First post, by Am386DX-40
Hey guys, another tricky (and interesting) one.
I've always read that there's absolutely no difference between the IIT 3C87 and the IIT 4C87DLC, and that the 4C87 is just a relabelled 3C87 that changed the name to go with the Cyrix/TI 486DLC line of processors.
Fair enough.
But today, I've found something really curious. I have 2 4C87DLC-40, which seem identical to each other, until I tested them with IEEETEST and then this happened:
Testing the 1st one:
Testing the 2nd one:
Clearly they are not the same internally, so we can throw the "they are all the same" out of the window.
On closer inspection, I notice that the one on the right is deep black, while the one on the left is more brownish-redish (this is the one that has rounding errors in the test). The manufacturing date differs by a few weeks, nothing major. I've been looking at photos everywhere and it seems that the black ones are all "1002FA" and the brownish ones are "1002FB". Maybe that indicates a different factory, maybe the brown ones are in fact relabelled 3C87 while the black ones have a new core with bug corrections and IEEE-754 compliance.
So I'll ask you guys (if you have the time and want to do it) to run the test on your machines and report back which IIT math co you have, and what results you get.
Also, according to "the bible of math coprocessors" (https://dougx.net/gaming/coproc.html) you can check on the accuracy tests that he uses a 3C87 (dated 1992) and he gets another result, different than the ones I posted. So there are "at least" 3 different versions floating around. Intriguing.....
Reply 1 of 32, by frudi
I'd be happy to test my 1002FC chip, but where could I download this IEEETEST program? Searching for it has proven completely fruitless.
Reply 2 of 32, by Am386DX-40
frudi wrote on 2021-01-27, 20:48:
If I remember correctly, it's part of the Cyrix Fasmath software suit that came with the Cyrix FPUs. A big selling point for them were "100% IEEE754 compliant". Give me a little time and I'll attach it here when I'm back home if you don't find it.
Reply 3 of 32, by Am386DX-40
Here it is, you can find IEEETEST in Disk2.zip
Reply 4 of 32, by frudi
Am386DX-40 wrote on 2021-01-27, 21:59:
Much appreciated!
I attached images of my chip and results. I got the same results as your 1002FB.
Reply 7 of 32, by frudi
I'm currently tinkering with another system, but I'll switch back to the 386 later and run HWiNFO on it to check what it reports for the FPU.
Reply 8 of 32, by frudi
So I ran HWiNFO for DOS and it recognizes the FPU as IIT 3C87 at 37.3 MHz.
I would attach a screenshot, but for some reason all text in HWiNFO is blinking for me (using an STB Systems ET4000AX), which my crappy phone camera can't deal with and refuses to focus on the monitor picture at all.
Reply 9 of 32, by Am386DX-40
frudi wrote on 2021-01-28, 15:42:
Yep, same exact behaviour as my "brownish" 1002FB one.
Reply 10 of 32, by Mumak
FYI guys - pressing F2 in HWiNFO will save the actual screen into HWINFO.LOG file and running with the -r parameter will automatically walk thru all screens and log all data.
Reply 11 of 32, by PiotrUU
I tested the IIT fpu. I detected 5 core variations. Group 1 fails the ieee and mcpdiag tests.
Group 4 and 5 have the same ieee-754 score.
The fastest is the FPU from group 4.
Reply 12 of 32, by PiotrUU
cd..
Reply 13 of 32, by PiotrUU
Interesting fact - fake intel -> IIT group 1
Reply 14 of 32, by 386SX
Very interesting! I've got a 1002FB 9422 fpu the brownish one but I need to install the hard disk cause I have a temporary overlayed 8GB disk waiting for a time correct one. Anyway as soon as possible I'll update but I suppose it'll fail too.
But these failures what does they mean? Some operations weren't supported? Are there any detailed logs on which ones and where they could be considered back then a problem?
Does these test passes on a 486 integrated FPU?
Reply 15 of 32, by kixs
I guess I missed this interesting thread somehow... I'll test with some of my IIT including X2 part in coming "months" 😉
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 16 of 32, by PiotrUU
tests stop responding at IIT group 1 as shown by m_1.jpg and i_1.jpg.
The computer needs to be reset. (ctrl-alt-del works).
i486dx works fine in testing. (0 errors)
Reply 17 of 32, by PiotrUU
Hello!
I am renewing an old topic to add another version of the IIT FPU core. I called it version "1a".
It is similar to version "1" but the mcpdiag.exe and IEEEtest.exe tests are performed to the end.
Does the production date help to discover the type of core? - no - see the dates on the sample FPUs.
But the description 1002BC../ 1002BF.. is type "1" and 1002CA.. is "1a".
I found type "1a" only with a speed of 33Mhz.
See how many times IIT improved the core. - and there are still 2c87 FPUs to be tested...
Reply 18 of 32, by Am386DX-40
Cool, this keeps getting better and better 😁
Reply 19 of 32, by Gahhhrrrlic
I just bought the IIT FPU from group 4 above (because it's supposedly the fastest and only has some fails in sine/cos). But I just want to confirm so I don't blow up my precious machine... These XC87-DLC chips work in a 386 computer??? I thought that was kind of the thrust of the original post but never saw it explicitly made clear whether these chips were being tested on a 386 or 486. Are all of the chips compatible as 387 coprocessors or do some have to be used with 486 sx or something like that? Thanks.
https://youtu.be/BlBH5VvPXKU
