First post, by scarecrow182000
My work was clearing out some old hardware earlier this year and I snagged an i5-3570k with a DZ77BH-55k motherboard. It's got the original BIOS still on it and won't work some of the new-ish hardware I have, specifically GPU.
I saw a couple threads of guys trying to pull down as much Intel files before they got purged and I was hoping someone might have a later BIOS for this board. I already looked in the driver archives here and the big pull from IA's 2014 pull . Would appreciate any help to find this.
Reply 1 of 6, by pentiumspeed
Z77 chipset is 8 lanes of PCIe 2.0 and used for minor slots. The first slot x16 slot next to CPU is PCIe 3.0 supplied by Ivy Bridge CPUs. Sandy bridge CPUs are PCIe 2.0 only.
What is video card you are trying to use?
Cheers,
Great Northern aka Canada.
Reply 2 of 6, by PC Hoarder Patrol
scarecrow182000 wrote on 2020-12-06, 00:36:
You can get the latest BIOS (BHZ7710H.86A.0100.2013.0517.0942) and release notes / revision history here
ftp://ftp.micro-square.nl/Drivers/Mainboard/= … 055K/BIOS/0100/
As this will involve you trying to move from the original release BIOS to the latest one, I'd suggest you read this as well before attempting the update
https://community.intel.com/t5/Intel-Desktop- … 55K/td-p/700767
Reply 3 of 6, by Horun
Here is the Intel BIOS Update and Iflash pdf's and the original 0100 text (before Intel removed them) attached.
Read these and then if you want to try the Windows flash I can attach it (still have the complete archive on my other drive) or you can get it here:
https://rebyte.me/en/intel/27345/
NOTE: The *.BIO file is about 10MB so will not fit on a floppy disk....
    DZ77BH-55K_BH_0100.txt
    4.14 KiB
    181 downloads
    iflash_bios_update.pdf
    254.1 KiB
    157 downloads
    BIOS Update Readme.pdf
    122.07 KiB
    158 downloads
Reply 4 of 6, by scarecrow182000
I'm going through the steps to format a USB drive per the suggestions at Intel Community post and will be flashing the board later today. I'll update later today if it worked.
Thank you guys for the quick responses on this. Awesome community here.
Reply 5 of 6, by scarecrow182000
Got it done! Bios flashed on without a hitch.
I had to reinstall Windows, but its working with the GPU.
Thought there was another problem when I restarted and the post code stopped at 92 - No keyboard attached. Turned out I didn't move the HDMI cable from the motherboard to the Graphics card.
They just don't make motherboards like this anymore.
