Reply 36760 of 59792, by PTherapist
Got something relatively less common and most importantly affordable, which arrived today -
4x 256K SIPP RAM chips.
I have an 8088 motherboard that accepts these 256K chips and currently only has 1 stick of 256K (since I lost or damaged the other 3).
Going to see if I can at least get the board to 512K, as I'm not sure what would happen if I put 3x 256K sticks into the board, would it fail to POST or simply max out at 640KB?
The board has 4 banks and originally had 2x 256K & 2x 64K sticks, giving me the total 640KB.
Reply 36761 of 59792, by devius
PTherapist wrote on 2020-11-05, 15:33:
The 8088 can address up to 1MB. Doesn't mean the motherboard will actually support it though.
Retro Coisas no YouTube
Reply 36762 of 59792, by RichardG867
Shuttle FV24 motherboard + Coppermine 1000 + 512MB RAM. Found this set on the local eBay for a reasonable price many months ago in a random Google search(!); the motherboard caught my attention because it's a fully integrated Socket 370 board not much bigger than ITX. It could fit in an ITX case with enough wiggle room.
Unfortunately the integrated VIA graphics chip is unstable, crashing to a black screen sometimes after POST and all the time when opening the display driver properties on Windows XP. These Shuttle boards appear to be notorious for bad capacitors, so I guess a recap is in order, even though the caps all look fine. There could be more issues, but I don't have PCI graphics cards to test on this board.
Reply 36763 of 59792, by kolderman
RichardG867 wrote on 2020-11-06, 00:09:
If that had an ISA slot instead of PCI and the integrated graphics worked OK that would be a pretty awesome board.
Reply 36764 of 59792, by bjwil1991
Got the Biostar board yesterday and cleaned off a lot of corrosion off of the board. Next on the list: new resistors and 30AWG wire to patch the broken traces.
Reply 36765 of 59792, by HanJammer
Got something relatively less common and most importantly affordable, which arrived today - […]
Those are SIMMs converted to SIPs (not that it matters - they are pin compatible). I still have a few of those pin kits which allow for such conversion. Nowadays I see people use the goldpins for this purpose which isn't a perfect solution.
Reply 36766 of 59792, by CMB75
imi wrote on 2020-11-04, 19:42:
ok... I finally did it, prices have been steadily rising and I just couldn't take it anymore... my bank account hates me right n […]
ok... I finally did it, prices have been steadily rising and I just couldn't take it anymore... my bank account hates me right now.
Awesome machine, absolutely ... going to keep longing for one. I think I need to watch Steins;Gate now to calm down 😉
Reply 36767 of 59792, by mpe
Got two 486 DX2-66 overdrive CPUs. ODPR version and ODP (the one with extra pin everybody seems to be so confused about):
Blog|NexGen 586|S4
Reply 36768 of 59792, by SaxxonPike
Moogle! wrote on 2020-11-03, 01:44:
SaxxonPike wrote on 2020-11-02, 22:01:
Remembered something unusual I had acquired as a curiosity some time ago: a Trio3D/2X. Why should anyone care about these cards? Well, this one is a little unusual.PXL_20201102_215533447.jpg
Hint: these are typically only found as AGP.
Those came after the Virges, didn't they?
Yeah. They are effectively Virges, but (iirc) with updated 2D capability and lack of S3D support. Nothing really notable about them. Just this atypical card. 😀
Sound device guides:
Sound Blaster
Aztech
OPL3-SA
Reply 36769 of 59792, by PTherapist
devius wrote on 2020-11-05, 23:10:
Couldn't find any exact info about the motherboard, but it does indeed regcognise 640KB with the 4 chips installed and apparently there may be a jumper to allow the remaining RAM to be used in some capacity, ie. RAM drive etc.
HanJammer wrote on 2020-11-06, 09:20:
You know, I never even thought of conversion as a possibility. I have a drawer full of 30-pin SIMMS, albeit 1MB chips 🤣.
Reply 36770 of 59792, by Predator99
Didnt expect to win this for 60€...not bad 😀
The attachment IMG_1349r.jpg is no longer available
The attachment IMG_1350r.jpg is no longer available
Reply 36771 of 59792, by chrismeyer6
Is that first picture all cache/coast modules?
Reply 36772 of 59792, by debs3759
Looks like it. A rare find, hope there's some 512KB in there 😀
Reply 36773 of 59792, by Predator99
Yes, indeed. Was also surprised to see that amount of Coast modules in a "gold" scrap lot. On top there are many 30 pin SIMMs.
Reply 36775 of 59792, by brostenen
Not vintage hardware as such, yet for use with vintage hardware.....
I have ordered a pair of Logitech Z-240 speakers. Anyone know how they perform when hooked up to vintage computers?
Reply 36776 of 59792, by luckybob
cyclone3d wrote on 2020-11-06, 22:33:
Wow... I paid over $50 for a specific 512KB module to work in an ASUS dual socket 7 board I have.
Great find!
you also promised benchmarks, if I recall correctly.
Reply 36777 of 59792, by cyclone3d
luckybob wrote on 2020-11-06, 23:31:
Great find!
I did. Haven't gotten around to messing with it anymore yet though.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 36778 of 59792, by imi
Predator99 wrote on 2020-11-06, 19:17:
so you did get them :3 nice
some random stuff...
YMF card with QDSP1000, needs a good bath ^^
Aztech Sound Galaxy BXII
The attachment hardware39_69.jpg is no longer available
Yamaha DB50XG :3
The attachment hardware39_70.jpg is no longer available
and this oddity I absolutely had to have x3
The attachment hardware39_71.jpg is no longer available
Reply 36779 of 59792, by A001
SE440BX-2 manufactured 51/98 I assume?
The attachment IMG_3632.JPG is no longer available
