bshi02 wrote on 2020-09-26, 06:38:
darry wrote on 2020-09-26, 05:51:
My understanding is that, according to page 76 of the manual, sending a "GM System On" SYSEX message to a JV-1080 should toggle it into General MIDI mode .
The SYSEX message to send is F0 7E 7F 09 01 F7 .
This is also known as a GM RESET .
Thank you very mcuh for your rapid reply! By the way,I always use SAVIHost for DAW in order to load vst plugin,and It seems that there is no options which is able to send SYSEX message of "GM System On" in its menu.
Is there any good method to send SYSEX message of "GM System On" in SAVIHost DAW?
You will need to send the SYSEX message file gmreset.syx using an application such as MIDI-OX or, simply play the GMRESET.MID MIDI file through the JV-1080 using a MIDI file player (SYSEX message is embedded).
This should work, if the emulated JV-1080 behaves like a real one . I have never used either, so I do not know .
The attachment gmreset.zip is no longer available
EDIT : I used MIDI-OX to create the SYSEX file and SYX2MIDI (DOS program) to embed it in a MIDI file . I have attached SYX2MIDI to this post in case somebody needs it . If there are better ways to embed SYSEX messages in a MIDI file, please let me know .
The attachment syx2midi.zip is no longer available
