Capacitor Replacement
First post, by Smack2k
I am working on replacing some capacitors on a few video cards...
If the capacitor on the card was 1000uF 125 Degrees C, 6.3V, putting a 1000uF 105 Degrees C, 6.3V in its place would not be a good idea?
Just curious as I have 105 Degree capacitors.......not 125.
Reply 1 of 6, by gdjacobs
Smack2k wrote on 2020-10-27, 00:25:
It really depends how cool the air around the caps is. If the caps run well below 105 degrees, how long they last probably won't be paced by heat stress. If the board they're on runs hot and it doesn't get much air flow, you'll probably want the better caps.
The bigger concern is matching ESR. Depending on the application, ESR out of tolerance can result in high ripple voltage or unstable feedback circuits.
Reply 2 of 6, by Smack2k
The caps I have are rhe sane except for temp rating.
I cant locate any 6.3 v 1000uf 125 degree caps is another issue. Everywhere i look is 105
Reply 3 of 6, by debs3759
Digikey have some 1000uF 125 C 10V, if they are the right size. I can't find anything closer to your needs, unless cans are OK.
Reply 4 of 6, by quicknick
ESR and ripple rating are more important. Although you get more reliability from the higher rated ones, my take is that if any capacitor gets close to 105° (let alone 125°C) during normal use it means the cooling isn't up to the job.
Reply 5 of 6, by jmarsh
Agreed, they really shouldn't be getting anywhere near that temperature for it to be an issue.
Reply 6 of 6, by Smack2k
Thanks for the tips and assistance!
