80386 BIOS image collection
Reply 80 of 143, by Robin4
Predator99 wrote on 2020-08-12, 08:23:
#66 Manufacturer/Identifier: Chipset: BIOS/Version: BIOS-ID: […]
Chipset:
BIOS/Version:
BIOS-ID:
386-Peacock-4386-VCHD.rar
Looks like this board was build by First International Computer.
Reply 81 of 143, by HanJammer
Robin4 wrote on 2020-11-07, 21:58:
Chipset:
BIOS/Version:
BIOS-ID:
This thread is not for such discussions. Use this one: Re: BIOS image collection - requests, discussion etc
Reply 82 of 143, by HanJammer
Board ID : 303N1 V1.1
Chipset : ALI M1217-40
BIOS : MR BIOS MR001-SX V.1.41
BIOS ID string: n/a
Reply 83 of 143, by Predator99
Manufacturer/Identifier: Peacock P386DX-40
Chipset: Symphony SL82C465+SL82C461+SL82C362
BIOS/Version:
BIOS-ID:
(config pn photo works, only 4 SIMMs added in Bank 0)
The attachment 386_Peacock-P386DX-40.zip is no longer available
The attachment 386_Peacock-P386DX-40.jpg is no longer available
The attachment 386_Peacock-P386DX-40bio.jpg is no longer available
Reply 84 of 143, by Horun
Manufacturer/Identifier: ZEOS 386 SX-16
Chipset: VLSI VL82C201-16QC, 82C202, 82C203, 82C204, 82C205A, 82C100,
BIOS Version: AMI 1989
BIOS String: 03/20/89 ROM DIAGNOSTICS.(C)1987, American Megatrends Inc
020090 (C)1987 American Megatrends Inc.386-BIOS (C) 1989 AMI, for ZEOS INTERNATIONAL
(C)1988 AMI, 404-263-8181. 09/15/89 (from Hex edit)
Board marking: ZEOS International (front), mp386 x02, 88091901 Rev F.0 (back)
Notes: 386-16 AT motherboard.
Mine will not complete POST w/o memory parity error so no good POST screen shots from the board.
Saved BIOS's using TL866plus, included a merged BIOS for hex reading.
Reply 85 of 143, by HanJammer
Manufacturer/Identifier: G.W-386/486
Chipset: SARC RC4018A4 (UMC-491)
BIOS Version: Award 08/10/93
BIOS String: 08/10/93-UMC-491-214X2002-00.0000
Reply 86 of 143, by HanJammer
Manufacturer/Identifier: Generic (PC Chips? Amptron?) VLSI SCAMP 386SX 16/20/25MHz
Chipset: VLSI SCAMP VL82C311-25FC4+VL82C113A-FC
BIOS Version: AMI 07/07/91
BIOS String: 30-0400-428027-00101111-070791-SCMPSX
Reply 87 of 143, by Thermalwrong
Manufacturer/Identifier: QTC-SXM KT X20T02/HI Rev.3
Chipset: VLSI / Intel S82343 + S82344A
BIOS Version: Quadtel 03.05.07 1431503002
BIOS String: Quadtel VL82C286 386SX BIOS Version 3.05.07
BIOS Chips: Signetic/Philips 27C256-20N
Reply 88 of 143, by Predator99
Manufacturer/Identifier: PC-CHIPS M317
Chipset:
BIOS/Version:
BIOS-ID:
The attachment 386_PCCHIPS.jpg is no longer available
The attachment 386_PCCHIPS.zip is no longer available
Reply 89 of 143, by Predator99
Manufacturer/Identifier: ELT-P9
Chipset: NEC ELT3000A
BIOS/Version:
BIOS-ID:
Most likely ELT-386SX-160D
http://www.win3x.org/uh19/motherboard/show/5344
The attachment 386_676849_L.jpg is no longer available
The attachment 386_676849_L.zip is no longer available
The attachment elt1.jpg is no longer available
The attachment elt2.jpg is no longer available
Reply 90 of 143, by zoinknoise
Seritech SER-386ADIII (or SER-386AD3)
Am386DX-40
ALi M1429 + M1431
AMIBIOS 04/04/93
40-0212-001133-00101111-040493-ALI1429-F
The attachment IMG_3216.jpg is no longer available
Reply 91 of 143, by TheMobRules
Manufacturer/Identifier: ECS (Elitegroup) 386A
Chipset: CHIPS P82C301/2/5 + P82A303/4/6 + P82C206
BIOS/Version: AMI 386-BIOS / 386A V1.1 05-19-90 (2 x 27C256)
BIOS String: EC&T-1131-040990-K8
The attachment 386A.zip is no longer available
The attachment 386A.jpg is no longer available
Note 1: warranty label on the back may indicate manufacturer is ECS *** confirmed, see edit below
Note 2: TH99 is wrong regarding JP7, it does not switch between internal/external battery, it actually selects between generating internal PG signal (INT) or using the PG line from PSU (EXT)
EDIT: added BIOS string ID, manufacturer is indeed ECS (1131)
Reply 92 of 143, by Am386DX-40
Manufacturer/Identifier: PC CHIPS M321 REV 2.7
Chipset: OPTi 82C391 (according to this thread)
Notes:
* photo of the motherboard courtesy of AmoRetro.de
* I have 2 of these motherboards (physically identical, same revision, etc), and none of them work. One has been affected by A LOT of corrosion and the 2nd one is intact, in perfect shape. Looks brand new! But still it won't work. I took the bios chips out from each of them and used my GQ4X eeprom burner to get the bios image from the chips. As both BIOSes are different, I'm uploading both on the same .7z file. Use whichever you want. Apparently one is from 1990 and the other is from 1992, or something like that.
Reply 93 of 143, by Am386DX-40
Manufacturer/Identifier: Octek Jaguar V rev 1.4
Chipset: Macronix MX83C305FC + MX83C306FC
BIOS: AMI
ID string: 31-0100-426069-00101111-121291-MXIC-0
Note: this is the same motherboard as #36, but his BIOS doesn't match mine. Different SHA1. I dumped the rom with a GQ4X eeprom burner and I know it's right as the SHA1 matches the one in MAME.
Reply 94 of 143, by Am386DX-40
Manufacturer/Identifier: Morse M3 V3.00
Chipset: Morse 4L04F1282 + 4L04F1666 + 92A206S // (OPTi 82C391 (according to this thread))
BIOS: AMI
ID string: 30-0201-ZZ1216-00101111-050591-386DX-0
Note: picture is from V3.10 motherboard, but they are almost exactly the same.
Reply 95 of 143, by Am386DX-40
Manufacturer/Identifier: PCCHIPS M326 V5.2
Chipset: SARC RC4018A4 + SARC RC4019A4 // (UMC UM82C491 + UMC UM 82C493F (according to this thread))
BIOS: AMIBIOS 10/01/93
ID string: 40-0100-001437-00101111-080893-4386-0
Reply 96 of 143, by Eep386
Manufacturer/Identifier: Prolink P386SX-25PW VER:2.00
Chipset: OPTi 82C281
BIOS/Version: AMI
BIOS-ID:
The attachment Prolink P386SX-25PW.jpg is no longer available
AMI BIOS:
The attachment P386SX25PW.zip is no longer available
Reply 98 of 143, by alvaro84
HanJammer wrote on 2020-11-08, 00:18:
Board ID : 303N1 V1.1 Chipset : ALI M1217-40 BIOS : MR BIOS MR001-SX V.1.41 BIOS ID string: n/a […]
BIOS ID string: n/a
I seem to have the same board but the BIOS originates from somewhere else - unfortunately I don't remember the seriously damaged board I removed it from just to have MR BIOS for another board I may find later. And I was lucky. It's slightly different version so I post it here. I hope debug/checkit dumps are okay, these are all 64kB single chip BIOSes.
So...
#90
Board ID : Unknown
BIOS : MR 386SX BIOS V.1.40
BIOS ID string: n/a
The attachment ALIM1217.jpg is no longer available
The attachment M1217MRB.zip is no longer available
Shame on us, doomed from the start
May God have mercy on our dirty little hearts
Reply 99 of 143, by alvaro84
And an old debt of mine. It's not even the board I was asked to upload a BIOS dump from because that very piece died on me almost instantly. But I found another one so it's here:
#91
Board ID : Unknown 486SLC-33 (feel free to id it which I'd appreciate)
BIOS : MR 386SX/86SLC BIOS V.1.61 (apparently they moved to Santa Clara after the other one)
BIOS ID string: n/a
The attachment ETEQ.jpg is no longer available
The attachment ETEQ-MRB.zip is no longer available
