First post, by Intel486dx33
My Gateway computer will not start ?
It was working but has stopped working now.
The power button use to turn green when on but now it just stays yellow.
Any Ideas ?
Reply 1 of 6, by Errius
This is a LEX 700XL?
ETA: It's missing the FireWire port so is probably a ELP 500s
ETA2: Or a Performance 1000/1500
Is this too much voodoo?
Reply 2 of 6, by Horun
Intel486dx33 wrote on 2020-10-09, 23:08:
My Gateway computer will not start ? It was working but has stopped working now. […]
Any Ideas ?
Can you give a bit more info on the model and other specifics ? Stating "My Gateway computer will not start ?" is like saying: my Toyota (or any) car will not start, the dash used to have a green light but is now only yellow 😀
Reply 3 of 6, by leileilol
I'd assume the graceful OEM PSU death.
Reply 4 of 6, by Intel486dx33
Okay, it was the DVD drive must have had a short that was causing the computer not to turn on.
Reply 5 of 6, by Tetrium
Intel486dx33 wrote on 2020-10-10, 06:44:
What did you do to solve it? Did you replace it or did you simply disconnect it and then try to turn it on?
Because if it's the latter it might still be the PSU.
Btw, your case doesn't have a reset switch right? Or at least mine didn't come with one.
My retro rigs (old topic)
Report spammers here!
Reply 6 of 6, by Intel486dx33
I just replaced the DVD drive with a new one and the computer works again.
