OldTV wrote on 2020-11-22, 11:50:I met cheap devices for usb 3.0 on aliexpress, in which 60 fps are declared, but I'm not sure if they can write at 640x480x60fps […]
I met cheap devices for usb 3.0 on aliexpress, in which 60 fps are declared, but I'm not sure if they can write at 640x480x60fps.
I have it, so here you go. But it is not USB 3.0, at least the one I have. Maybe there is a newer revision, but most likely it's fake blue USB 2.0 connector. I also have small dongles without HDMI passthrough and they perform exactly the same.
The attachment 60fps-rullz.png is no longer available
This is 60FPS mode. It only works with MJPEG compression, so there are visible artifacts. It works in 60FPS up to 1280x720.
The attachment 30fps-rullz.png is no longer available
This is 30FPS mode. Here you can get YUY2 image with much better quality.
I listed available modes:
1920x1080 (max 30FPS MJPEG)
1600x1200 (max 30FPS MJPEG)
1360x768 (max 30FPS MJPEG)
1280x720 (max 60FPS MJPEG)
1280x960 (max 50FP […]
1280x960 (max 50FPS MJPEG)
1280x1024 (max 30FPS MJPEG)
1024x768 (max 60FPS MJPEG)
800x600 (max 60FPS MJPEG, YUY2 up to 20FPS)
720x480 (max 60FPS MJPEG, YUY2 up to 30FPS)
720x576 (max 60FPS MJPEG, YUY2 up to 25FPS)
640x480 (max 60FPS MJPEG, YUY2 up to 30FPS)
BTW it has built in scaler, so you can connect 640x480 input and capture upscaled to 1024x768 60FPS (or any other resolution, even 1600x1200 or 1920x1080p, but only 30FPS obviously). The image will be softer, but will have less visible compression artifacts.
//edit: i also added a comparison image here (it is magnified 200%)
The attachment compare-compression2.png is no longer available
Edit2: if this device captures 1920x1080P at 60FPS (mine does only 30FPS) maybe it is a better/newer revision.
