button mapping issue
First post, by tizerist
has anyone else come across this?
i can play TR on my joypad (pc line tournament pad) but if i try to map controls to the shoulder buttons the set-up doesn't acknowledge them. the ones on the face of the pad are fine, but i need the shoulder buttons to look around and stuff.
hope theres a way round this! cheers!
Reply 1 of 2, by Kaminari
TR DOS only supports four buttons, if I'm not mistaken. You can easily work around this limitation by using a remapper like JoyToKey. (I recommend disabling the joystick function in VDMS.)
Reply 2 of 2, by tizerist
i've opened my VDMS folder, but cant see how to do that!
there's also a couple of other hiccups, but firstly how do i do that?
cheers.
