First post, by Hamby
I'm about to order capacitor kits for my TRS80 Model 100 laptops.
This got me to thinking that I never checked the power supplies on my Toshiba T5200 laptops for bad capacitors.
As these are my favorite machines (I think...), I'm now kind of concerned about it. And I haven't done a capacitor replacement for anything, yet.
Is there a "standard" capacitor kit for power supplies? Has anyone recapped a T5200 power supply? Does anyone know of a list of capacitors I'm likely to need? I'd like to have my ducks in a row before I open up the laptop, if possible.
Any advice or "gotchas" I should be aware of?
Reply 1 of 9, by dionb
Nope. Individual designs can differ quite a lot. Open it up, read the values, then get those. Higher voltage rating is almost always fine, but capacitance need to be the same, or failing that as similar as possible.
Reply 2 of 9, by Hamby
dionb wrote on 2020-12-21, 21:49:
Know of a reliable source in the States?
Reply 3 of 9, by debs3759
Hamby wrote on 2020-12-22, 00:37:
Mouser and DigiKey are both reliable. When you select your replacements, check the size and leg spacing, to make sure they will fit, as there can be some variance
Reply 4 of 9, by Hamby
debs3759 wrote on 2020-12-22, 00:47:
Thanks very much for the advice and info!
Reply 5 of 9, by Horun
Hamby wrote on 2020-12-22, 02:05:
Agree ! Some of the older 8mm or 10mm width bigger caps are hard to find, you need to look carefully for those.
Reply 6 of 9, by gdjacobs
Try to select caps from compatible series. Certain applications can become unstable with ESR values too different from those they replace.
Reply 7 of 9, by Horun
gdjacobs wrote on 2020-12-23, 03:40:
Totally agree and Yes this ^
Many older AT PSU (like Antec AT PSU's) do not like newer low ESR caps because they were not designed for them. Have read and run into this myself.
Same with older XT/286 PSU, the caps were low ESR by the standards of that period but not like what is out since ATX.
"Try to select caps from compatible series" is very good advise !
Reply 8 of 9, by gdjacobs
Horun wrote on 2020-12-23, 04:24:
Totally agree and Yes this ^ Many older AT PSU (like Antec AT PSU's) do not like newer low ESR caps because they were not desig […]
This is specifically an issue when changing caps alters the parameters of the feedback loop for the controller.
Reply 9 of 9, by radiounix
Horun wrote on 2020-12-22, 03:14:
The Nichicon PM line is probably the oldest low ESR line with wide availability, those are some seriously large capacitors. I ordered those all around for my Tandy 1400LT laptop, but they were often significantly LARGER than what was originally specced to the point of barely fitting.
