CD-Audio under Kubuntu.
First post, by KHJD
is it possible to play CD-Audio-Tracks within a DOSBOX running on Kubuntu ?
I dont now, how to mount the cdrom in DOSBOX correctly, trying
mount d /cdrom -t cdrom -usecd -ioctl
mount d /dev/cdrom -t cdrom -usecd -ioctl
mount d /dev/hdc -t cdrom -usecd -ioctl
but it didn't work.
I can play Audio-cd via VLC, for example, but not via a DOS based CD-Player within DOSBOX.
The reason for this is, that i want to play DSA1 (Realms of Arkania 1), whitch uses CD-Audio-Tracks for the Ingame-Music.
Sorry for my bad English
Mfg
Reply 1 of 20, by Qbix
Rank DOSBox Author
DOSBox Author
well -usecd needs a number
(find it with mount -cd)
audiotracks should work that way.
Water flows down the stream
Reply 2 of 20, by KHJD
Thanks, now the drive runs and its LED is on, but I can't hear the music (SFX/Speech is okay, tested with DSA1+2 / Realms of Arkania1+2).
I tried to play the Audio-Tracks with Kaffein, Xine and VLC ---> Okay
With KsCD --> It plays the CD, but no Sound....
Is there a special Sounddriver (or something like that) needed ?
Reply 3 of 20, by eL_PuSHeR
I think you mean Das Schwarze Auge: Realms of Arkania not Arcadia.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 20, by KHJD
Yes, sorry... Its been a while since I have seen the English Version - Title (It was in a Error-Message, I think)
Reply 5 of 20, by KHJD
It seems that the Digital Audio Extraction for the Audio-CD-Playback isn't working in Dosbox and Analog-Playback isn't possible (PC is a Notebook, with no Analog-Audio connection between Soundcard and Drive).
Reply 6 of 20, by eL_PuSHeR
By the way...
I had just finished Realms of Arkania 3: Shadows over Riva (yesterday). CD Audio worked just fine for me but keep in mind that I am running it under WinXP.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 7 of 20, by KHJD
WinXP is using the digital "Way" by default!
Reply 8 of 20, by eL_PuSHeR
Do you mean that Kubuntu uses analogic output?
Intel i7 5960X
8 GB DDR4 (2100)
Reply 9 of 20, by KHJD
I think so...
Some Audio Players can use the digital audio extraction (in Xmms you must change it in the Options-Menu), but I don't know if and how to enable this system-wide.
Reply 10 of 20, by KHJD
Is it possible to tell DOSBox (or ALSA) to use "Digital Audio Extraction" and not Analog CD-Audio ???
Reply 11 of 20, by Qbix
Rank DOSBox Author
DOSBox Author
sdl seems to "forward" everything to ioctl commands
and those play audio like a audio should be played (so analog).
Reply 12 of 20, by KHJD
So its impossible (at this time) for me to get use of the CD-Audio-Music, cause I'm using a Notebook with an internal(and a second, external) DVD+/-RW Drive... 😢
Reply 14 of 20, by KHJD
Which tool should I use for doing this ? I only found tools for creating ISO-Images (which IMO don't include Audio-Tracks) !
Reply 15 of 20, by Snover
dd if=/dev/cdrom of=file.iso bs=32767 should create a full image of the disk.
Yes, it’s my fault.
Reply 16 of 20, by KHJD
Nope, dd if=/dev/cdrom of=file.iso bs=32767 (or dd if=/dev/scd0 of=file.iso bs=32767) didn't work... Its just a 7 MB Image without Audio-Tracks...
I get this error-messages:
223+1 records in
223+0 records out
Segmentation fault
I think I have read somewhere (some times ago) that you can't do a dd on Disks containing Audio-Tracks.
Reply 17 of 20, by Qbix
Rank DOSBox Author
DOSBox Author
cdrecord can burn them. Maybe it can make them as well.
Reply 18 of 20, by Snover
I'm a little concerned that dd is segfaulting. It should not do that.
Yes, it’s my fault.
Reply 19 of 20, by KHJD
Well, I have 2 different releases of the game, the normal release and a Collection release.
I have tried dd with both releases --> Same result. I also tried to clean the CDs (using TFT-Cleaner Gel and Microfiber cloth)...
So its impossible to configure SDL or ALSA (or where the problem lies) to use DAE ?
