First post, by pete8475
- Oldbie
Specs:
AT Case / Coolermaster ATX Power Supply
A-Corp 6BX86 Motherboard
Pentium 3 600
512MB SDRAM
16GB Compactflash
Geforce 4 MX440 128MB AGP
2 x Diamond Monster 3D II 8MB (with homemade SLI cable)
Soundblaster AWE64 Soundcard
OS is 98SE, the case was used before to house my K6-2 machine but I decided to upgrade that a bit and get some use out of my Voodoo 2's again. I'm waiting for a Startech USB 2.0 card to come so I can hook up the front USB ports I added, the motherboard USB 1 ports are connected to some ports I added on the back. I'm also planning on changing to a front mounted Compactflash IDE drive instead of the slot version in the back.
Interestingly the USB ports on this A-Corp board aren't quite the normal pinout, one row is the reverse of the other.
I also had to move some pins around in a PS/2 port to get it working, luckily there was a decent thread about that on here and this board seems to follow one of the "standards" for that stuff. This was the thread - Help with PS/2 mouse header connection - wiring for SS7 MB.
aka pete4237.5
