EPISODE3
IF ERRORLEVEL 2 GOTO EPISODE2
IF ERRORLEVEL 1 GOTO EPISODE1
:EPISODE1
< command to load this episode>
GOTO END
:EPISODE2
GOTO END
:EPISODE3
GOTO END
:END
Reply 2 of 2, by Robhalfordfan
i did not know the errorlevels choices had to backwards
and i noticed a spelling error on my part which affect the rest of choices but all works and load to corresponding episodes
will keep this as guide for any other dos game/program that has mutiple episode and if some slowdown software or other stuff loads before game
thank you for your help
