First post, by keithktam
hi, my name is keith.new to dos box, i have read the faq, understand the problem.However, my computer is 2.4Ghz and 1GB ram, and a 3d graphic card, I still can't play a mere Syndicate Wars.I mean my computer is 10 generation after the game, I am sorry, I am just frustrated. Disperate for help.i am running win xp by the way.thank you
keith 😢
Reply 1 of 9, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
What did you change in dosbox.conf so far?
1+1=10
Reply 2 of 9, by keithktam
Well... i have no idea.sorry.i just don't know what is "dosbox.conf".what does it do??
keith 😕
Reply 3 of 9, by eL_PuSHeR
keithktam. Welcome to the forums.
dosbox.conf is a TEXT file located inside the DOSBox folder and it serves as configuration file. You can edit it (with Notepad, for instance) and fine tune DOSBox by changing some parameters.
You should take a look at it (revise documentation too) and ask here afterwards if you have got some further questions.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 9, by keithktam
I have sucessfully opened the dosbox.conf with the notepad, and have taken a look at it.What should i do now?
keith
Reply 5 of 9, by eL_PuSHeR
Well, for starters, change these lines...
output=overlay
You could also try ddraw and Opengl. For ATi cards overlay and ddraw seem to be the best. For nVIDIA cards, you can try Opengl. In my opinion, I like overlay most, because I do not like bilinear filtering used in ddraw and Opengl (although there is also a Openglnb - without bilinear filtering).
Then adjust speed:
core=dynamic
cycles=auto
There is also an autoexec section at the end of the file. It's used to auto execute parameters when starting DOSBox. Mainly used for writing mounting commands there.
E.g.
mount c c:\oldgames {The Hard disk}
mount d h:\ -t cdrom -iotcl {The CD-ROM}
Exit and save changes.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 6 of 9, by keithktam
eL_PuSHeR wrote:
Well, for starters, change these lines... […]
output=overlay
Then adjust speed:
core=dynamic
cycles=auto
Thank you very much.It works so much better now...must be magic...
However,the game is just a little bit slow,it is not so smooth.
would be grateful if u can help me just a bit more.thank you
keith 😁
Reply 7 of 9, by Xelasarg
You ARE aware that DOSBox is an emulator, aren't you!? The emulation process consumes a LOT cpu power, i.e. you can emulate something like a 486/66 MHz at the most on your 2.4 GHz machine - which means you only meet the minimum requirements for Syndicate Wars. I doubt you'll be able to run it smoothly through DOSBox unless you switch to 320x200 mode.
"What's a paladin?!"
Reply 8 of 9, by keithktam
Ah,I see. 😦
