First post, by logjammer
Hello,
I have tried searching high and low and utilizing multiple driver downloads, but cannot get the CS4327b sound card to work in DOS mode on this Laptop.
Utilizing the official Dell driver or the ones posted on this site, I am presented with the following issue every time I run cwdinit.exe or cwbinit.exe depending on the driver version:
Inadequate configuration to download Firmware code.
If I try to run the init with a /A, the following error occurs: Cannot find C:\Windows\CWDAUDIO.WCM.
I hope that it is something simple that I am missing.
Currently Win95 OSR 2.5 with Plus! is installed. I have tried with Win98 SE, but get the same results.
If there is someone with a set of Factory Restore Media I would be incredibly appreciative!
Thanks!
Justin
