Reply 29 of 167, by Sphere478
cyclone3d wrote on 2020-09-23, 15:50:
I have one of those AGP to PCI adapters. I can take some high resolutions scans and post them if that would help.
have you been able to get other cards to work in it? Like say a 9800gt 😁
Or does it only work on old voodoos?
sdz wrote on 2020-09-23, 17:51:
Something like this? […]
Even made a bracket for the V5 😀
I designed it a couple of months ago, AGP 1.0 1x (3.3V only), 4 layer board with uninterrupted ground plane under PCI signals, properly terminated unused AGP signals, 12V PCIe power input, 3.3V/5V switching power supplies which can deliver more power than the AGP specs require, separately filtered AGP VIO, high speed level shifters, it can work in any 3.3V/5V PCI slots, 33/66MHz jumper (if the mobo supports PCI 66MHz ofc), 2 fan headers with support for 5V/12V 3pin/4pin fans and adjustable PWM.
Holy crap man. Very nice!! Have you made any more improvements?
What’s the fastest card you have tried in it?
Sphere's PCB projects.
Reply 30 of 167, by Whatscheizer
Heh, I started down this rabbit hole last night. I've been getting into Unraid and what is possible with VMs. I was looking at some tutorials on this YouTuber's channel and noticed in his VM dashboard he had machines setup labeled as Windows 98 and Windows 3.11 ...I thought "huh" and went searching through his videos. Sure enough he had made one regarding the subject.
https://www.youtube.com/watch?v=rgIF8uG-2G0
So I'm already hunting down PCI-E to PCI adapters, however I'd really be curious to see if I could get a hold of a PCI-E to AGP adapter for the purpose of stubbing AGP hardware to pass through to a VM. ...and I kind of realize this isn't practical in anyway really. But I'll be damned if it isn't really cool. 🤣
I also came across this...
http://arstech.com/install/ecom-prodshow/usb2isar.html
I would think that ISA running through the USB bus might be a little odd though. I'm pretty much just in the theoretical phase of my over excitement. I haven't gotten too hands on yet.
Anyway I suppose my point is, please make a PCI-E to AGP adapter!
Reply 32 of 167, by Whatscheizer
sdz wrote on 2021-01-29, 19:05:
I already made one, but haven't assembled it yet.
PCIe x4 to AGP 1.0 1x up to 150MHz AGP clock. I will publish all the files when I have some free time.
Any chance you will make some assembled units and post them for sale? I'm sure its a bit of an undertaking and I'm not trying to press for a "right away" solution. I'd just be really interested in purchasing one if it were to become available.
Reply 34 of 167, by adalbert
So this is to install AGP card in PCI-E slot? Or other way around?
I was thinking myself about putting modern PCI-E cards in AGP slots (even 1x) to have better transfers than with PCI-E - PCI bridges (like in GT520 PCI, where you can really feel the PCI bottleneck). And having fun trying to run GTX in Pentium 3 PC or so.
I tried to make some research in this topic PCIe card in AGP slot. Do such adapters exist?, which was basically salvaging nvidia bridge chips or using PCI-E - PCI bridge in 66 MHz / PCI mode in AGP slot.
Reply 36 of 167, by adalbert
Okay, this is exactly the same IC i wanted to use too. But I didn't start designing the PCB yet.
Reply 37 of 167, by delcolux
sdz wrote on 2020-12-17, 19:36:
Thanks! Hopefully soon (ish) I will post photos of the RTX3090 sized 3dfx card 😁.
I'm sure you saw that Voodoo 9000 joke video with 32 chips... https://www.youtube.com/watch?v=_3iHV0NvLPI
Will be awesome to see a real 8-way implementation.
Reply 38 of 167, by The Serpent Rider
Quantum3D AAlchemy 8164. Which is a beast in it's own way.
Reply 39 of 167, by delcolux
The Serpent Rider wrote on 2021-02-05, 06:56:
Cool. Thanks for this. Didn't know that existed. This will give me some hours of internet exploration.
