MP-32 : Pi based MT32, GM, ... module
Reply 60 of 103, by keropi
quovadis11 wrote on 2020-11-13, 10:41:
p.s: Do you have any plans for a 5.25 slot enclosure? I have a great ambition to install inside my retro computer and connect it with a 26 pin IDC Wavetable cable.😀
wow that is actually a very neat idea! 😮
Reply 61 of 103, by appiah4
keropi wrote on 2020-11-13, 11:01:
I think a better idea would be an eventual wavetable daughterboard model that will have the raspberrypi connected directly on top of it and powered by the PSU's 5V Rail.. Kind of like a 2 slot wavetable solution.
Reply 62 of 103, by matze79
Why not make directly a ARM based Wavetable and place all Stuff on One Board.
Banks could be switched by sending commands over mpu for example.
The Pi has many Stuff that no one needs inside a Retro PC, Wlan, Lan, USB.... etc.
It can emulate the Whole Retro PC + MT32... does not feel right to stick that inside the Case.
A full Style break.
Reply 63 of 103, by SScorpio
matze79 wrote on 2020-11-13, 23:04:
Why not make directly a ARM based Wavetable and place all Stuff on One Board. Banks could be switched by sending commands over m […]
A full Style break.
Wasn't someone working on a wavetable adapter that takes a Raspberry Pi Compute unit? That can attach right to a sound card and look much cleaner.
Reply 64 of 103, by appiah4
SScorpio wrote on 2020-11-13, 23:57:
A full Style break.
I would be very interested to learn about this..
Reply 65 of 103, by dreamblaster
haha yes, i was too ... it was not completed yet,
now i probably change into compute module 4
part of the problem, starting more projects than i finish...
I better first finally MP32.. need more free time!
Thanks for your support !
Reply 66 of 103, by SScorpio
dreamblaster wrote on 2020-11-14, 09:38:
haha yes, i was too ... it was not completed yet, now i probably change into compute module 4 part of the problem, starting mo […]
At least if you target that you'll have some breathing room. Everything is pre-order only with place holder dates of 12/31/2020, though Element 14 is saying the beginning of February.
The new connector should be able to make a slimmer design. And the no WiFi 1GB model is targetting $25 which makes creating an internal MT32 Pi a no brainer IMO.
Reply 67 of 103, by dreamblaster
SScorpio wrote on 2020-11-14, 14:54:
Yes indeed, i want to make slim version, take less slot space. The smallest one should do, as we only need the computing power for munt.
Reply 68 of 103, by matze79
There is 1Gb no Wifi Model ? wasnt aware there is such a small one! Nice
Reply 69 of 103, by dreamblaster
Maybe I make a new thread on the waveblaster version of MP32, it will be called McCake 32. -->
It will use a compute module 4.. I expect to build a first prototype in december...
Reply 70 of 103, by darry
dreamblaster wrote on 2020-11-15, 02:28:
Will it use an external DAC or the Pi's PWM audio ?
Reply 71 of 103, by dreamblaster
darry wrote on 2020-11-15, 04:21:
The board has it's DAC, NOT using Pi PWM
Reply 72 of 103, by appiah4
I'm having trouble following all your recent projects Serge, apparently I missed your ESS wavetable project altogether! Maybe you should start a single thread where you post updates on everything, or start a blog or something? Would hate to miss out on a lot of these, the Pi-32 and ESS WT (I love me some ESS) are particularly interesting to me. Also, that Pi wavetable thing - Do you have photos of a working prototype for that or something? Sounds INCREDIBLY interesting.
Reply 73 of 103, by matze79
Making a Blog would be a great Idea!
Reply 74 of 103, by dreamblaster
new revision of 3d print enclosure, almost ok
Reply 75 of 103, by appiah4
Looks more like an SC-55 than an MT-32 this time around, why did you ditch the angled front panel? 😀
Reply 76 of 103, by dreamblaster
appiah4 wrote on 2020-11-16, 06:36:
it still looks like MT-32 in reality, but on a frontal photo, you can't see the angle...
Reply 77 of 103, by appiah4
Oh wow, the perspective on that first photo is absolutely mind bending 🤣
Finish this thing fast Serge, I must buy it asap! 😀
Reply 78 of 103, by arthur071169
Happy new year to all! Looking forward to some MT32 fun this year... watching this page with ever growing anticipation.
Reply 79 of 103, by arthur071169
Any more images to tease us with?
