First post, by BetaC
As per the title, I am having a peculiar issue in which I am unable to turn off a "hall" effect while windows is running. As in, sounds will trail off for a second or so after they are played. I have attempted to disable it by turning off the enhancements that come with the driver, but the 3D effect option seems to have nothing to do with the problem I am facing. The only thing I can think of is something weird coming with Windows Plus! 95. Before that was installed, I don't remember hearing the hall effect.
Reply 1 of 7, by Paar
Good test would be to try pure DOS. That way you can know wheter it is hardware or software problem.
Reply 2 of 7, by BetaC
Paar wrote on 2020-11-17, 13:54:
I have tested it in pure-DOS, and the effect isn't present. I have also used a separate computer in the same physical setup as an extra layer of testing, and the effect is also not present, so It's most likely somewhere within windows.
Reply 3 of 7, by darry
I would try a Hall-effect sensor. 😉
Seriously, I would try removing all drivers and software for the AWE and re-installing .
Reply 4 of 7, by BetaC
darry wrote on 2020-11-17, 21:38:
Okay, I will give that a try, then. I just wanted to see if it was some odd configuration issue or something like that beforehand. And I am sure that someone somewhere has tried to make a VST or something to act as a "Hall-effect Sensor".
Reply 5 of 7, by darry
BetaC wrote on 2020-11-17, 21:43:
Just saw this . Echoing effect (Win98, AWE64 Gold)
