First post, by freetmool
Hello, this is my first post (no pun intended), I'm from Belgium, born in 1979.
I like to restore old stuff and now it's my first PC from my youth 's turn 😉
This forum has already helped and interested me a lot by reading it, so thank you all !
I'll need some help because I've done many tests and I can't get my motherboard much alive...
First I didn't have any sign of life despite testing the PSU voltages (all good) and replacing the battery.
Plugged a VGA card, nothing...
I've tried many different BIOS and when I used the Phoenix one, I got 1-3-3 BEEPS
That seems to mean that there is a RAM problem.
So I've checked every DRAM with an arduino tester and found one bad one, great ! Well.... no.
Tried with one bank only and zero bank. All bank switches are in the right place.
Still the same problem.
Any idea ?
I should receive a diagnostic card soon but I don't think it would be much help from what I could tell.
Here is the motherboard in question: ( I do have the manual, bios rom and EMS diskettes if someone is interested)
(picture from HanJammer)
file.php?mode=view&id=100918
Reply 1 of 19, by Cyberdyne
Wow nice, a 286 with IDE and floppy!
you need an original bios for that motherboard, you can not just swap out random bioses and expect them to work. even if they beep a little bit.
You have 1MB of memory, it is all good. Usually it is called bank 0.
Reply 2 of 19, by freetmool
Oh I see, I may have a corrupted original BIOS then ...
Just to be clear I've tried multi Suntac's BIOS.
And the Pheonix 3.10 gave me some hope.
Reply 3 of 19, by megatron-uk
I'm going through a similar process myself (see my 286 is dead, long live the 286 thread: 286 dead, long live the 286! Sourcing and building a fast 286 replacement).
I also had an original 286 board that was my first computer and used it on-and-off for many years. After putting it in storage 6 years or so ago it now won't POST successfully either.
These are old things, and I'm of the opinion that if we don't use them on a regular basis that they can degrade quite quickly. We're talking about 30+ year old IC's, capacitors and resister networks. They're going to fail at some point 🙁
Still, back your situation, yes I agree that you really do need the original BIOS - or at the very least a Suntac ROM for the same chipset (even then they can vary based on the other supporting chips). You could always try fitting different RAM - though your board has SIPP sockets you can either desolder them and fit SIMM sockets, or fit some SIMM modules into SIMM sockets and just insert the sockets into the SIPP holes - they are electrically identical.
The other thing is to remove and reseat every removeable chip. It costs nothing and it could just be a bad contact somewhere.
https://www.target-earth.net
Reply 4 of 19, by freetmool
Very interesting thread and thanks for the original BIOS confirmation.
Haha yes I haven't used my 286 for 25 years , poor thing 😉
I'll order some SIMM to SIPP adapter and try that.
Could someone ask HanJammer if he could share his BIOS image if possible, please ?
He had posted the picture above and said it was working.
I don't have message privilege yet ...
Or any one else having it of course 😉
Thanks
Reply 5 of 19, by Predator99
Why do you think your original BIOS is corrupted? Did you try to read it with your programmer?
A BIOS from a similar board will do. Most 286 boards accept "standard" BIOS. Here are some, did you try those?
80286 BIOS image collection
Reply 6 of 19, by dieymir
I have almost the same board up and running. Mine has a 12Mhz processor and SIMM memory slots. BIOS is an AMI one dated 13/06/1990 Here is the image:
The attachment suntac.zip is no longer available
Hope this helps.
Please, Could you upload the EMS driver for the board and or the manual?
Thanks a lot
Reply 7 of 19, by freetmool
@Predator99
It's just a guess, I've tested the voltage, rams, reseated everything with deoxit, I have an error code 1-3-3 with a phoenix bios ( so the cpu seems to work ).
That would be nice to have a known good bios to compare with my programmer indeed.
Thank you for the link, very interesting.
@dieymir
Thank you for the bios image ! I'll try that for sure.
I'll upload the manual very soon.
The EMS driver will follow, I have to plug my 5 1/2-inch floppy drive to a PC with USB.
Reply 8 of 19, by freetmool
Here is the User's Manual and display module for Turbo:
The attachment SUNTAC 320i 286 User Manual and Turbo Dispaly 404C.rar is no longer available
Reply 9 of 19, by freetmool
@dieymir
So... it doesn't make any difference with your BIOS image.😢
Reply 10 of 19, by freetmool
@Predator99
I've tried your "286-Morse KP286.zip" and it works !!!!!
Thank you !
Another problem arose , my VGA card has white vertical stripes and it's blinking ... so I can see half of the boot if I blink at the right moment 😉.
But that's very promising.
Reply 11 of 19, by dieymir
Glad to know you have solved it and thanks for the manual!!
Reply 12 of 19, by freetmool
Here it is 😀
The attachment IMG_1670.jpg is no longer available
Reply 13 of 19, by pan069
Nice case. I have a similar looking one.
The attachment PXL_20200930_001059061.jpg is no longer available
Reply 14 of 19, by freetmool
Very nice 👍
Was it always that white or did you retrobright it ?
Reply 15 of 19, by Caluser2000
freetmool wrote on 2021-01-22, 22:42:
Here it is 😀
Great set up. GeoWorks Pro 1.2 and DrDos were the first things I put on my 286/16 in the very early '90s.
Reply 16 of 19, by Caluser2000
Cyberdyne wrote on 2021-01-21, 12:15:
286 with floppy and ide hdds was 'nt terrably rare from about '89 onwards. My '90 Zenith 286LP Plus has them. Those four connectors at the bottem are for 30 pin sipp ram. The board is very similar to the one I had ay back when. I maxed it out to four megs of sipps(had to remove the dipp ram first). At $nz100 a meg it wasn't cheap but I had a lot of disposable income back then. You can use 30 pin simm holders and plug them in to those sipp sockets and use standard 30 pin simms in them. just make sure you have the orientation correct when you fit the adapters.
Reply 17 of 19, by pan069
freetmool wrote on 2021-01-23, 19:01:
Very nice 👍
This is the color I got it in, other than cleaning I haven't done anything to it. It has a few scars, small crack in the top part of the plastic etc. But I think this my favorite case because it has all these odd curves and corners and the black plastic bits etc.
Reply 18 of 19, by Robin4
megatron-uk wrote on 2021-01-21, 15:20:
I'm going through a similar process myself (see my 286 is dead, long live the 286 thread: 286 dead, long live the 286! Sourcing […]
I would recommend to use Deoxit D5.. Use it myself to clean IC sockets and card slot or cleaning the contacts on surface mounted quad flat packs.
Reply 19 of 19, by freetmool
@dieymir
Here is the "EMS 303 Utility" that came with this motherboard.
The attachment SUPER.rar is no longer available
