First post, by Jorpho
I notice that a fix commonly needed for System Shock 2 is a patch that solves a compatibility issue with hyperthreading.
Is this a common problem with running older games?
Reply 1 of 4, by DosFreak
It's not hyperthreading but multithreading that is the problem.
I wouldn't say that it is a common problem but it is one of the many things you have to keep in mind when troubleshooting old and new games.
Make your games work offline
Reply 2 of 4, by Jorpho
There's no easy way to tell that multithreading is causing a problem, though, is there? Aside from disabling it in the BIOS or through Task Manager?
Reply 3 of 4, by DosFreak
No. Not really. A typical symptom is that the game crashes when you know it should work. In those cases you set the affinity of the program to a single processor and if you start the game and it works then you know that most likely it's a threading problem.
Anything more involved requires debugging/programming experience.
Reply 4 of 4, by Jorpho
...Because of course it's just that easily to eliminate every other possible cause of a crash. 😉
