First post, by Durandal
Hey all,
I've been trying to replace the dead FDD in this Japanese IBM PS/55 (essentially IBM Japan's PS/2, it's a 386 MCA machine) and am having trouble getting it to read 1.44MB disks.
https://retrocomputing.stackexchange.com/ques … -in-an-ibm-ps-2
http://www.vcfed.org/forum/showthread.php?508 … -2-floppy-drive
What I've done so far is follow the pinout on that site + thread above: wired the 34-pin cable, power cable, and added 5 x 4k7 resistors bridging pins 8, 26, 28, 30, and 34 to 5V on the floppy drive itself (it wasn't working without the resistors). It didn't work at all with pins 12 and 16 wired to for 'drive select A' and 'motor enable A', but a friend suggested that I re-wire both for drive B and then the FDD started to read 720KB disks perfectly. However, it outright refuses to do anything with a 1.44MB disk. When I try booting from a known good 1.44MB floppy, the drive will seek 2 times and then boot from the hard drive, and also does the same thing when I've booted DOS from the hard drive and am trying to access a 1.44MB disk.
Luckily I had the foresight to copy the PS/55's reference diskette to the hard drive. Booting into the setup from the HDD, my only options for Drive 0 (A:, I'm assuming) are either 3.5" 1.44MB or 2.88MB, and Drive 1 (B:) has those two options plus 5.25" 360KB. I tried setting the only active drive to Drive 1, 1.44MB 3.5", but that stopped the FDD from working with 720KB disks. Setting either Drive 0 or 1 to 2.88MB 3.5" also stopped the drive from working as it was before.
I had this exact same problem when replacing the floppy drive in another Japanese PS/55 (that one had the PS/1 style 34-pin connector with integrated power) and all I had to do to fix the problem was ground pin 2, which is 'density select' on a standard floppy drive. I thought the same might be the case for this 40-pin edge connector style PS/55, but grounding pin 2 did nothing. Also, it might not be relevant but I thought it strange nonetheless: that PS/1 style PS/55 auto-detects the new standard FDD as 2.88MB 3.5", but works perfectly with 1.44MB and 720KB disks; I have no 2.88MB disks to test with but I'm sure they won't work since the drive isn't capable of it.
After some more research on this it appears that some PS/2's don't have 'media sensing' but modern drives do (I think?):
http://ibm.kanotech.org/ps2/
That page says that a drive "that supports CMOS" is necessary but I can't find this information anywhere else, and I don't really know what to do about it. Do I need a special type of 34-pin drive? Or am I doing something wrong?
Any and all help is greatly appreciated! I'm planning to try my hand at creating a plug-and-play solution to this if I manage to figure it out.
Thanks and best regards,
Jordan
Reply 1 of 6, by kish2554
Jordan,
Have you ever found a solution to this? I have tried EVERYTHING everyone's posted about making this work on a PS/2 model 55sx with no success. I've tried the resistors on pins 8, 26, 28, 30, 34 to 5v, no luck. I've tried using power off the power supply to power a floppy drive, tried pulling it from pins 3/6/1 on the ribbon cable, no luck. Tried cutting pin 4, grounding it, no luck. A combination of the several, no luck. Have tried Mitsumi, Epson and one other brand of floppy drive, all with different results. Epson the light comes on and stays on, almost as if it's connected backwards, but it has clear indicators of pins 1 and 34. I'm stumped.
Would be happy to try anything else!
Matt
Reply 2 of 6, by Durandal
kish2554 wrote:
Jordan, Have you ever found a solution to this? I have tried EVERYTHING everyone's posted about making this work on a PS/2 […]
Jordan,
Matt
Sorry for the late reply, but no, I never got it reading anything but 720KB disks. It remains a mystery to this very day!
I ended up revisiting the original drive and managed to resurrect it which is what I should've done in the first place, but my plan was to cobble together a crappy adapter for standard 34-pin drives and use that to design a proper PCB for people to use. Perhaps I'll revisit it again someday when I know more about PS/2s.
Reply 3 of 6, by Shyzah
Having a similar issue with a 35SX.
Keeps booting to basic.
I got it to boot to windows 95 boot disk after cleaning the floppy heads with 99% iso but they stopped reading after an hour.
Now it won't even work after another cleaning.
Any way to use a standard floppy drive on these?
What's life without a turbo?
Reply 4 of 6, by Caluser2000
Yes. https://github.com/schlae/PS2FloppyAdapter
Reply 5 of 6, by SteveC
Caluser2000 wrote on 2020-12-16, 16:33:
Oh this is interesting! Has anyone ever tried making these (or even better have one for sale?)
I just have got hold of a model 50 and guess what the floppy drive doesn't work! I've recapped it and cleaned it but still the exact same behaviour - it does the boot up seek OK and spins the disk OK, but it doesn't start reading the disk on boot and ends up giving me the 'insert floppy' screen and then the ROM BASIC 🙁
Cheers,
Steve
