First post, by Sphere478
Snagged this, not sure about the clock, but I hear I can expect trouble? What do I do to fix it? Are there multiple options?
It’s supposed to be in a removable socket, so at least there is that.
Is there a upgraded part? Or direct replacement? I would prefer not to modify unless it will look oem
Sphere's PCB projects.
Reply 2 of 8, by Sphere478
maxtherabbit wrote on 2021-01-21, 04:27:
You can buy a brand new Dallas DS12887 from digikey for under $10
Sounds like an ideal option. How long can one expect on average before it gives trouble again?
Reply 3 of 8, by dionb
Sphere478 wrote on 2021-01-21, 04:54:
A decade or two.
There's a lot of hate on these things, as they are more expensive than coin cells and all too frequently were soldered onto the board (which was an arsehole move) but in fact they're pretty elegant - last for ages, don't leak if they fail and can be drop-in replaced. It's only idiots actually using systems well belong their technical and economic design lifetimes who have trouble with it. 😉
Reply 4 of 8, by chinny22
Other options are hacking a Dallas chip to use a coin cell
http://www.mcamafia.de/mcapage0/dsrework.htm
or buy something like this which does the same thing but doesn't look as ugly
https://www.tindie.com/products/glitchwrks/gw … lacement-module
but if yours is socketed then I'd just get a standard replacement.
As dionb said its the motherboards that soldered the chip direct to the board that have given the chips a bad name.
One in my PC finally quit last year, on a PC that I've had since '95 and yeh mine's soldered 🙁
Reply 5 of 8, by Sphere478
Oh wow 🤣 it’s just a little button cell in There 🤣
Sweet! All the i formation I needed to know!! Thanks guys!!
So these all had the same part number? (I don’t have the board yet to check) and was thinking of ordering ahead
Edit: oh wow, that custom one with a removable battery looks perfect!! I’ll probably get that!
Reply 6 of 8, by Sphere478
https://monotech.fwscart.com/DS12887_RTC_Drop … zpALxZQuibpgARI
Ooo here is one that takes a bigger battery
Reply 8 of 8, by Sphere478
maxtherabbit wrote on 2021-01-21, 17:31:
The new dallas module is still my recommendation. Costs less and full encapsulation > ability to change the battery again 25 years from mow
I was sold on the ability to use a normal battery on a oem looking solution that will basically fix it forever.
More money. But It’s the option I like the most.
