About Roland Virtual Sound Canvas 3
Reply 100 of 377, by mattw
i am totally stuck, i hope someone will come with some idea about SC55ROM "pcm data address map" and how the PCM samples are addressed - there is nothing there that resembles address 0 to me. So, I saw in MAME:
https://git.redump.net/mame/tree/src/mame/dri … roland_sc55.cpp
IC28 Waverom is mapped to address 0x300000 (or is it that the total size is 0x300000?!), but again I see nothing in "pcm data address map" of SC55ROM that resembles such address - I mean after all we need to have 1MB of PCM samples between address 0x300000 and 0x400000 and thus there has to be many (0x300000 + some_offset) addresses, but I see none. It's too bad IC30 is not dumped and probably it's very hard to be dumped, maybe as hard as what I mentioned here:
Re: Sound Bank rom dumps - how are made?
So, without IC30 we're most likely totally blind regarding what's really going on...
Reply 101 of 377, by mattw
and here:
https://git.redump.net/mame/tree/src/mame/dri … oland_cm32p.cpp
there is UNSCRAMBLE_ADDRESS and UNSCRAMBLE_DATA for CM32P - it seems different than CM32L that we already discussed.
and CM32P is PCM compared to CM32L that is LA-synth. So, at least to me it's the fist time I see how exactly Roland scrambled data in one of their PCM devices.
[EDIT] and here:
https://git.redump.net/mame/tree/src/devices/ … d/rolandpcm.cpp
is another code used for CM-32P.
Reply 102 of 377, by mattw
BTW, anyone, where I can get CM-32P ROM dumps?
[EDIT] never mind, I found it, I am not posting link, because after all it's copyrighted material. I just want to look at it in order MAME code to make more sense to me.
Reply 103 of 377, by mattw
CM-32P scrambling is more sophisticated than VSC, because it changes both the address and the value, while VSC "block2" 2nd layer encryption changes only the address. Interesting that even addresses they change using bit-swapping. So, bit-swapping they really love - use it everywhere.
Reply 104 of 377, by mattw
if i ported the mame code correctly (attached) to see how the indexes (addresses) are changing, the CM-32P scrambling algo on the indexes (addresses) is different than what VSC is doing, but is there bit-swapping that will give this sequence of indexes:
Re: About Roland Virtual Sound Canvas 3
Reply 105 of 377, by mattw
just in case someone is interested in CM-32P samples, I believe I did ported all of the ROM descrambling from MAME - attached.
see decode_sample() function from here:
how the samples are converted to playable PCM - it's essentially the same as what I said in previous posts about Yamaha TG100 and SC55 - they are using packed 12-bit samples.
Reply 106 of 377, by mattw
hmm, applying MT-32 bit-swapping to SC55ROM results in really interesting patterns (and they repeat and repeat through the whole data stream) - screenshot attached.
so, maybe bit-swapping of SC55ROM is the same as MT-32, but we have also byte-scrambling, i.e. each byte is on a wrong place like with CM-32P...
    43.51 KiB
Reply 107 of 377, by mattw
"IC23" ROM contains 2 demo songs as well "Jazz Lagoon" - at offset 0x88ac and "Leya's Song" at offset 0xd174 - they are stored as complete MIDI files with header and everything. So, you can just copy the byte sequence and paste it to a file. Also, I found the related portion of "IC23" ROM H8/500 assembler code - it's pasted below. If by any chance the descrambling algorithm is in IC23 (and not in IC30), then we still have a chance ...
ROM:74A8 ! ---------------------------------------------------------------------------
ROM:74A8 mov:i.w #0x88AC:16, r4
ROM:74AB cmp:g.b #0:8, @byte_CF8C:16
ROM:74B0 beq loc_74BF:8
ROM:74B2 mov:i.w #0xD174:16, r4
ROM:74B5 cmp:g.b #1:8, @byte_CF8C:16
ROM:74BA beq loc_74BF:8
ROM:74BC mov:i.w #0xF37F:16, r4
ROM:74BF
ROM:74BF loc_74BF: ! CODE XREF: ROM:74B0j
ROM:74BF ! ROM:74BAj
ROM:74BF add:g.w #0xC:16, r4
ROM:74C3 ldc.b #4:8, ep
ROM:74C6 ! assume ep:4
ROM:74C6 mov:g.b @r4+, r0
ROM:74C8 mov:g.b r0, @byte_CF8A:16
ROM:74CC mov:g.b @r4+, r0
ROM:74CE mov:g.b r0, @byte_CF8B:16
ROM:74D2 ldc.b #0:8, ep
ROM:74D5 ! assume ep:0
ROM:74D5 add:g.w #9:16, r4
ROM:74D9 mov:g.w r4, @word_CF84:16
    153.73 KiB
Reply 108 of 377, by yawetaG
What's interesting about demo songs on many hardware units is that the synth often does not output MIDI data while playing back the songs, even if ostensibly the songs are stored as MIDI data in ROM - probably a form of copy protection. I guess it will be the same on the Virtual Sound Canvas.
Reply 109 of 377, by mattw
I followed the code in VSC.DLL and it seems to me the 2nd layer decryption is removed in _WriteWaveBuf() function, which calls VSC.VXD. So, it seems to me the 2nd layer decryption is done in the VXD. I cannot find any other tool that is capable to show "Device Descriptor Block" (DDB) of VXD and its "Service Table" except VXDasm:
http://jls.chez.com/vxdasm.html
Unfortunately, it's long gone, i.e. all the links to it are dead, even using the web-archives of the website. that's huge obstacle at the moment. my idea was to write some small client that is capable to hook to the VXD and do the decryption using similar idea to this one:
http://ivanlef0u.fr/repo/madchat/vxdevl/vdat/tumisc71.htm
It's the first time I meet with VXD and maybe there are other options, but I just don't know them...
[EDIT] actually, this:
https://www.hex-rays.com/products/ida/support … orials/idc/vxd/
helps a little, i.e. it allows immediately to identify that the "VXD ID number" of VSC.VXD is 0x392E and based on that (with simple search for 0x392e) to find the corresponding code in VSC.DLL:
cseg01:2E56 loc_2E56:                               ; CODE XREF: _LoadVxD+57j
cseg01:2E56 push 392Eh
cseg01:2E59 call sub_2E9A
cseg01:2E5C add sp, 2
cseg01:2E5F mov word ptr _VscVxdAPI, ax
cseg01:2E62 mov word ptr _VscVxdAPI+2, dx
cseg01:2E66 mov ax, dx
cseg01:2E68 or ax, word ptr _VscVxdAPI
cseg01:2E6C jz short loc_2E74
cseg01:2E6E mov ax, 1
cseg01:2E71 leave
cseg01:2E72 retn
Reply 110 of 377, by mattw
Interesting, very interesting I did the simplest patch possible - just remove the 2 calls to _WriteWaveBuf() function (which calls the VSC.VXD) in VSC.DLL:
E8 75 FC --> 90 90 90
E8 BE FB --> 90 90 90
and the whole Soundbank remained encrypted in RAM dump, i.e. it's the same as the file on the HDD. So, it seems I was wrong and not only the 2nd layer decryption, but the 1st layer as well, is done in the VXD. I wonder considering 1st layer decryption is so simple if I can find the code where that is done in the VXD, because at least 1st layer algo is known.
BTW, maybe the above solves what I suggested here:
and maybe the above patch allows to use unencrypted Soundbanks, because their on-load decryption is disabled. TODO: try that, because it's very convenient to use unencrypted Soundbanks.
Reply 111 of 377, by mattw
hmm, I am not sure if I am on the right track, i.e. if removing the 2 calls to _WriteWaveBuf() removes the on-load decryption or messes-up something else that causes no on-load decryption, because in the VXD the only place I can find something that resembles 1st layer decryption is very complicated assembler code that is using MMX instructions. Also, I cannot find anything that looks like 1st layer decryption in the VXD from VSC 1.x. So, I guess I need to re-do the above experiment, but using VSC 1.x and see what will happen.
Reply 112 of 377, by mattw
mattw wrote on 2020-10-19, 19:30:
disappointment - no, there is no sound with unencrypted bank and the patch. So, it's more destructive than I expected 🙁
Reply 113 of 377, by mattw
Until now, I was using Win98, because even 16MB RAM are enough and that makes "RAM dumps" compact and easy to search - that was essential until figure out how to obtain decrypted SoundBank from the RAM dump. However, at this point, I start to think that now holds me back, because things like VSC.VXD are really hard to work with for reverse-engineering - at least it's hard to me. So, I think it's time to switch to WinXP and try to understand more, but this time using VSC.SYS - I already determined ExAllocatePoolWithTag() function is called in VSC.SYS with Tag of 0x206B6444. Maybe, I can use that with SoftICE to break on that memory allocation and trace the execution from there. I think that's really good idea, but it will take me a lot of time to setup - for one, I've never used SoftICE and have no idea at the moment how to set breakpoints when particular driver, like VSC.SYS, calls ExAllocatePoolWithTag(). How hard or easy that to be done is unknown to me at the moment, but it has to be possible.
Reply 114 of 377, by mattw
OK, switching to WinXP was very fruitful , here are the key points:
* 64MB RAM are enough, performance is not great, but who needs performance when understanding assembler code to reverse-engineer requires hours of scratching your head. it's good compromise though, because 64MB still makes RAM dumps feasible (if such are needed), even at the moment I see no point of RAM dumps, because using Win98 and RAM dumps I already have decrypted copies of all the Soundbanks. So, what is the main open question is the actual scrambling algorithm, because that can gives ideas for the SC55 Waverom scrambling.
* with several (actually many) trial and errors, I determined only 3 files are required: "Vsc32Cnf.exe", "vscapi.dll" and "vsc.sys"
* from here on it was very easy to determine several very important findings:
"Vsc32Cnf.exe" calls function CSynth::LoadWaveTable() from "vscapi.dll", then
using DeviceIoControl() 2 calls to "vsc.sys" are made:
IOCTL_VSC_LOAD_WAVE_TABLE
IOCTL_VSC_INITSYNTH
I bet all the decryption is done in IOCTL_VSC_LOAD_WAVE_TABLE, but it really narrows down where to look. Another (even easier) option is the decryption is done in CSynth::LoadWaveTable(), before it calls IOCTL_VSC_LOAD_WAVE_TABLE via DeviceIoControl(), but that is less likely.
Reply 115 of 377, by mattw
oh, boy, SoftICE requires specific VGA driver to work and it fails in my WinXP setup, works in my Win98 setup, but there I am lost, because of the VXD use.
hmm, I wonder how hard would be to make fake vsc.sys that exports IOCTL_VSC_LOAD_WAVE_TABLE and IOCTL_VSC_INITSYNTH and that way dump what data "vscapi.dll" passes when those are called.
Reply 116 of 377, by mattw
Unbelievable, I think I finally cracked the 2nd layer encryption, i.e. the byte shuffling VSC is doing. I am still struggling to translate the corresponding assembler code to properly working C code to fully confirm the success, but I am very positive this time I really did it. Maybe, in few hours or tomorrow I will be able to release proof-of-concept working code, i.e. new version of "vscdec". I still cannot believe with my small brain I went thus far...
Reply 117 of 377, by mattw
"vscdecv4.c" - the code in C that can fully decrypt any VSC Soundbank is attached. Enjoy!
it removes all the encryptions - 1st and 2nd layer one and all the sounds are playable PCM data - in the next days when my free time allows I will make small tool that writes (or extracts) each sound to a playable WAV file.
P.S. it's also very nice that's my 100th post here 😀
Reply 119 of 377, by mattw
cyclone3d wrote on 2020-10-21, 23:44:
Awesome work!
thanks, now if we crack SC55 Waverom byte scrambling, we can make real SC55 Soundbank for VSC. Unfortunately, with SC55 ROM we have almost no clue, because there is very good chance the scrambling algorithm is in IC30 of SC55, which is not dumped, because no one knows how to dump it. However, as I mentioned before if it's in IC23, then there is real hope.
