Also guys do I need service packs for se or anything like that?
I would avoid unofficial "service packs" which often involves replacing system files with those from later Windows versions to enable features you probably don't need.
Perhaps mass storage drivers / USB 2.0 support could be handy. Down to your use case.
Otherwise, Windows 98 is usually best with as little variables as possible for instability.
Screw period correct; I wanted a faster system back then. I choose no dropped frames, super fast loading, fully compatible and quiet operation.
If you want to use over 512MB of RAM you'll want to install at least the base Unofficial SP3 package. Some programs can still have issues but it's been stable in my experience. I personally skip the other packages.
I also recommend installing the universal USB storage driver. Having a USB drive mount just by plugging it in is so nice. I forgot how bad USB support is on 98 until I went back to it.
BushLinwrote on 2020-11-11, 20:32:I would avoid unofficial "service packs" which often involves replacing system files with those from later Windows versions to e […] Show full quote
I don't know of any software for Windows 98 that would need more than 512MB of RAM but if you have more than 512MB RAM and want to make Windows 98 stable by simply limiting how much RAM it can access you can just edit your system.ini to include a MaxPhysPage value like so:
1[386Enh] 2 3MaxPhysPage=20000
These are some possible values for MaxPhysPage:
960 MB MaxPhysPage=3C000
768 MB MaxPhysPage=30000
512 MB MaxPhysPage=20000
384 MB MaxPhysPage=18000
2 […] Show full quote
BushLinwrote on 2020-11-12, 01:22:These are the official USB 2.0 drivers from Intel and I'd recommend them, probably not of much use on a non-Intel chipset:
https […] Show full quote
I will probably get a usb 2.0 pci card just because my board only has 1.0 which stinks so I could just get the product and then download the drivers from the model itself too 😀
Also do I technically even need to install the onboard sound drivers just because I will not be using anything going into the mb because the soundblaster itself will be hooked in with the drivers for that.
In a word, no.
You could install the drivers and disable the device perhaps if you were setting up for someone else but disabling the device without driver installation is cleaner.
If you aren't going to use the onboard sound, go into the BIOS and disable it there so it doesn't take up IO and IRQs. That could prevent a conflict with other hardware.
