Blank Screen
First post, by Alzoth
Im running XP with VDMSound, syndwfix, and a DOS4GW(~260k)(265,396), the added info to Play.BAT, changed the CD info drive location to install location, and copied all the files in the main directory on the CD into the DATA folder in the install location.
When i start up Play.BAT with VDMSound i go through the motions of the sound setup and press done. Now Main.exe is loaded and i can hear the bullfrog sounds from the intro logo, and the intro plays at normal sound speed ; if i press any key it goes to the login page. . . i know this cuz i can hear it.
The problem is, the entire screen is blank!!!!!!!!!! I just cant seem to get this thing running. HELP
Reply 1 of 2, by eL_PuSHeR
Try replacing DOS4GW with DOS32A and use DOSBox.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 2, by Alzoth
I replaced the file. Still getting the same slow gameplay w/ dosbox
