Reply 37620 of 59283, by pete8475
kixs wrote on 2021-01-13, 17:36:
Don't exaggerate... I had a few Ultras back then and I have a few now... they all worked/work great. Maybe you had some memory incompatibility...
I'm not exaggerating, I am amazed his works this well.
I threw at least 50 of these shit motherboards in the trash. I RMAed a few and got more shit in return from MSI and Asus and after that it was straight into the dumpster.
aka pete4237.5
Reply 37621 of 59283, by PC@LIVE
Purchased this mini lot earlier.
An AMD 5k86-P75 Socket5 CPU, an 8-bit ISA modem, and an ASUS with 2 USB ports.
See pictures
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 37622 of 59283, by chrismeyer6
I've used nforce 2 boards from Abit and DFI and never had any stability issues. It might just be something up with the MSI and Asus boards. I've personally have had nothing but issues with anything I've gotten from Asus so I now avoid their parts at all costs.
Reply 37623 of 59283, by devius
pete8475 wrote on 2021-01-13, 21:15:
The moral of the story seems to be to not use nForce2 motherboards from Asus and MSI. Count me in as someone that used a nForce2 motherboard for about 7 years without the stability problems you mention. In my case it was manufactured by Soltek.
Reply 37624 of 59283, by kolderman
devius wrote on 2021-01-13, 21:32:
The moral of my story is once you discover the wonder of KT333 boards and their support for 3.3v AGP (read voodoo5 support), and DDR400, there is no going back. I save dual-channel DDR400 builds for my P4 systems.
Reply 37625 of 59283, by bearking
Got these today as a lot for 22 euro incl. shipping... only took the hard drive because it came with the card. A Joytech Apollo 3D Voodoo Banshee. Not that special but the price was good.
Both are working fine...
Reply 37626 of 59283, by Horun
At my fav local thrift store bought 2 Maxtor HD boxes labeled as 80Gb but has the original drives those replaced inside. One has a WD24300, the other has a WD28400 and a Maxtor 91024u2 10Gb inside. All nicely anti-static bagged and cushioned with original Maxtor HD box cushions. There is a sticky note on one 80Gb box with "4-2-05 original Dell GX1 4Gb HDD" and on the other box "4-2-05 Old WD 8GB HDD: C, D &F. 10Gb HDD: D drive imaged replaced Dell GX1". The boxes have the original unopened cables and Instruction books too.
Hope they work ! If they have sat boxed for nearly 16 years there is hope ! Also got a PCI USB card in original box. Also got a Arrow Heavy Duty T-50 stapler NOS from before 1990. Paid $25 for all.
Will post pics and test results when I get home.
Reply 37627 of 59283, by stege
A fiend afflicted by the same disease we all seem to suffer from, donated these to me. Tears rolled while goods exchanged owners.
Miss the Monkey Island days, the Space Quest days, even The Longest Journey days.
Reply 37628 of 59283, by Shreddoc
Am I the only one with the bugbear about RAM on carpet? 😀 Probably unfounded. I grew up in that paranoid era regarding RAM and static damage. But I don't actually know if static charge can or does "sit waiting in the carpet", waiting to be destructively transferred into the RAM laid down upon it.
Reply 37629 of 59283, by Horun
Shreddoc wrote on 2021-01-14, 02:59:
NO ! I never put any bare computer part on bare carpet (and I live in a area that has typically 70%+ humidity). Yes it can shorten the life of some items....if not they would not put warnings in bright yellow tags on parts bags 😀
Ok tested the drives and they work ok. Only the Maxtor 10gb has SMART which reported all very good, but a quick random surface check showed all as good. None had file newer than 3 years after man date and all were at over 90% capacity. 🤣
I did power them up for about 5 minutes before connecting and reading/testing, wanted to stabilize the old electronics and sure enough not one had a file written to any after 2004. The Wd23400 did chirp and click on and off a bit during the warm up, the others just purred. Was expecting the 23400 to have issues (have had them before and they developed the click of death syndrum ) . Did not test the 4 port Opti based USB card... for $3 in a box am not worried about it.
As per my post a few hours ago: the yellow sticky notes were on the boxes and drives from whoever had them before. The green circle sticky is mine (green = good and put the year tested, just my OCD thing)
added Shit just relealized I put 2020 and it is 2021, will fix that....
Reply 37630 of 59283, by Repo Man11
wiretap wrote on 2021-01-13, 18:44:
Just grabbed these for $21 shipped (total for both). […]
In the spring of 2001, I was given a Cybermax computer that had a VX chipset Biostar motherboard, and a Cyrix 133 MHz CPU. I bought one of those Winchip Evergreen 200 MHz CPUs in late April to upgrade it, but it wouldn't post. I put the Cyrix back in and emailed Evergreen, and even though I'd bought it on Ebay, they emailed me a BIOS to make it work. Very nervous about doing my first ever BIOS flash, I felt like I'd done a magic trick when I swapped the Winchip CPU back in and it POSTed!
Reply 37631 of 59283, by brostenen
Not computer hardware.
I bought this lamp that have 1970's design. I could not resist. And yes, it is made in the 1970's.
True Danish design from that era. I simply love it.
They are not that expensive. Some 65 US Dollars is the market price. They originally come with ceramic socket.
They can take up to around 60 or 70 watt light bulps, running at 220/240 volt.
The attachment lampe.jpg is no longer available
Reply 37632 of 59283, by gex85
Today I made a nice purchase: The Turtle Beach Montego II Plus, an Aureal Vortex 2 card with an additional daughterboard with SPDIF and RCA connectors. There are quite a few threads about this card, like this one.
I saw an eBay listing for a Dell XPS Pentium III machine the other day, starting at 65€ + shipping. And it had this card in it. I was really tempted to buy the whole system, but apart from the soundcard it was a pretty basic setup with a P3-500 and Nvidia TNT. I always liked the design of the XPS machines of that era, but I already have too many systems of this vintage and the price wasn't exactly cheap. The auction ended with zero bids... Although it doesn't feel good to rip a system like this apart, I contacted the seller and offered him a fair price for the card and he agreed.
The attachment Turtle-Beach-Montego-II-plus (1).jpg is no longer available
The attachment Turtle-Beach-Montego-II-plus (2).jpg is no longer available
My retro computers
Reply 37633 of 59283, by gex85
And another good deal (at least I think so). A lot consisting of:
  • M396F motherboard with AMD 386SX-40 CPU. My first 386 ever, usually I'm more interested in the late 90s and early 2000s stuff, but it was in the lot, so why not.
  • MB-8433UUD-A motherboard, UMC chipset, AMD 486DX4-100 CPU installed. I don't have a working 486 motherboard with PCI yet, so it's a welcome addition to the collection.
  • Shuttle HOT-591P Ver. 2.0 motherboard (Super Socket 7, Via MVP3). Since the Gigabyte GA-5AA that I am currently building a system around is acting up and refuses to POST every so often, it might get replaced with this Shuttle board. It was the main reason for me to get this lot, actually.
  • Tseng ET4000AX ISA video card, no details are known. Might be made by "Ara-Tech" according to the sticker on the BIOS chip...
  • Some mystery ISA interface card, looks like a PS/2 mouse connector or something. Labelled "HS - 3000 REV2", haven't found any useful info on a quick first attempt.
Seller's photos:
The attachment M396F Rev. 2.6.JPG is no longer available
The attachment MB-8433UUD-A.JPG is no longer available
The attachment Shuttle HOT-591P Ver. 2.0.JPG is no longer available
The attachment Tseng ET4000AX.JPG is no longer available
The attachment isacard.JPG is no longer available
Got this lot for 35€ shipped, so it's like 7€ per piece. Everything's untested, of course, so fingers crossed that some of it still works.
My retro computers
Reply 37634 of 59283, by debs3759
Has that Tseng card got an FCC ID on it?
Reply 37635 of 59283, by Horun
gex85 wrote on 2021-01-14, 22:55:
And another good deal (at least I think so). A lot consisting of: […]
Nice ! Good price for lot of goodies !
Went to the local SA store and found a boxed XFX GF 9400 GT (PVT94G-YAL) for $3. Took a gamble and it works ! I needed a low profile PCIe for an InWin desktop case.
Not a speed demon card but has 128bit memory (versus 64bit on some 9400GT) and good enough for my purpose.
Reply 37636 of 59283, by chrismeyer6
For 3 bucks that 9400 is a good deal. Back in the day my wife's computer came with one of them and it was quite decent. Back in those days we were vary much into WOW and that card ran WOW beautifully.
Reply 37637 of 59283, by imi
brostenen wrote on 2021-01-14, 19:09:
Not computer hardware. I bought this lamp that have 1970's design. I could not resist. And yes, it is made in the 1970's. True D […]
I nabbed a similar design table lamp from the office move, also from the 70s/80s ^^ I really like those for some reasons
that's some nice stuff @gex85
Reply 37638 of 59283, by bjwil1991
Bought another CR-563-B CD-ROM drive for my other build.
The attachment Screenshot_20210114-201409-222.png is no longer available
Seller's photos:
The attachment Screenshot_20210114-201604-942.png is no longer available
The attachment Screenshot_20210114-201623-253.png is no longer available
Reply 37639 of 59283, by imi
mhh love those matsushita drives :3
so I bought this Korg Audio Gallery AG-10 boxed with all the stuff for a reasonable price, quickly took it out of the box (which was pretty beat up but eh not complaining) to put it in my midi tower build to see how everything fits.
The attachment hardware40_08.jpg is no longer available
today I put away the box... and curiously in the shipping box there was another small box hiding between the packaging material...
a midi interface? oh nice :3
wonder what that is... "magic midia" huh? never heard of...
The attachment hardware40_09b.jpg is no longer available
well I opened the box to check and wrapped in bubble wrap was this...
D:
well that's a nice and welcome addition to the purchase, nowhere in the listing was this even visible or advertised in the description
The attachment hardware40_09.jpg is no longer available
