Reply 240 of 675, by Mentat-vvo
- Member
Just leaving it here.
PPro250/Freeway694x/512M/Gf3/AdvGUS
SP750 2x P3Xeon900-2M/4Gb/V56k/Vortex2
K6III+400@624/P5A/256Mb/GF3ti200@500
Iskra 1031 Issue 2 - i8086 PC/XT Clone from USSR
Don't just leave it here, do something with it :p
So I just got outbid on a rev H chipset GA5AX, I am so sad.
Hope that someone on here got it at least!
I’ve recently got Ga5AA rev 2.2 and K6-2+ 550
Well, it is capable of running at almost 700 MHz ! However, I was unable to activate cache even at 100 MHz. The Cache memory was then replaced by 1Mb of 4 ns cache EliteMt from the post above. Looks like the tag sram is dead, because nothing was changed, no summary screen and boot with cache on.
PS 1MB cache was recognized in Tekram VIA MVP3 from-the-box, after the replacement of 512kb module. However, it does not work with cache on with any FSB settings. 1Mb of cache in GA-5AA was recognized as 512k. Gonna try that trick with Asus P5A. I am afraid that the cache modules were remarked from 7ns to 4ns (
Mentat-vvo wrote on 2020-07-21, 14:52:I don’t give a junk )) Stock bios was wasted by awdflash) I’ve found some bios and will try Plus CPUs with it tomorrow. […]
cyclone3d wrote on 2020-07-21, 14:48:So just use a EEPROM flasher to flash it back to the stock and/or reflash it with the modified BIOS.
I wouldn't necessarily just junk the board because of a bad flash.
Stock bios was wasted by awdflash) I’ve found some bios and will try Plus CPUs with it tomorrow.Update:
Freeway TI5VGF is a clone of TMC TI5VGF So, I flashed the mobo with TMC bios and , unfortunately , it was unable to run with more than 100 MHz FSB and cache on. Moreover, 3DMark2000 run caused reboot.Update2:
A DFI baby AT board K6BV3+/66 B1 (1Mb of fast cache) also ran well at 124 MHz FSB as my Epox 5MVP3G2 Mobo. A Sharptooth 450 tried some superPi @500 MHz. However, AGP power is also a problem here. And the mobo is unable to set 112,124 and 133 FSB via jumpers or from BIOS.
You can install a modified bios for the K6BV+3 that enables 112, 124,133 in Bios. Are you sure it also has the power problem? Which cards did you test on this board?
This board is from the 2000s and should already have a proper agp regulator installed, IIRC.
frankmonk wrote on 2020-10-27, 22:37:Mentat-vvo wrote on 2020-07-21, 14:52:I don’t give a junk )) Stock bios was wasted by awdflash) I’ve found some bios and will try Plus CPUs with it tomorrow. […]
01A988AD-4B89-4A06-80A3-914C828252C7.jpegYou can install a modified bios for the K6BV+3 that enables 112, 124,133 in Bios. Are you sure it also has the power problem? Which cards did you test on this board?
I sold that board, since I’ve got more powerful ATX ones. It was capable of running 124M with cache enabled, a good one, but baby AT is not my size.
Is this good enough?
Let's mod everything! Check my youtube channel:
https://www.youtube.com/channel/UCZ6ULBqIKhxuNslAbqFNJUg
Interested in my devices? Check my store:
https://migron-electronics.com
Thats awesome! Thanks for your contribution 😁
That 3dmark99 CPU score looks super good actually!
I see you were able to run the FSB at 124MHz with L3! Now that you can get a pat on the back for!
Skalabala wrote on 2021-02-12, 06:10:Thats awesome! Thanks for your contribution 😁
Thnx 😀
Unfortunately my K6-III+ does not go any higher 🙁
Hi
I was hoping to post some good results here but...
I have put together K6-3+ 450, Asus P5A-B 1.04 and GF3Ti200, powered the system, then wanted to add Ethernet card, so I turned system of, it switched off thanks to ATX power supply, but now it won't turn on. Even when I use AT power it doesn't start, CPU gets hot and power regulators get warm, so there is power on board. I have tried other CPU, ram and graphic card.
Is there any typical issue about this board that I should check? I have only multi-meter..
Have you checked the PSU rail voltages while your trying to start the machine? I'd also check for any kind of shorts from rogue screws or anything?
chrismeyer6 wrote on 2021-02-23, 02:56:Have you checked the PSU rail voltages while your trying to start the machine? I'd also check for any kind of shorts from rogue screws or anything?
I have checked it with two PSUs that works with other computers.
Today I wanted check it 4th time, connected every thing that works on other motherboard (MVP3) and it won't let PSU start, like overcurrent protection..
I thought I'd start with my 3d 2001 score before I switch cards to do 2000. Epox MVP3G-M, K6-2+ 550 @ 616, and an FX 5600.
After much fooling around, here are some more results. The K6-2+ CPUs I have that will do 616 end up scoring lower if I do 620 (5x124) because I have to disable the board's cache and slow the memory timings. The fastest K6-3+ I have is a 400 ATZ, but it won't do better than 560 (5x112), but this is still fast enough to best the K6-2+ @ 616. I also discovered that CPU Z locks up if ACPI is enabled in the CMOS settings; I also had this issue with my Soyo SY-5EMA and I thought that CPU Z just wouldn't work with MVP3 boards - by chance I had ACPI disabled on this board and CPU Z worked, then I had to reset CMOS and it no longer did (ACPI is enabled by default). Ignore that voltage setting in CPU Z - it's set to 2.3, but it's misreported in the CMOS settings as well. The GeForce 3 I have isn't a great overclocker, the best it can do it 209 core and 473 memory. To climb any higher I would need a fast GeForce 3 and a faster K6-3+, but I've spent more than enough on this as it is.
Maybe I'll take it apart and put in a GeForce 2 but for now this is my k6-3 with voodoo3 pci
My current best score is: 1666
This is K6-3+ @ 500MHz with a Voodoo 3 2000 PCI.
mwdmeyer wrote on 2021-04-26, 02:32:My current best score is: 1666
I think this is exactly the score I got 😁
On another note I got delivery of a Geforce 2 Ultra today!!! Its dead though so I hope I can repair it!
That is good results @Repo Man11 😀
Sad that your K6-2+ does not want to hit 660-720Mhz 🙁
I also have the MVP3G-M This board hates to boot in an overclocked configuration, If I overclock it in windows I got to 682MHz on K6-3+ Not stable at all though. Think 5*124 worked or it was 5.5*112
Also I recently found a GA5AA 3.2, dead though. But caps seem to be not happy, hope I can fix it 😀
My GA-5AX with K6-3+ 400@580 and Voodoo3 3000 AGP (no OC)
The big scores come from nvidia geforce 2 and 3 cards, so use those.. 3dfx isn't that much slower but for some reason the nv cards with the right driver are a golden combination for this project. Beating the highest scores you'll probably need around a k6-3+ @660mhz or higher and an overclocked card and all the right bios tweaks and registry settings.
lukas12p wrote on 2021-05-10, 10:29:My GA-5AX with K6-3+ 400@580 and Voodoo3 3000 AGP (no OC)
That is a good score 😀
