First post, by Grayshazzle
Hello everyone, so for my Windows 98 SE build I was finally able to get this motherboard in the mail today, although I went to take a look at all the pins and whatnot, and noticed a ton of jumpers with different labels around the board itself. I probably don't need to put any pins around flash or on clear CMOS because I will not be doing that but for everything else I am very confused. Also for the 3 pin headers do you put the 2-pin jumper on the right side or the left, does it act like a off or on or something? Also KB Wake and the 66 - 100 confuses me, is it like a serial bus CPU speed thing for oc. Not fully sure about any of this but if I could have clarification that would be awesome, I attached an image to my revision and all with very helpful labels so you all can see what you are looking at. Thanks 😀
Reply 1 of 2, by PC Hoarder Patrol
Grayshazzle wrote on 2020-11-21, 23:35:
As far as jumpers go, just follow the info in the Quick Jumper Setting Reference
https://www.elhvb.com/mobokive/archive/Ecs%20 … p6bxtaplusj.pdf
Also, you can download the full manual here
https://www.elhvb.com/mobokive/archive/Ecs%20 … /p6bxtaplus.zip
and the latest BIOS for your board revision here
https://www.elhvb.com/mobokive/archive/Ecs%20 … bxtaplus52d.zip
Reply 2 of 2, by Grayshazzle
PC Hoarder Patrol wrote on 2020-11-22, 04:52:
As far as jumpers go, just follow the info in the Quick Jumper Setting Reference […]
My man thank you so much, I have idea how you got the bios file too, I have been searching forever for so thank you for real 😀
