First post, by chrisNova777
does anyone know where to get these cables in 2020? im not sure what to type in to eBAY to get it to come up;
or where else to search;
my interest stem from a 1999-2000 era motherboard that i have here that i happened upon a game-port breakout cable to attach to the motherboard header
then ir ealized theres also a number of CD-IN, AUX-IN, MODEM-IN audio connectors that i could be making use of either from seperate internal sound cards or external audio devices
routed thru the motherboards mixer if i had the appropriate cables
Reply 2 of 6, by Jorpho
chrisNova777 wrote on 2020-11-03, 19:44:
I don't think internal sound cards generally have outputs that you could easily connect that way.
Reply 3 of 6, by chrisNova777
Yes they do it’s a standardized connection for audio from the 1990s
Reply 4 of 6, by GigAHerZ
When nothing else works, dupont cables would do the job. 😉
Reply 5 of 6, by Jorpho
chrisNova777 wrote on 2020-11-04, 12:31:
Yes, it's a standardized connection - but that doesn't mean you'll find it as an output on an internal sound card. I'm looking at the CT4830 I happen to have handy, and it has connectors for TAD, CD_IN, and AUX_IN, but there's no 4-pin output.
Reply 6 of 6, by andrea
Jorpho wrote on 2020-11-04, 16:15:
I have seen several soundcards that have unpopulated through-holes for 2.54mm headers in parallel with the rear jacks. As you say it's not a standard feature, but if OP is lucky it can be done.
