First post, by Warlord
It says it works for tax card no idea what that is and claims sound card.
https://www.aliexpress.com/item/33037848642.h … 2%2315392%23472
Found this one too. ISA USB. Claims to work in dos and win 3.1
https://www.aliexpress.com/item/1005001969235 … searchweb201603_
Reply 1 of 8, by dionb
The USB one is specifically for USB storage, so only for USB sticks. Still useful if it works though...
Reply 2 of 8, by Sphere478
I’d be interested in one that goes the other way around if you run across one. I could use more pci slots even if they were slower.
Also interested in hearing what you find out about these cards.
It is my knowledge also that that usb card is for a virtual hard drive on a usb stick also.
Sphere's PCB projects.
Reply 3 of 8, by fosterwj03
Something like the PCI to ISA bridge might work with a sound card on an Intel ICH5 or earlier platform. ISA sound requires DMA, and Intel removed DMA functionality from later chipsets. I can't speak to AMD chipset compatibility with DMA, I'm afraid.
The bridge chip would need to support DMA as well. Hard to tell what bridge they used from the photo.
It might work with a P4 or P3 board that only has PCI slots.
Also, it looks like only an 8-bit ISA slot, not 16. It could still work with 16-bit cards that offer an 8-bit mode.
Reply 4 of 8, by Sphere478
dionb wrote on 2021-01-17, 22:47:
so I guess using it to boot ubuntu live sticks and windows 7 install sticks won’t work?
Reply 5 of 8, by dionb
Sphere478 wrote on 2021-01-20, 07:07:
Without a bootROM: definitely not. With one... I'd still doubt it, as the storage driver needs to be loaded after OS BOOT - but it's not theoretically impossible, just requires a significantly more complex bit of ROM.
Reply 6 of 8, by Dant
fosterwj03 wrote on 2021-01-17, 23:00:
Something like the PCI to ISA bridge might work with a sound card on an Intel ICH5 or earlier platform. ISA sound requires DMA, […]
Intel chipsets after the 440BX won't tunnel any ISA sideband signals through the PCI slots, as in DDMA. You have to get the serialized IRQ and DMA lines from the Southbridge and run them to the ISA bridge separately. To make this card work with DMA on any chipset that doesn't have DDMA support, you'd need an SBlink or PC/PCI connector to bring those signals to the bridge.
Reply 7 of 8, by fosterwj03
Dant wrote on 2021-01-20, 14:19:
If true, than the bridge card and/or the sound card would require significant modification (as well as wires attached to the south bridge). Probably not worth the trouble when several PCI sound cards offer adequate compatibility in DOS.
Reply 8 of 8, by Warlord
not so sure youre right about that,
