Reply 20 of 24, by yawetaG
derSammler wrote on 2020-04-01, 18:21:I'm not even sure if you can use more than 16 channels over the serial connection, as the data rate is not high enough for that...
Some serial MIDI drivers can send more than 16 channels over a serial connection if you enable specific options...
