First post, by ildonaldo
Due to Covid-19 I advanced some of my retro projects that I've planned for the next winter season 😉
Please find here my 1998 rebuild:
Board: MSI MS6119 Ver. 1.1 (1998)
CPU: Pentium II, 400 450 MHz (upgade info see below)
RAM: 128MB, Mo SDRAM PC100, Hyundai GMM26416233ENT
2D-Grafik: Matrox G200A, 8MB (1998)
3D-Grafik: SLI 2x Voodoo 2, Creative Labs CT6670, 2x12MB (1998)
Sound: SB 128 PCI, CT4700 (1998)
HDD: 6,4gb IDE, IBM DTTA-350640 (1998)
ODD: DSR-520H DVD-ROM (5,2X/32X), DVS Korea Co. (Feb. 1999)
FDD: 1.44 MB 3.5", D359T7, Newtronics Mitsumi
Case: NoName ATX (ca. 199x)
PSU: ATX 380W, Seasonic SS-380GB Active PFC F3
OS: Windows 98SE (incl. Updates)
Honestly, this isn't my most favoured Retro-build because I've never got friends with 3dfx before the Voodoo 3 as single card solution came out.
There was always, due to the Loop-through, this loss in video quality.
Working in grapic business, despite of the good 3D performace, this was always a no go for me.
best wishes & stay well
ildonaldo
Here some pictures ...
The attachment 01.jpg is no longer available
The attachment 02.jpg is no longer available
The attachment 03.jpg is no longer available
Building my own PCs since 1991 - for my retro builds it's "no CF-disks, no Floppy emulators, no modern cases etc.", only the real and authentic stuff whenever possible.
Reply 1 of 19, by Joseph_Joestar
That looks awesome, except for the SB128. It's a bad card overall, with software EAX and some of the worst FM Synthesis in existence.
The Sound Blaster Live was released in late '98 so you can use one of those and still stay period-correct. It's a huge improvement over the SB128 in all aspects.
Reply 2 of 19, by chrismeyer6
I really like that case it fits that time period very well. If your monitor has dual vga ports you can put the main card on one and Voodoo's on the other
Reply 3 of 19, by wirerogue
i like it.
i would definitely utilize the front fan mount. looks like an 80mm.
not sure exactly what seasonic power supply that is but, your entire system is only going to draw about 100 watts so that psu fan might not even turn on.
Reply 4 of 19, by chrismeyer6
I concur with that looking like an 80mm fan mount. I also think it would be a good idea to install a fan there. You can never have to much cooling.
Reply 5 of 19, by foil_fresh
The SB128 might be a bad FM card but it's General MIDI from within windows is decent so it's not too awful. I've had crystal sound cards that suck doing everything 😜
Reply 6 of 19, by ildonaldo
wirerogue wrote on 2020-06-11, 23:02:
The PSU was just at hand when I built it.
I always try (if possible and not too costly) to stay in period with the hardware except for the PSU - I wouldn't like to use one of this firecrackers that were sold back then.
Reply 7 of 19, by ildonaldo
foil_fresh wrote on 2020-06-12, 05:06:
Thank you, the card is only intended for windows.
If I play games that need OPL3 support than I use either my 486 or the Pentium clone.
Reply 8 of 19, by Joseph_Joestar
Those ECW sets that the SB128 uses for General MIDI sound very bland to me, even with the 8 MB version. With a SBLive, you can use proper soundfonts and get something that sounds reasonably close to a Roland SC-55.
Other than that, the software EAX that the SB128 uses sounds different from the hardware EAX on a SBLive. The software EAX also taxes the CPU more which can make a difference in demanding games. Source: I own both cards and have used the SB128 for 5 years during my youth.
Reply 9 of 19, by ildonaldo
Joseph_Joestar wrote on 2020-06-11, 20:05:
Which model ( CTxxxx) are you referring to?
If I go on the hunt I'd like to know which pray to look for 😀
Reply 10 of 19, by Joseph_Joestar
ildonaldo wrote on 2020-06-12, 10:28:
If I remember correctly, the original SBLive (CT4620) was released in August of 1998 (see this review) while the Value version (CT4670) came out in October of the same year.
You might want to double check those model numbers with other people to be sure. Also, see here: https://en.wikipedia.org/wiki/Sound_Blaster_Live!#Models
Reply 11 of 19, by chinny22
Jan 98 when when I got my first PC , up till then I was using the family DX2/66
Had a $3000 AUD budget and this is what I got:
P2 400
64MB Ram
Onboard SB64 PCI
10GB HDD
32x CD-ROM
A friend strongly recommended upgrading to the graphics to a 16MB TNT. It was cheaper then going Voodoo 2
a SB Live was high on my want list but didn't get the Live! value till the following year.
So depending on what other systems you ave planned the 128 PCI may still be a more correct choice, you do miss out on EAX though.
Reply 12 of 19, by ildonaldo
I have been able to get a CT4620 with the CT4660 extension board cheap.
It should arrive in a few days.
And according to soundblaster.com it should be in period for my 1998 build.
Reply 13 of 19, by Joseph_Joestar
ildonaldo wrote on 2020-06-17, 15:13:
Very nice! I love the gold plated connectors on that model.
If you want to play around with soundfonts in DOS games, try using the Audigy drivers on it.
Reply 14 of 19, by Wolfus
Very nice build! I wish I had similar in 1998 (or 2000) 😀
Reply 15 of 19, by ildonaldo
Finally I've found some time to update the Hardware with the new Soundcard, PSU and a 80mm case fan.
Everything runs fine 😀
CPU: Pentium II, 400 450MHz, with Intel cooler (1998)
Sound: Sound Blaster Live! Gold CT4620 & CT4660, PCI (1998)
Case fan: 1x 80mm Lüfter (Cooler Master A8025-21CB-3BN-P1)
PSU: be quiet! PURE POWER BQT L7-350W ATX
The attachment 01snd.jpg is no longer available
The attachment 04_IO.jpg is no longer available
The attachment Hardware.jpg is no longer available
Reply 16 of 19, by matze79
8mb gm Bank also works in plain dos
Reply 17 of 19, by ildonaldo
recently I've got a Pentium 2 450 MHz along with a Gigabyte GA-6BXC board cheap.
The board was crap (needs some new capacitors first) but the CPU works fine on the MS6119.
I've now upgraded the machine to max the '98 Pentium II Power 😀
The attachment s-l1600.jpg is no longer available
Reply 18 of 19, by gex85
Yeah, these P2-450 chips are hard to find at a decent price. It took me quite a few months (or even years) to find one for my 1998 build, they show up very rarely. A few weeks ago I got lucky again and found a second one, bundled with an interesting Siemens Nixdorf motherboard.
I like how clean your build looks, and the case with its blue accent looks very nice, too. 👍
But the way the power supply is mounted above the CPU area would be a no-go for me, I always hated that mounting style...
My retro computers
Reply 19 of 19, by ildonaldo
gex85 wrote on 2020-10-04, 15:37:
Yes they are hard to get - had to wait almost a year to get one for a reasonable price.
... I always hated that mounting style...
Me too, it always gets in the way with larger CPU coolers.
But for the CPU generation up to Pentium II it works fine.
