Reply 60 of 71, by auron
you can just copy the ICD .dll into the game folder and hexedit out all the multitexturing extensions.
Half Life runs well on my K6-2+ With rage 128, a P3 should run it fine even in Software Mode..
Hi Guys,
I am trying to do some HL1 benchmarks without luck. Even if I record my own it just doesn't play afterwards.
I have 1.0.0.9 GOTY currently but hoping I can try the benchmark from BeginnerGuy but cannot find HL1108.exe. Does anyone have a link?
Super old thread but I used to play Half Life at lan parties ( A lot) at the end of the 90s and everything about this machine should make it run 60fps except for the TNT2 M64, which was never a good card. A overclocked Voodoo will get you there though.
did somebody compare radeon vs geforce opengl performance in goldsrc games? in 2021 I still experience radeon cards having bad performance
5800X + 6800XT in sven coop fps drops to 20fps x)
i did not have something like this with a geforce..
Win10 Ryzen 7 5800X | TUF B450M-Pro | 32GB DDR4-3800 CL16 | RX 6800 XT
WinXP Core i3-3220 | H77 Pro4-M | 8GB DDR3-1600 CL9 | X1950 Pro
Win98SE Pentium E5800 | 775i65G R3.0 | 512MB DDR1-400 CL2 | X850 XT
The stand-alone Sven Coop that's on steam has some major renderer cruft changes, I wouldn't see that as a good yardstick to compare two vendors on with regards to Half-Life.
Didn't they remove OpenGL from the original HL/goldsource engine in favor of Directx?
My builds!
The Underdog - The budget K6
Munx wrote on 2021-12-19, 11:35:Didn't they remove OpenGL from the original HL/goldsource engine in favor of Directx?
afaik OGL is there and the default option on steam.
Is there a way to run HalfLife on Voodoo1? I'm trying to do it on Pentium III -500/256MB/S3Trio+Voodoo1. I get 1-2 FPS in the game itself. The intro - riding on rails stretches for 20-25 minutes, sometimes smoothly, 15-20FPS, sometimes freezes for 1-2 seconds. The sound is interrupted. When returning to the menu, it loads line by line for about 10-15 seconds. Maybe there is some trick to make the game work smoothly?
Are you using a MiniGL to play? Which version? Are you sure you've picked that over the OpenGL ICD that came with your Voodoo driver (or god forbid the Microsoft OGL emulator!)?
Thank you! I reinstalled the minigl driver, installed the patch to version 1.1.1.0 and replaced the ISA sound card with a PCI one and it worked properly
Postman5 wrote on 2025-03-24, 08:11:Thank you! I reinstalled the minigl driver, installed the patch to version 1.1.1.0 and replaced the ISA sound card with a PCI one and it worked properly
That is great news! Also try to run it with 512x384 resolution! Also you can add Vram to the Voodo 1!
