Reply 17940 of 29946, by Caluser2000
- l33t
Not strictly but the could apply to older notebook/laptops.
My HP/Compaq CQ62 desktop set up was over heating in the warmer weather here. I suspect part of the reason for the over heating was trying to charge a completely dead battery pack. Because this system doesn't need battery pack I pulled the dead one out and dissected it, remove the cells and the small circuit board and sensors.
Once I had it apart I decide to make a fan holder out of it with a pentium 1 era SOYO 12 volt cpu fan. This fits into the battery pack nicely after some cutting if the plastic. I drilled holes in the bottom cover for the fan to draw fresh air in. I attached stainless steel mesh from an old Honda motorcycle , which I stripped many many years ago, air box with black silicon sealant. This will stop insects and other items from being sucked in. Drill holes in the top half of the battery pack were I knew they meet up the latch openings in the CQ62 where the battery pack will attach and lock in to place.
Searched through my wall wart box for a suitable 12v DC power supply. Used a bit of 32 thou lock wire bent in two and soldered to the black cpu fan lead and inserted it into the center of the psu connector with some insulation around it so there is no direct short with the other connector. Grabbed a eyelet connect from my electrical connector box which was a bit smaller than the outside of the psus outer contact. Cut most of the eyelet part off leaving a 5mm x 3mm tap I could solder the Red lead from the cpu fan.Also spread out the circular bit so it fitted on the outside of thge psu connector nice and tight. Got a piece of soft rubber clear tubing and fitted this around the outside of this.
Connected the psu to the cpu fan connector I'd just made to see if it functioned correctly. It did. Applied black silicon sealant to keep the fan in place, made a cut out for the psu connector in the bottom half of the battery pack and then seal the two halves together with black silicon sealant. Wrapped masking tap around the battery pack halves to keep them nice and tight against each other then left the unit out in the sun on the fence railing for a few hours. Removed the masking tape then retested the unit. Fan is working fine-Good. Now I can fit the unit to my CQ62 desktop set up, plug the psu into a spare electricle socket, turn it on and have extra cooling of I need it.
Edit 25--2021: Tested the unit today and there is quite a reduction in on my CQ62 desktop setup.
