WP32 McCake : MT32 compatible waveblaster board
Reply 60 of 452, by SScorpio
subnet_zero wrote on 2021-01-25, 14:32:
How about an USB interface and audio out on the McCake like it is on the Dreamblaster X2? Like for Routing the Dosbox MIDI to this device.
Wouldn't it be better to just run Munt or a Soundfont directly on the host machine if you are running Dosbox on a modern machine? You could also just run MT32 Pi on a regular Pi 3/4 rather than a ComputeUnit 4 and get what you are asking for.
Reply 61 of 452, by subnet_zero
SScorpio wrote on 2021-01-25, 14:37:
Yep, you 're right. I obviously didn't thought this through.
Reply 62 of 452, by DNSDies
Damn you Serdashop! My wallet can't take these repeated beatings!
Reply 63 of 452, by dreamblaster
New revision of board...
Thanks for your support !
Reply 65 of 452, by dreamblaster
Here's a first test, Silpheed MT32 track : https://youtu.be/W1HHudGXREA
Reply 66 of 452, by dreamblaster
Some more photo's
Reply 67 of 452, by JimWest
Great work!
This is exactly what I've been waiting for. I absolutely need that. Put me on the list... 👍🏼😎
Reply 68 of 452, by dreamblaster
claesbas wrote on 2020-11-18, 22:54:
So I can just plug this into my MPU 401 ISA cards wavetable and get full mt32 sound via Munt?
Yes that is the idea, perfect companion for Keropi's MPU / Orpheus card
just plug on wavetable header
and also, it needs additional power through floppy cable (due to the high current).
You can also power through wavetable header, but that is only suitable for high current interfaces, like the new CHiLL II
Reply 69 of 452, by d0pefish
Looking (and sounding) good - great job! 😀
Reply 70 of 452, by dreamblaster
I will make a new revision.. with a tiny display on it as well
Think it would be a nice addition.
the display could be local on the board,
or optionally extended to a 3d printed 3.5inch bay plate.
Reply 71 of 452, by root42
The display would be awesome. That plus the Chill2 board with a 3D printed case could make for some really awesome MT32 replacement!
YouTube and Bonus
Reply 72 of 452, by dreamblaster
root42 wrote on 2021-02-02, 10:27:
Yes i will make a special lid then, to make room for the display 😀
Reply 73 of 452, by schlomoe99
dreamblaster wrote on 2021-01-31, 15:53:
I will make a new revision.. with a tiny display on it as well Think it would be a nice addition. […]
Yes, that would be perfect!
Reply 74 of 452, by cde
awesome!
Reply 75 of 452, by kisscool
Daddy (private joke only Serge can understand), this is just awesome ! I just can't wait 😀
Reply 76 of 452, by dreamblaster
kisscool wrote on 2021-02-17, 18:24:
Patience, my son...
I'm designing the new revision with display...
Reply 77 of 452, by Cyberdyne
Hope there will be a final pruduct "budget" option without the display, only the interface for connecting the compute module to your waveblaster header.
Reply 78 of 452, by bnz99
This is very awesome. I'll have to get one of those as well.
Reply 79 of 452, by mothergoose729
Love this project! Feature request time!
Will there be ways to cycle ROMs for munt (CM32L, old MT32) as well as load different sound fonts from within DOS like you can with MDF and a midi PC emulator?
