First post, by AntiRevisionism
Just putting an 98 SE system and I have two PCI network cards to choose from. First is a DFE-530TX+ Rev.E1. Second is a Linksys LNE100TX 5.1 . Anyone familiar enough with these cards to recommend using one over the other? (And anyone know what the empty sockets on the end are for?)
Reply 1 of 3, by dionb
The DFE-530TX+ is a generic Realtek RTL8139, the LNE100TX is a DEC Tulip chip. Realtek has excellent driver support (you can still download the driver from their site), but the chips are lackluster, putting a heavy load on the CPU. If your CPU is very fast that can be an advantage, but with Win98SE I'd suspect your CPU isn't so fast - and then the Tulip wins. Off the top of my head I'd say the tipping point is somewhere just above 1GHz.
Reply 2 of 3, by OzzFan
The empty sockets are for an optional boot PROM used for PXE (network) booting.
Hobbyist Developer : https://www.shelteringoak.com/du/
Reply 3 of 3, by AntiRevisionism
Thanks. Processor is a PIII 600 MHz, so I'll give the LNE100TX a try first.
