DOSBox-X branch
Reply 1980 of 2428, by Wengier
jmarsh: Thanks for pointing out the probable cause of the issue, and you are certainly very familiar with this part of code. If you also know how to actually change this code to fix the said issue please let me know. Thanks a lot!
Reply 1981 of 2428, by gfernval
Hello:
I have compiled Dosbox-X 0.83.7 for running in Windows XP (SDL2 version) DIAGNOSE.EXE now works, but sound in Windows 3.1 not.
Why both DIAGNOSE.EXE and sound in windows 3.1 work in 0.82.18 but not in newer versions?
Reply 1982 of 2428, by gfernval
It seems network connection does not work well (worked well in 0.83.6). If you enable network card and
in MS-DOS run:
lsl
ne2000
ipxodi
running ipxodi shows "IPXODI-303-12: The IPX protocol has already been loaded" (when was loaded?)
if I now run "netbios" Dosbox-X 0.83.7 hangs
Reply 1983 of 2428, by gfernval
Hello:
What about the config settings dosbox-x.conf? in version 0.83.6 the file was 177kb, and in 0.83.7 only 44kb.
In version 0.83.6 you could specify the MAC address of the network card, but in 0.83.7 you can´t.
Ethernet passthrough in 0.83.7 does not work well, after loading lsl.com and ODI ne2000.com, when you are going to
load ipxodi computer says "IPX already loaded", and if you run netbios.exe after ipxodi.com dosbox-x hangs.
Sound does not work in Windows 3.1, time to wait to make a DMA recording fix. Will stay with version 0.83.6 due
to the problems in networking in 0.83.7 version.
Reply 1984 of 2428, by _Rob
gfernval wrote on 2020-11-02, 19:29:
Hello: […]
Hello:
Regarding the config file, with the latest version there is now a full config file and a partial config file with the more common options. This was meant to be less confusing to the average user as the full config has too may options listed. And you are undoubtedly looking at this partial config. And just because the config does not mention some option, does not mean you cannot add it. Any option not listed will just use the default for that option. You can also generate a full config by typing:
config -wcd -all
Reply 1985 of 2428, by Wengier
gfernval: About the ipxodi issue, I have already fixed it in the latest code. Please check it out.
Regarding the sound, the fix was specifically for DIAGNOSE.EXE. I will check the Win3.1 SB16 driver later.
For the config file, as _Rob already mentioned all config settings are still (and will continue) working, but there are now simply two sample config files, namely dosbox-x.reference.conf (for average users) and dosbox-x.reference.full.conf (for advanced users). Just choose the one you prefer to look at.
Reply 1986 of 2428, by gfernval
The mingw compiled downloads and DOS compiled downloads are missing, the actual ones for download (Visual C compiled) don´t work in Windows XP. The file dosbox-x.reference.full.conf is not available for download nor inside dosbox-x-vsbuild-win-20201101082314.zip or dosbox-x-windows-0.83.7-setup.exe, but I have recreated it with "config -wcd -all" as _Rob mentioned.
The Latest code is the GitHub code (dosbox-..-master.zip) or dosbox-x-v0.83.7.zip? I have compiled the code inside dosbox-x-v0.83.7 and ipxodi does not work.
thanks
Reply 1987 of 2428, by Wengier
gfernval: Both MinGW builds and DOS packages are now downloadable from:
32-bit MinGW: dosbox-x-mingw-win32-20201103082126.zip
64-bit MinGW: dosbox-x-mingw-win64-20201103091449.zip
DOS package: dosbox-x-mingw-hx-dos-20201103155348.zip
IPXODI should work in the above builds.
For the Visual Studio builds, you must be using an older version of the package. The file dosbox-x-vsbuild-win-20201101082314.zip was already updated yesterday to include the dosbox-x.reference.full.conf file (alongside dosbox-x.reference.conf). The dosbox-x-windows-0.83.7-setup.exe file will install both of them.
The latest code refers to the GitHub code, not dosbox-x-v0.83.7.zip. Unlike the Visual Studio builds which were based on dosbox-x-v0.83.7.zip, the MinGW builds are compiled using the current GitHub code. But the IPXODI fix is the only functional difference between them.
Reply 1988 of 2428, by gfernval
I have tried to change the following from file dosbox.cpp and compile a new dosbox-x.exe
static void CheckX86ExtensionsSupport()
#if defined(__GNUC__) && !defined(EMSCRIPTEN)
sse2_available = __builtin_cpu_supports("sse2");
avx2_available = __builtin_cpu_supports("avx2");
#elif (_MSC_VER) && !defined(EMSCRIPTEN)
Bitu a, b, c, d;
cpuid(1, a, b, c, d);
sse2_available = ((d >> 26) & 1)?true:false;
avx2_available = ((b >> 5) & 1)?true:false;
#endif
to:
sse2_available = false;
avx2_available = false;
#endif
unfortunately the resultant dosbox-x.exe does not run in Windows XP with Pentium III CPU, it is not as easy to change the above lines
Reply 1989 of 2428, by Wengier
gfernval: Do the official MinGW build(s) run on your Windows XP system?
Reply 1990 of 2428, by gfernval
Windows XP in a Pentium IV machine: works (only SDL2 build)
Windows XP in a Pentium III machine: do not work (SDL1 or SDL2), latest version that worked on a Pentium III machine was 0.83.4
Reply 1991 of 2428, by gfernval
If possible try to make a patch for working sound in Windows 3.1 in the next dosbox-x version.
thanks
Reply 1992 of 2428, by gfernval
It is necessary to make a patch for every program that uses sound in a "per program" basis?
Cannot make a patch for all programs that use sound (in windows or dos)?
thanks
Reply 1993 of 2428, by K.A.R.R.
hi
i just wanted to report a small bug with dosbox-x.
monkey island enhanced cd version has a problem with cd audio.
audio is playing perfect until u talk to a pirat in the scumm bar.
instead of music u hear only cracks and noise until u leave the bar and the cut scene with le chuck begins.
prob happens with ece r4390 as well.
with normal svn r4390, staging 0.75.2 and with 0.74-3 it plays without the problem.
(i reported this bug in dosbox ece thread aswell
Re: DOSBox ECE (for Windows & Linux) )
btw: nice that dosbox-x has a gui
but it could be a bit more comfortable for e.g. with soundcards.
to change the soundcard for e.g. from sb16 to gus i have to go to configuration tool
disable soundblaster and enable gus
but i also have to set the ultrasnd values and gus dir manually in the dosbox-x.conf file under autoexec
(same with blaster values for sb cards)
would be nice if this is done by dosbox-x automatically when selecting a soundcard in the configuration tool
Reply 1994 of 2428, by cyclone3d
1993 replies - DOS 6.0 - 6.2:
The attachment DOSBOS-X-1993-replies.jpg is no longer available
And this is the 1994 th post, the year when DOS 6.21 and 6.22 was released.
Just thought it was kinda interesting and decided to mention it.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 1995 of 2428, by Wengier
K.A.R.R.: Thanks for reporting the CD audio issue with Monkey Island CD version! I could confirm the issue and have already fixed it in the latest DOSBox-X code. Thanks kcgen for the fix logic.
I will look at your soundcard setting suggestion later.
Reply 1996 of 2428, by Wengier
gfernval: I only knew DIAGNOSE.EXE had this issue before, and that is why I specifically fixed it for DIAGNOSE.EXE. If there are more programs with this issue then I can make a different approach before the DMA recording function is properly implemented.
Reply 1997 of 2428, by gfernval
Windows 3.1 sound does not work. In theory when DMA recording function is properly implemented the sound in all programs will work, right?
Reply 1998 of 2428, by Wengier
gfernval wrote on 2020-11-06, 19:36:
Yes. The DMA transfer limit was enforced in earlier versions, and in DOSBox-X 0.83.7 I specifically added an exception for DIAGNOSE.EXE to allow it, which is why DIAGNOSE.EXE works but others (if exist) may not (I can add more exceptions of course). But when DMA recording function is properly implemented all such programs should theoretically work.
Reply 1999 of 2428, by Wengier
cyclone3d: And this is the 1999 th post, the year when the final version of DOS 7.1 was released.😀 DOSBox-X well supports DOS 7.1 features such as long file names and FAT32 disk images.
