OPL3LPT : OPL3 FM Synthesis on parallel port
Reply 200 of 278, by Jinxter
dreamblaster wrote on 2020-03-08, 13:40:
Jinxter wrote on 2020-03-08, 12:07:
Suggestion.
Sometimes i need to go to the back of the PC and press reset. Instead i start the opl3test which resets the OPL3LPT.
What about a reset util, or a parameter to the opl2test that only resets?
good idea
Wow that was quick. You already updated github with an oplreset.exe. Thanks. I have entered the oplreset.exe in my autoexec.bat
Check out my YouTube channel: Retro Erik https://www.youtube.com/c/RetroErik
My collection: https://retro.hageseter.com
Reply 201 of 278, by Jinxter
The readme file states that you have to use EMM386 version 4.46 or later. I Tried the adlipt driver on PC DOS 6.00. With version 4.45 of EMM386. That did not work.
So then i copied the emm386.exe from a MS-DOS 6.22. I was surprised to se that PC DOS 6.00 had no objection to that.
So if you have an older DOS version on your retro PC, you probably don't have to upgrade DOS to a newer version. It is enough with the emm386.exe.
For me, this is important because i am trying to keep my Retro computers true to the time periode they were used.
Reply 202 of 278, by dreamblaster
Here's a new demo of OPL3LPT, running on IBM PS/2 Model 55sx, on youtube channel Retro Erik : https://youtu.be/bQZSTH5bQVQ
Thanks for your support !
Reply 203 of 278, by cde
Just got an email from Serdashop that OPL2LPT is back in stock! Thanks Serge 😀
Reply 204 of 278, by matze79
Yeah opl2lpt rocks! Great Device!!!
Reply 206 of 278, by root42
Jinxter wrote on 2020-04-11, 19:20:
matze79 wrote on 2020-04-11, 19:08:
It there any reason so choose the OPL2LPT over the OPL3LPT?
Beautiful through hole chip of course!
YouTube and Bonus
Reply 207 of 278, by appiah4
Price maybe, also authentic OPL2 if you want adlib sound.
Reply 208 of 278, by Jinxter
appiah4 wrote on 2020-04-12, 05:06:
Do they not sound exactly the same. Is not the only difference that the OPL3 has stereo?, and when using OPL2 games, will not the sound be the same?
Reply 209 of 278, by matze79
But it feels different!
Reply 210 of 278, by appiah4
Jinxter wrote on 2020-04-12, 11:59:
OPL3 has more voices, but is 100% backwards compatible. However, with Adlib/OPL2 you actually can't have the same amount of polyphony as OPL3, so it sounds completely different when playing chiptune music etc. as it completely skips some sounds.
Also, most sound cards featuring OPL3 have some kind of filtering going on that makes the resulting sound slightly different from the way an Adlib card does.
Reply 211 of 278, by cde
I have received and assembled my OPL2LPT and it is working very well! Thanks dreamblaster for the detailed instructions 😀 Also I got a few questions:
- Sometimes when I cold-start the PC the OPL2LPT will emit a sound or series of sounds. This isn't a real problem since it happens rarely and I can reset the OPL2LPT from DOS, but is this behavior to be expected or did I miss something about the assembly? Or could this be caused by the motherboard's BIOS (Abit KT7A) sending stuff over the parallel port?
- I tried to patch Monkey Island 1, and although the patch seems to proceed successfully (two locations were patch), I get no sound. OTOH the ADLIPT program will produce sound when the non patched MONKEY.EXE is run. Any idea?
- Are there particular noteworthy DOS games that make use of the OPL3 more advanced capabilities?
Reply 212 of 278, by dreamblaster
cde wrote on 2020-04-25, 18:59:
Yes it could be due to parallel port behaviour at bootup. The reset button or driver initialisation will resolve it.
no idea
Cybersphere has very nice OPL3 music
Reply 213 of 278, by kirikl
I can't get this adlib21.drv (windows 3.1 driver) work. The only bin file is adlib21 there. So I'm replacing it in Windows\system directory.
And it doesn't say anything, no errors, just programs working with adlib saying no driver/no music 🙁
Anyone has any luck with Windows driver?
My device is Opl3LPT
GA-5AX/k6-3+ 600mhz
XT Turbo 10mhz
HP TC4200 / NC6400
Sony Vaio PCG-SRX99 / PCG-505TR / C1 Picturebook
Compaq LTE Elite 4/75CXL / LTE 5000
Toshiba T1100+ / T3100e/40 / T3200SXC
Tandy 1400 LT / 1000HX
PB G4 1.33 / G3 300
iBook Cl 300
Reply 214 of 278, by dreamblaster
New OPL3LPT batch finally ready ! Black, read, and ... IBM enclosures !
Reply 215 of 278, by appiah4
Wow, I would have bought one if I had a PS/2 😀 Fortunately I am not a masochist and the only IBM box I have is PS/1. God bless ISA 😁
Reply 216 of 278, by MichiganderRyan
Have an OPL3LPT on the way, going to be awesome. I'm composing music using real hardware when possible. With a PCIe LPT port and this unit, and ideas on how I could interface this with my DAW? I'm considering just using old software in DOSbox with the appropriate driver, but was wondering if anyone knows of any modern software that can reach the chip directly. This is in Win10 64bit.
Maybe the software for one of the arduino boards can be used?
EDIT: Maybe some Sound Blaster software for windows from back when it was being discontinued?
Reply 217 of 278, by MichiganderRyan
kvanderlaag wrote on 2019-01-02, 23:36:
I appreciate the offer! Using some of the code I supplied as a base, Darron has provided me with a version of the application wh […]
datajake1999 wrote:
I can help you with this project, if you are interested.
I appreciate the offer! Using some of the code I supplied as a base, Darron has provided me with a version of the application which can use the OPL3LPT as output, and it's working well so far; my understanding is that he's going to clean up his changes to the code sometime and publicly release a new version with support built-in.
However, I have been thinking that it would be fun to extract the functionality of the Adlib Tracker II instrument editor into a Windows frontend and allow the user to map MIDI controls to parameters; the ability to load AT2 patches and play them from a MIDI controller alone would be a boon. I know I miss the MIDI synth mode from earlier versions.
Are there any interesting applications of the OPL3LPT that I'm missing that would be a better use of time?
Update: Found Darron's site and frontend at http://fm801.kewl.org/app/about/
He has version 4.69a up that has OPL3LPT as a menu selection! Woo! Looking forward to trying this bad boy out.
Reply 219 of 278, by kvanderlaag
It appears he's rolled the changes into the main branch for this release. Glad to see, it still works great with my OPL3LPT. My stage setup gets less janky every day!
